DogHead
Bypass Webfig Splash
Thu Oct 18, 2012 6:16 pm
Is there a way in ROS 6 to bypass the first splash screen of webfig and just go to the plain login page with no logos or links to graphs, telnet, etc as the default. When logging in we just want two fields on the page...userid and password, nothing else. Can this be done using skin design? if so how
WOOF BANG!
linek1980
Re: Bypass Webfig Splash
Thu Oct 18, 2012 8:00 pm
unfortunately not possible :( .
partial solution:
DogHead
Thu Oct 18, 2012 10:58 pm
Thanks for the suggestion. I suppose the best I can do is follow your suggestion and then create a skin that limits the admin account to do minimum viewing of status items only.
WOOF BANG!
Users browsing this forum: No registered users and 40 guests
