MUM Europe 2020
remo85
[SOLVED] strange ip range
Sun Nov 25, 2012 10:37 pm
My nightmare,,,these ip`s is my biggest problem in life now.,,did anyone see like that before?
cbrown
Trainer
Trainer
strange ip range
Sun Nov 25, 2012 11:17 pm
What do you mean? What is the problem?
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
remo85
Re: strange ip range
Sun Nov 25, 2012 11:28 pm
The problem is these ip`s are not in my range,,they are stuck somehow in clients routers,and when they connect to the network they generate huge traffic over the specific ap they are connected with,,i tried to stop them with no result,,i can`t see the ips anywhere but in mikrotik like you see.notice that they refer to a DNS also,,which is real.
Ivoshiee
Mon Nov 26, 2012 12:17 am
It is probably just a device down with some IP-address generating virus. Just throw them out of your network and ask them to fix it before let back in.
remo85
Mon Nov 26, 2012 10:44 am
We tried once to disconnect all the clients after we disconnected them one by one with no result,,i found that these ip`s come from the internet with range 1.0.0.0/8 i blocked them via juniper SSG5 but they kept stuck with clients,,i bought new router and connected to it to the mikrotik and it gave the same!!!!! im trying to rebuild all routers including mikrotik today hoping it will work,,the truth is that i really can`t understand what is going on,posted this hoping some is familiar to it!!!
Thank You.
Ivoshiee
Tue Nov 27, 2012 1:52 am
Look at the MAC address. Is it truly at the WAN side?
remo85
Re: [SOLVED] strange ip range
Tue Nov 27, 2012 2:39 pm
We found that an attack with DDNS affected our network,,we stopped it from the public side,,these ip`s were stuck with TP-LINK 740N routers,,we tried to reset and upgrade it with no result,,finally we changed all firmware with DD-WRT one,,its stronger with more firewall and security options,,it stopped. thank god.
Thank You so much
Users browsing this forum: No registered users and 79 guests
