MUM Europe 2020
americo
I CAN'T PING!!!!!
Tue Feb 07, 2006 3:56 pm
I have my RouterPC installed with two ethernet cards, one configured with the 200.x.x.x IP for getting access to the outside, and the other card is set to 192.168.1.1, and through cross connection, I can't PING to a PC with the IP 192.168.1.2. COULD YOU HELP ME? I want to connect that PC to internet. :?
cibernet
Long time Member
Long time Member
Re: I CAN'T PING!!!!!
Tue Feb 07, 2006 4:02 pm
? have you read the basic documentation...?? post your configuration...
Regards
José Ignacio Acosta
MikroTik Consultant IDAR0001
Mikronet
Movile: +54 9 3472-624722
Email/Msn: info[at]mikronet.com.ar
normis
Tue Feb 07, 2006 4:03 pm
interfaces on router are enabled? paste the following:
/interface print
/ip address print
/ip route print
americo
Tue Feb 07, 2006 4:05 pm
My real problem is that I want to setup a web proxy, but I cant even make ping :?:
normis
Tue Feb 07, 2006 4:06 pm
please do what i asked
americo
Yes, they are enabled.
djape
Tue Feb 07, 2006 4:07 pm
Could you give us some more info?
Check ARP...
I drink like a pirate and smoke like a hippie...
normis
Tue Feb 07, 2006 4:10 pm
no, please do the commands that I wrote and paste the results in the forum. commands:
/interface print
/ip address print
/ip route print
cibernet
Long time Member
Long time Member
Tue Feb 07, 2006 4:11 pm
Tell us how do you add the ip´s? did you ran setup command on CLI?
José Ignacio Acosta
Mikronet
americo
Tue Feb 07, 2006 4:19 pm
# Address Network Broadcast Interface
0 200.x.x.x 200.x.x.x. 200.x.x.x ether1 (added by setup)
1 192.168.1.1 192.168.1.0 192.168.1.255 ether2 (added by setup)
# dst-address Prf Gateway Distance Interface
0 ADC 192.168.1.0 192.168.1.1 ether2
1 ADC 200.x.x.x ether1
2 A S 0.0.0.0/0
# Name Type RX TX MTU
0 R ether1 ether 0 0 1500
1 R ether2 ether 0 0 1500
cibernet
Long time Member
Long time Member
Tue Feb 07, 2006 4:25 pm
2 A S 0.0.0.0/0
You missed the default route....
put this on terminal :
ip route set 2 dst-address=0.0.0.0/0 prefsrc=(your isp gw) distance=1
Regards
José Ignacio Acosta
Mikronet
americo
I used ip arp print, and get no data
americo
Tue Feb 07, 2006 4:41 pm
I made the configuration you told me, but I still cant ping
raulborda
Tue Feb 07, 2006 5:27 pm
What is your isp gw IP?
Raul
americo
Tue Feb 07, 2006 5:40 pm
I cant tell that 8)
djape
Tue Feb 07, 2006 5:57 pm
Then there is something wrong with the cable or card. If you are sure that everything is ok then do this:
Add static apr entry
enter mac-address of 192.168.1.2 pc and which interface
Cheers...
Borage
Tue Feb 07, 2006 8:36 pm
This is obviously a physical problem between those computers. I strongly advice you to replace that crossover cable with a switch. You can try to disconnect and connect the cable and see if it helps. If it does not, you may try to restart the computer with Mikrotik RouterOS. You can also set the Link Speed/Duplex Mode to a fixed rate instead of Automatic Mode in the computer with IP address 192.168.1.2 and the computer with Mikrotik RouterOS.
Users browsing this forum: che, MSN [Bot], Sob, UpRunTech and 104 guests
