KBoris
Ping time very strange - SOLVED
Sat Oct 27, 2012 10:35 pm
Hello, I have Switch routerboard 250GS and I connect PC direct to the interface 5 (or any other). Without any changes in configuration I try to ping switch and I see the response time in ping is very slow (19ms). I expect that should be less or equal 1ms ? Anybody other have same problem ? SW software version is last 1.6.
C:\Users\User>ping 192.168.88.1 -t
Pinging 192.168.88.1 with 32 bytes of data:
Reply from 192.168.88.1: bytes=32 time=19ms TTL=255
Ping statistics for 192.168.88.1:
Packets: Sent = 7, Received = 7, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 19ms, Maximum = 19ms, Average = 19ms
Any suggest would be helpfull
regards
Boris
mixig
Re: Ping time very strange
Mon Oct 29, 2012 10:46 pm
It should be 0ms, maybe bad cable? Tried with different computer?
KBoris
Mon Oct 29, 2012 11:03 pm
Thank you for your response. I already try three different cables and two computers also two different Mikrotik Switch RB250GS , on every same problem.
Any idea ?
reverged
Tue Oct 30, 2012 6:47 am
19ms is not unusual for pinging the switch management interface.
If you ping another device connected to the switch, you will see 1ms or less.
kirshteins
Tue Oct 30, 2012 8:28 am
Such ping times are normal. 250GS does not have powerful CPU to generate ping response faster than that.
KBoris
Re: Ping time very strange - SOLVED
Tue Oct 30, 2012 2:55 pm
OK, satisfied with answers. I will try to ping other device.
Thank you everybody for answers.
Regards
Boris
Users browsing this forum: No registered users and 7 guests
