hi all
I have about 300 clients. this week most called me becouse Internet was very slow.
how much bandwidth do I need to satisfy them? half of them use skype
any help
It depends on how many use it at the same time... and what they are doing.hi all
any help
You could increase your bandwidth by 300% but this not wise unless you first plan each move carefully.hi all
any help
How is 30mbps going to work if he actually has 150 people using Skype and he received more than 150 complaints in 1 week?30 mbit with good queue tree management
Maybe he exaggerated in the number of skype users, and the number of complaints... but the OP hasn't asnwered any questions yet for you to make an absolute "you need 30mb" comment.
Thanks for the replies. I really have 120-150 customers at the same time who use SKYPE.
my speed for the moment is 50mb down and 10mb up (i pay $2000 for this).
i think i dont have good queue management.
With 50Mb and 150 customers that is only a 3 to 1 contention ratio which is more than adequate for clients and if they are complaining about the service being slow maybe you have network configuration issues and not internet access issue?Thanks for the replies. I really have 120-150 customers at the same time who use SKYPE.
If there is no customer bandwidth limits being used, then it’s time to consider using or pay more for unnecessary extra bandwidth.
hi all
any help
Sorry my mistake about upload speed, I should have pointed out 50Mb is OK for downloading @ 3 to 1 contention but have you ever seen a network which has 100% of customers using just one application (Skype) simultaneously, I don’t think Skype is the real problem here but part of, there could be torrent files uploading, etc. and if bandwidth limits for customers is not in place they could simply be using 100% of the upload bandwidth 24/7 and choking the network, network traffic needs to be analysed, pinpoint users who have a very high usage, adding extra upload bandwidth will help but without bandwidth limits and fair usage policy for customers, the problem will occur again?ONLWith 50Mb and 150 customers that is only a 3 to 1 contention ratio which is more than adequate for clients and if they are complaining about the service being slow maybe you have network configuration issues and not internet access issue?
You obviously don't understand the importance of upload speed. He only has 10 mb up. How is that more than adequate for 150 skype users??? Skype uses an equal amount of upload and download.
There is no magic configuration that can fix that!
He specifically said:but have you ever seen a network which has 100% of customers using just one application (Skype) simultaneously
That is a lot who SkypeHe specifically said:but have you ever seen a network which has 100% of customers using just one application (Skype) simultaneously
According to the Skype website:
Recommended upload / download speed: 300kbps / 300kbps for standard video quality, each user
150 skype video users X 300kbps = 45mbps UP AND DOWN
Unlikely that from 300 users you have, half of them use Skype at the same time.Thanks for the replies. I really have 120-150 customers at the same time who use SKYPE.
my speed for the moment is 50mb down and 10mb up.
You are being unrealistic. Skype is EQUAL upload and download. If each skpye video call is 300kpbs UPLOAD, then 30 skype users will saturate the 10mb upload... and that is assuming that no one else is using the internet. That's no where near 150 users.
50mb down should be enough, upload is small.
Most IP networks are designed for users to download more than they upload, usually with an expected (Download:Upload) ratio of 3:1 or more. You have 5:1.
I would say that 10% of 300 customers spending 2mb is 60mb/20mb would be enough.
If you want better you can use 15%: 90/30.
Yes, Skype is equal. But you also mentioned that "and that is assuming that no one else is using the internet".You are being unrealistic. Skype is EQUAL upload and download. If each skpye video call is 300kpbs UPLOAD, then 30 skype users will saturate the 10mb upload... and that is assuming that no one else is using the internet. That's no where near 150 users.
Have you seen this person's network? If not, how do you know that he is incorrect when he confirms the number of active skype users? In some parts of the world, Skype is the #1 communications method.
To further complicate the calculations, it it not stated how many are using Skype for video and how many are using it for phone calls, you are assuming they are all using it for video.
It doesn't really complicate it that much. If 1/3 of the skype users are on voice-only, and 1/3 are on standard video, and 1/3 are on high-quality video, it still averages out to almost the exact numbers as if they were all on standard-video.To further complicate the calculations, it it not stated how many are using Skype for video and how many are using it for phone calls, you are assuming they are all using it for video.
It would very interesting to view a screenshot of the 120-150 Skype users online simultaneously.It doesn't really complicate it that much. If 1/3 of the skype users are on voice-only, and 1/3 are on standard video, and 1/3 are on high-quality video, it still averages out to almost the exact numbers as if they were all on standard-video.To further complicate the calculations, it it not stated how many are using Skype for video and how many are using it for phone calls, you are assuming they are all using it for video.
samsung172, do you have a question? You should start a new thread with your question. This thread is specifically for "rini" and his problem. Your picture doesn't have anything to do with his question.I can give you one exsample from our system:
Today one of my customer have sold:
down 596 mbit (linje 100 mbit, 596% booking)
up 591 mbit (linje 100 mbit, 591% booking)
Look at picture for actual usage:
How many customers for 600Mb/s, unless bandwidth is very cheap should you have a 100Mb/s?Well, this was a reply, to "how much" bandwidth do i need. This was an exsample. HÆow much bandwith do i neeed, depends on how much do all customer wants. I doubt, that its 300 customer, having 150 skype calls at the same time. half of em having skype. I will assume, that then all of em also have internet.
The Q was not, how much bandwitdh do i need for 150 skype calls. Or 300 Skype calls.
When the Q is, how much do i need, you need to know a bit more about customer dependences. In my answer, there is no qwuestions, just a. This is how it might be for someone else.
Sold : about 600Mb/s , actual use, nevere peeked above 80Mb/s, but around 20-40Mb/s
