MUM Europe 2020
leoservices
Trainer
Trainer
RB751U 2HnD to version 6.0-rc3 with variable processing
Mon Nov 12, 2012 2:32 am
I put in my RB751U 2HnD to version 6.0-rc3 and noticed that processing varies from 5% to 100% with only one client in the wireless with very low traffic. In this New Terminal also slow.
Firmware Version 3.0
I try to help !
Leonardo Vieira
https://youtube.com/contractti
Like Facebook.com/contractti
leoservices
Trainer
Trainer
Re: RB751U 2HnD to version 6.0-rc3 with variable processing
Mon Nov 12, 2012 2:48 am
I did a downgrade to 5.21 with the same settings as RB returned to normal operation. I was not happy because I could not identify the real cause to contribute to Mikrotik
I try to help !
Leonardo Vieira
cbrown
Trainer
Trainer
Mon Nov 12, 2012 3:28 am
Did you check /tool profile to see what was the cause?
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
TSimmonsHJ
Tue Nov 13, 2012 8:55 am
I'm seeing similar issues with the same release on the same hardware.
At near-rest (traffic through the device best measured in k) the device seems to consume 5-10% cpu.
Under moderate load (1 client, 25mbit through wireless to cable modem on ether1) the cpu usage gets up around 100% and winbox and terminal response hang. While watching profile it freezes for a bit and when it unfreezes the 'flash' process is upwards of 55% and falling.
I've also seen seemingly random reboots of the device by watchdog that don't appear to be load related. Sometimes once a day, sometimes a few times in an hour, then not again until the next day.
Issues were not present under 5.21, same config.
uldis
Tue Nov 13, 2012 1:57 pm
could you make a support output file from your setup?
Also what kind of that 25mbps traffic it is? Torrent or some file transfer - so we could try to reproduce it?
TSimmonsHJ
Wed Nov 14, 2012 1:13 am
I have submitted the supout as requested.
The traffic in this case was http, generated by running a speedtest at http://speedtest.net.
estdata
Sat Nov 17, 2012 1:52 pm
uldis
, I also wished ever 6.0 or 5.21 in addition to put but I dare not because of my cpu, and the router itself becomes slower, I fear it. Was this version as 5.18 and then happened to be such a thing as the cpu at 100% and the router dizzy
don't forget to give me karma if got help
nickshore
Sat Nov 17, 2012 6:05 pm
I am seeing lots of cpu being used by the flash process on a 751U as well.
Tried to make a supout but it didn't like it - tested on dev version, still the same
I'm testing by doing a wget over wifi on a single stream, into a pppoe client onto my DSL.
Seeing flash process jumping up to around 35% in normal running, and then cpu maxing at 100% when doing a simple download.
Update managed to generate a supout, sending to support
Nick.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
vadyalex
Sat Nov 17, 2012 7:36 pm
Nick.
I have similar problem when intensive traffic goes over Wi-Fi on the device CPU goes to the sky and RB751U hangs.
nickshore
Wed Nov 21, 2012 11:43 am
Confirmed CPU usage when downloading on wired seems fine, but using wireless causes it to use lots of CPU.
Nick.
uldis
Fri Nov 23, 2012 6:11 pm
contact support@mikrotik.com to get test release of RouterOS v6.0rc4 where it should be working better.
nickshore
Fri Nov 23, 2012 8:46 pm
Today's rc4 seems a lot better !
Users browsing this forum: Google [Bot], MSN [Bot], Rey68 and 95 guests
