honzam
Why is 5.21 missing?
Sat Oct 13, 2012 12:57 pm
Why is 5.21 mising from development site?
I need download it :(
LAN, FTTx, Wireless. ISP operator
NetworkPro
Re: Why is 5.21 missing?
Sat Oct 13, 2012 1:19 pm
It may have been dangerous. Have you tried 6.0rc2 that is on there ? I think it works... except if some Ethernet drivers are not in it for x86 platform.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
honzam
Sat Oct 13, 2012 1:46 pm
I need 5.21 due NV2 Wireless fix. I do not know whether this fix is included in 6.0RC2?
I hope that MT support read forum and give us an explanation?
NetworkPro
Sat Oct 13, 2012 2:37 pm
Try this one http://www.sendspace.com/file/6lqbn9 Package Built Oct/10/2012 12:19:33 if something breaks - the person who installed it will take responsibility because this is a development test version which has not been released. I've tested it only on RB450G.
bambangs2komputer
Sat Oct 13, 2012 5:07 pm
btw when 5.21 released? because I never see. I need upgrade from 5.20 because my RB1200 if I Click reboot in winbox, my RB1200 can't work :-(
napismizpravu
FAKE files 5.21 mikrotik.com
Sat Oct 13, 2012 5:16 pm
no download all packages torrent http://www.mikrotik.com/download/router ... 21.torrent
fake files http://download.mikrotik.com/all_packag ... e-5.21.zip
-//- http://download.mikrotik.com/routeros-mipsbe-5.21.npk
FAKE all packages RouterOS 5.21 download is link mikrotik.com
Why doing to us?
NetworkPro
Sat Oct 13, 2012 5:42 pm
lol dont worry man its not a problem that those empty files (fake as you put it) exist on the server and we can hit their URLs by manually requesting it
5.21 is not released
no one is forcing us download empty files
Monday normal work time someone will fix that stuff. And rebuild/release/put on development page in mikrotik.com account.
napismizpravu
Sat Oct 13, 2012 6:20 pm
lol dont worry man its not our problem that we can download those empty files 5.21 is not released no one is making us download empty files Monday normal work time someone will fix that stuff. Statistics: Posted by NetworkPro — Sat Oct 13, 2012 4:42 pm
I'm looking forward to the new features and improvements that will be able to routerboard.
honzam
Sat Oct 13, 2012 9:51 pm
5.21 is released NOW
normis
Re: FAKE files 5.21 mikrotik.com
Mon Oct 15, 2012 8:05 am
Why doing to us?
What is fake? Both addresses are official mikrotik download sites!
normis
We removed the files when v5.21 was released on official download page
5CardBaka
Fri Oct 26, 2012 2:28 am
Hi Guys,
this is my first post and its due to lack of info from google. I've had a number of issues with the new routerOS 5.21. We use the RB750GL to bond pppoe connections using the mlppp functionality of the mikrotik. I'm currently using OS firmware v 5.19 because the traditional scripting I do for them fails horribly on 5.21. Is any one else having issues creating a pppoe interface on the RB750GL?
Everytime I use a command like:
/interface pppoe-client add user="insert random pppoe username here"password="random password" add-default-route=yes allow=pap dial-on-demand=no max-mru=1480 max-mtu=1480 mrru=1480 use-peer-dns=yes disabled=no name=pppoe-out1 interface=eth1-mdm1,eth2-mdm2
I get:
bad command name pppoe-client (line 1 column 12)
Even when trying to add the interface manually via winbox the options simply are not there.
I've checked the change logs and for some reason can find nothing on this. Anyone else having similar issues?
Thanks in Advance,
James
normis
Fri Oct 26, 2012 8:28 am
TIP: do not post in other topics, make your own. It will be easier to see your post by others
You are missing some RouterOS packages. Make sure you upload this file to your router: http://download.mikrotik.com/routeros-mipsbe-5.21.npk then reboot it.
Users browsing this forum: glat, Gulik, sindy, yreks and 151 guests
