MUM Europe 2020
brainy
Problems with mesh-interface and topology change
Mon Nov 05, 2012 10:26 am
i have a simple setup of 5 RB751, one is configured as hotspot-gw, the others are simple wds-slaves. In the current lab-setup all devices can see each other by wifi.
The gateway has "Mesh Portal" configured. All other settings are default settings and i use dynamic-mesh in the wifi settings.
Now when one accesspoint is getting lost (i.e. rebooted) everything is ok but when it comes back (topology change?) i loose the whole wds mesh for about 45 seconds and i can not reach any of the other (still connected) accesspoints.
I didnt find any good howto or anything like that, that could help me with that issue :(
Any ideas?
Regards,
Joerg
TheWiFiGuy
Re: Problems with mesh-interface and topology change
Mon Nov 05, 2012 4:36 pm
Mesh is still broken and does not have the wds loop fix that were introduced to bridging in the 5.18 fix - or so I was told when I questioned this with support. They 'may' get around to fixing it.
Your simply getting a L2 loop which floods the network until it finally sorts itself out.
Mikrotik Consultant.
MTCNA, MTWCE, MTCTCE, MTCRE, MTCINE
brainy
Mon Nov 05, 2012 7:39 pm
is there any workaround? this is REALLY annoying issue because its causing a lot of outages :(
Users browsing this forum: No registered users and 36 guests
