MUM Europe 2020
SirThor
iOS6
Tue Nov 06, 2012 11:04 am
I'm unable to login to my routers through webfig from either inside the network or from the web via static IP. I'm using iPhone4s or iPad iOS6. Did not have a problem prior to upgrade.
I have a 493AH v.5.20
SirThor
Re: iOS6
Thu Nov 22, 2012 1:44 pm
update: i find that if i change the service port www to something other than 80 i can gain access.
SirThor
Re: iOS6
Thu Nov 22, 2012 2:01 pm
update 2: that only worked for a little while.
SirThor
Re: iOS6
Fri Nov 23, 2012 11:05 am
update3: i find that if i delete cookies I'm able to access the router. this needs to be done daily though. I'm sure there is a better fix.
SirThor
Re: iOS6
Sun Dec 02, 2012 3:04 am
Really. No one else is having this problem!? :shock:
remotelylocated
iOS6
Sun Dec 02, 2012 6:56 am
I have used chrome and safari from my 4s with iOS6 and have had no issues using ros 4.x - beta6rc4.
Jason
Sent from my iPhone using Tapatalk
Jason Wilson
Remotely Located Inc.
Providing High Speed Internet to out of the way places.
530-651-1736
http://www.remotelylocated.com
astern
Re: iOS6
Tue Dec 04, 2012 8:14 am
I registered just to say that I'm seeing the same issue too on 5.22 with a 2011UAS.
scampbell
Trainer
Trainer
iOS6
Tue Dec 04, 2012 11:05 am
Do you have any DST-nat rules configured for port 80 ?
If you do not specify the interface it may redirecting your requests.
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
Users browsing this forum: zafarsyal and 59 guests
