MUM Europe 2020
miro10hr
Add additional ethernet port to RB411?
Wed Oct 10, 2012 10:26 am
Customer is asking for additional Ethernet port in RB411U. It will be used for 3G backup with embedded 3G wireless card, so miniPCI-E slot will be full. Is there a miniPCI Ethernet card suitable for Mikrotik?
The solution should be delivered in one enclosure, together with Routerboard and not hanging on some wires beside enclosure.
jandafields
Re: Add additional ethernet port to RB411?
Fri Nov 02, 2012 3:02 am
I don't know of any minipci ethernet cards, but you can use this:
http://store.apple.com/us/product/MC704 ... et-adapter
Ivoshiee
Fri Nov 02, 2012 3:43 am
Some 2 etheret port capable device similar to RB411 should be good to have, but you should go for something in the series of the RB433.
jandafields
Fri Nov 02, 2012 3:03 pm
Purchasing a 433 doesn't actually add any ports to the 411. I'm sure the OP knows he is allowed to purchase a new device with more ports, that wasn't the question.
Ivoshiee
Sat Nov 03, 2012 10:38 pm
Fine, but if to take account given conditions the RB411 is useless.
jandafields
Sat Nov 03, 2012 11:31 pm
Not if you add the ethernet adapter i listed above.
Ivoshiee
Mon Nov 05, 2012 10:16 pm
How you accomplish that? By some (innovative) soldering?
jandafields
Thu Nov 08, 2012 4:34 pm
No, use the USB port. The USB port is in the enclosure already. Just consider the usb-to-ethernet to be part of the network cable. This makes is "all in one enclosure".
Users browsing this forum: No registered users and 75 guests
