Knight
Why API Is Too Slow
Mon Oct 15, 2012 2:41 am
hi I'm using API Php Class But I want to know why api is too slow why it is not like winbox
it's take long time to disable,enable,add or remove
for example i have 600 user on rb750gl i can enable and disable all users but it's take long time may be 5 minutes
or more
but via winbox just seconds
this is my class
http://wiki.mikrotik.com/wiki/API_PHP_class
thanks
boen_robot
Re: Why API Is Too Slow
Mon Oct 15, 2012 12:35 pm
If you're doing multiple enable/disable/remove commands, that's to be expected.
To make it more efficient, you should collect all IDs in a comma separated list, and execute a single enable/disable/remove command with all of them.
Winbox is more efficient because by the time you hit the "enable/disable/remove" button, the comma separated list has already been gathered (with each click on an entry), and only that single command is issued.
Knight
Mon Oct 15, 2012 2:48 pm
thanks, you are right.
your suggest solved my problem
aboshhab
Thu Mar 24, 2022 6:46 pm
can you please explain to me more
or give me just example, buz i suffering from slow api
rextended
Thu Mar 24, 2022 6:50 pm
This is unuseful, the user left MikroTik forum on 2019,
very bad habit to resurrect old topic from 10 years ago...
aboshhab
Thu Mar 24, 2022 11:18 pm
sorry
advice me what should i do
Jotne
Fri Mar 25, 2022 7:36 am
No reply to an 10 year post...
And do not quote the whole post above you. Not a good habit as well.
Use the green Post Reply button under the the post to reply some.
When there are post inn between, you can quote a post, but pick only what you reply to.
