MUM Europe 2020
bowgey
[solved] L2TP/IPSec client to site configuration
Fri Nov 16, 2012 9:38 am
sorry for that silly question and my bad grammar, i have tried to configure L2TP with IPSec on this topology but i still can't activate the IPSec on the router. the L2TP tunnel is worked properly, but when i add an IPSec, the tunnel still worked with no IPSec running.
i use this configuration on gateway router
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des,aes-128,aes-192,aes-256
/ip ipsec peer
add generate-policy=yes hash-algorithm=sha1 nat-traversal=yes secret=test123456 send-initial-contact=no
i use RouterOS v4.3
my client is windows 7 home premium
what should i do next?
thank you.
NAB
Trainer
Trainer
Re: [ask] L2TP/IPSec client to site configuration
Fri Nov 16, 2012 11:11 am
i use RouterOS v4.3 ... what should i do next?
Upgrade to ROS 5.x.
Nicholas Barnes BSc(hons)
Certified Mikrotik Consultant
Certified Mikrotik Trainer
Vitell - Asterisk, Linux and network consultants
Unofficial IRC channel: #routerboard on irc.z.je
bowgey
Fri Nov 16, 2012 12:37 pm
Upgrade to ROS 5.x.
is it necessary? because I don't have any privilege to do that...
so, it would be a dead end, is it? :(
bowgey
Mon Nov 19, 2012 11:23 am
Upgrade to ROS 5.x.
is it necessary? because i don't have privilege to do that. :(
bowgey
Tue Nov 20, 2012 10:01 am
is it necessary? because i don't have any privilege to do that. :(
NAB
Trainer
Trainer
Tue Nov 20, 2012 1:19 pm
4.3 is incredibly old. Assuming that you have read the wiki section on IPSec and have set your configuration correctly, then this would be my first course of action.
mrz
Tue Nov 20, 2012 1:24 pm
If client is windows PC then you need to set exchange mode to main-l2tp which is available starting from v5.4
Users browsing this forum: No registered users and 93 guests
