MUM Europe 2020
fash
New Users
Sun Feb 05, 2006 7:25 pm
For a new user of mikrotik ,how can one set up an ISP with the products.I need a detailed diagram of an ISP setup.
I think Mikrotik is the best thingthat has ever happened to linux world.
wildbill442
Sun Feb 05, 2006 8:12 pm
So basically what I got from your post is, you don't know the first thing about networking, and you want us to build it for you.
Before you dive head first in the ISP game it might be wise to get some kind of understanding on how the industry works. Here's a great book I'd recommend for anyone in the industry: http://tinyurl.com/9qxzz
More information on Networking, TCP/IP, and the OSI model:
http://www.uga.edu/~ucns/lans/tcpipsem/
http://goforit.unk.edu/networks/default.htm
And finally, pour through the mikrotik user manual, if you're going to use RouterOS and mikrotik based products it'd be wise to learn the Operating System.
I don't mean to sound condescending, but if you don't know how to deploy routers and bridges in a network environment and your goal is to provide customers access to that network, your business plan just failed.
However, if you're serious in your ISP endevor educate yourself before you dive in, it will only help you make more educated technical descions in the long run once you have staff that actually does the "dirty work" for you.
Your other option is to hire a network engineer and the appropiate staff to design, build, and maintain the network for you. :)
ofasa
Sun Feb 05, 2006 10:36 pm
Take a look at these:
http://www.mikrotik.com/index.php
http://www.mikrotik.com/appexamples.html
http://www.mikrotik.com/projects.html
For a diagram of an ISP setup, depending on the required capacity, you can do everything on one MT box!
Hope this helps.
djape
Re: New Users
Mon Feb 06, 2006 12:33 pm
How about you employ somebody to do this for ya?
You'll save yourself a lot of trouble ;)
I drink like a pirate and smoke like a hippie...
normis
Mon Feb 06, 2006 12:34 pm
Users browsing this forum: EnverS and 49 guests
