evert
Syslog & firewall...
Fri Aug 20, 2004 10:06 pm
Hi everyone!
Which firewall rules (if any) do I need to be able to log all syslog traffic from my Mikrotik on a server on my LAN?
signal
Sat Aug 21, 2004 6:44 am
That would go thru the "output" firewall chain. If you have nothing in this chain, then your golden. If you are putting rules in this chain however, then make sure you are allowing syslog traffic to your server. I would suspect however, that you probably have nothing in the chain.
Brian
