Ivoshiee
Update License Key->"failed: could not resolve www.mikrotik.
Sun Nov 25, 2012 1:37 pm
If I recall correctly then you should be able to use NetInstall to flash in random ROS version regardless of current ROS level or license level.
I tried it on a RB333 with current ROS v3.30 and sent in a ROS v5.16. As the license key format is different between those releases, it urges me to upgrade the license key by pressing "Update License Key". If I do it then I am greeted with a prompt message about "failed: could not resolve http://www.mikrotik.com". If I fire up a terminal session within the same Winbox then I can ping http://www.mikrotik.com just fine.
What I am doing wrong? The clock is ticking and I have 3 days to resolve it.
slawekk
Re: Update License Key->"failed: could not resolve www.mikro
Sun Nov 25, 2012 1:40 pm
You must have internet access on host you run winbox.
Ivoshiee
Sun Nov 25, 2012 1:45 pm
Thanks. I expected it to be the MT box itself that should have the Internet access.
trystan
Tue Nov 27, 2012 4:46 pm
That just got me too!
I was running winbox inside 'wine' on Linux - I couldn't figure out why the DNS didn't work until I read this post.
