MUM Europe 2020
raenius
Wireless Cards for routerboards
Tue Feb 07, 2006 10:14 pm
Hello, just wondering what wireless cards you guys use. Well more importantly which cards have worked best with this system and give you the best range. I live in an area with lots of trees :) I have read atheros based cards are really good but would like some input from you guys. We been using Tranzeo 4500's but would like to start using mikrotik and routerboards for our APs' instead. Mainly because of all the features and bandwidth management built into the system. Anyway any hints or suggestions on cards would be greatly appreciated.
Thanks in advance
jober
Long time Member
Long time Member
Wed Feb 08, 2006 6:47 pm
We use SR2, SR5, SRC, CM9, SL-2511CD Plus Ext2, SL-5354MP and many more. They all have their place. But my fav. is the SRC, SR2 and SR5.
cscheele
Wed Feb 08, 2006 6:54 pm
we use Wistron DCMA-81 (halfsize minipci)
Atheros AR5413 Chipsatz
802,11a/b/g Triband Radio
Atheros Super A/G Modus
works wonderful on rb532(a) also with doughterboard.
rickard
Sun Feb 12, 2006 9:58 pm
I use the (R52) 802.11a+b+g 65 mW Wireless miniPCI Card
and it work like a charm :-) i have it today on 150 customers CPE units.
I have tested the SENAO 100 mv card called ARIES2 and i working well but its more sensitive to noise compared to the R52 card.
This is from the Mikrotik site :
MikroTik presents our new wireless 802.11a+b+g miniPCI card for multibandhigh speed applications! It can work either on 2.312 - 2.497 or 4.920 - 6.100GHz range.
//Rickard
sergejs
Mon Feb 13, 2006 1:12 pm
rickard,
150 online users ? :o
Note, do not use more than two wireless interfaces in RB500, if they are SR cards.
rickard
Mon Feb 13, 2006 2:50 pm
Yes 150 users on lots of RB500 Ap cells :-) the maximum user per AP is 20 users.
//Rickard
GJS
Wed Feb 15, 2006 7:10 pm
What's the difference between the R52 and the CM9?
Guy
wispuk.org
A Forum Community for UK WISPs
rickard
Wed Feb 15, 2006 7:40 pm
The main diffrent that im found is that the R52 is sensitive compared to the CM9 . And its handeling the Noise verry good.
We are running on 5.4 Ghz with 26 Dbi Grid antenna and the distance is 10 Km with signal -54/-58. and real trafic is ~ 25 mbits.
//Rickard
GJS
Wed Feb 15, 2006 7:51 pm
Thanks Ricard. Can you tell me the price for small volumes? The MT site does not have it.
Guy
wispuk.org
GJS
Thu Feb 16, 2006 1:13 am
Sounds good. It may make a very good combination with the new R100 routerboard.
Guy
wispuk.org
rickard
Thu Feb 16, 2006 9:38 am
Yes it will be perfect solution. and when i get my own designed antenna that can handel Both 2.4 ghz 19 dbi and 5.4-5-5.8 ghz 24 dbi in the same antenna :-) , its in development state right now. Then i only have to change the a or b setting on the R52 card.
//Rickard
texanmutt
Fri Feb 17, 2006 7:54 pm
Were is the spec sheet for the R52 card ? How much does this card cost?
normis
Mon Feb 20, 2006 8:17 am
please write to sales or support and we will give you the pdf
phendry
Thu May 11, 2006 8:14 am
I heard that the actual performance of the R52 wasn't as good as the CM9. Maybe this has been rectified in recent releases but confirmation from Mikrotik on this would be handy.
normis
Thu May 11, 2006 9:31 am
actually it is the other way around.
phendry
Thu May 11, 2006 9:41 am
Cool. In what way?
normis
Thu May 11, 2006 9:47 am
the R52 is at least as good as the CM9, in many cases - it is better. Plus it's cheaper. It uses a newer and more advanced chipset, and when we did the 300Mbit wireless combo link at the MUM-Prague - we came to conclusion that R52 will be better for this kind of test.
NZLamb
Fri Jun 09, 2006 7:24 am
What about the Compex WLM54G? Anyone here used these before or have any opinions?
djape
Fri Jun 09, 2006 12:06 pm
I used it and wouldn't recommend this card, furthermore I wouldn't recommend any Compex product. Bad signals, too much noise...
I drink like a pirate and smoke like a hippie...
NZLamb
Fri Jun 09, 2006 1:53 pm
Damn, I just ordered a bunch but haven't set them up yet! In hindsight I guess it pays to ask first! :)
Mind you they won't be used for anything over 3km and will be out in the sticks with no other networks around so hopefully will be OK.
jonbrewer
Tue Jul 04, 2006 10:50 pm
There are other networks around. Engineer carefully.
Users browsing this forum: No registered users and 10 guests
