MUM Europe 2020
normis
v6 rc5 released
Thu Dec 06, 2012 12:30 pm
What's new in 6.0rc5 (2012-Dec-05 15:22):
*) wireless - advanced rate selection is the only method supported;
*) ssh client - support keyboard-interactive authentication;
*) fix simple queue config upgrade;
http://www.mikrotik.com/download
honzam
Re: v6 rc5 released
Thu Dec 06, 2012 12:51 pm
RB111, RB112, RB113C, RBMinirouter devices are not supported in v6, please use v5
Never in the future?
LAN, FTTx, Wireless. ISP operator
normis
Re: v6 rc5 released
Thu Dec 06, 2012 12:59 pm
too many features, too little RAM. those devices are quite old already, and new device of superior power costs as little as 39$
Raf
Re: v6 rc5 released
Thu Dec 06, 2012 1:19 pm
And too slow CPU.
Rafał Wójcik from AWB-NET
High Definition enthusiast
w0lt
Re: v6 rc5 released
Thu Dec 06, 2012 1:35 pm
Normis,
Stable still downloads the 6.04 torrent...
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
slech
Long time Member
Long time Member
Re: v6 rc5 released
Thu Dec 06, 2012 1:51 pm
And as always:
All stable files - http://www.mikrotik.com/download/routeros-ALL-6.0rc4.torrent
sorry for my english
paoloaga
Re: v6 rc5 released
Thu Dec 06, 2012 2:18 pm
On 6.0rc5 I am not able to add PPPoE client interfaces. I tested it only on an RB951-2n. If needed I will send a supout.rif.
normis
Re: v6 rc5 released
Thu Dec 06, 2012 2:25 pm
what is the error message? does the same command work on previous versions?
paoloaga
Re: v6 rc5 released
Thu Dec 06, 2012 2:31 pm
It's a standard configuration I apply to all the routers used as a CPE (around 1200 installations). It works with all previous releases.
Through CLI, if I add the interface, it just hangs. Through WinBOX it appears an error after a while, saying that it was not possible to add the PPPoE client interface.
It happens even just adding a PPPoE-Client, selecting any interface (example: ethernet 1) without any particular other setting.
normis
Re: v6 rc5 released
Thu Dec 06, 2012 2:32 pm
It's a standard configuration I apply to all the router used as a CPE (around 1200 installations). It works with all previous releases.
looks like only hangs if you specify a password. can be added without a password. thanks for the report, will fix!
napismizpravu
Re: v6 rc5 released
Thu Dec 06, 2012 3:05 pm
again 6.0rc5
wireless package is not compatible RB433UAH + R52H, CM10
enable wireless packages > enable card R52H and CM10 (default config,reset) router KO! wireless packages CPU 97% KO RouterOS 6.0rc5
off -//- wireless packages router OK
5.21;5.22 error
downgrade 5.20
normis
Re: v6 rc5 released
Thu Dec 06, 2012 3:07 pm
what is "KO"? how dead is it? Anything on serial console? Any autosupout.rif files? Those are standard cards, they work for other people. I doubt you would be the only one to notice.
napismizpravu
Re: v6 rc5 released
Thu Dec 06, 2012 3:23 pm
CPU 100% useless, inefficient, broken RouterOS ... kernel KO?
normis
Re: v6 rc5 released
Thu Dec 06, 2012 3:24 pm
please answer my other questions
napismizpravu
Re: v6 rc5 released
Thu Dec 06, 2012 3:36 pm
via winbox to get to settings, many settings disappeared (google translator)
honzam
Re: v6 rc5 released
Thu Dec 06, 2012 3:39 pm
show image
(vlož sem obrázek co ukazuje winbox po nahrání 6.0rc5) Jinak to asi nepochopí
napismizpravu
Re: v6 rc5 released
Thu Dec 06, 2012 3:48 pm
When you turn on wireless card > image
napismizpravu
Re: v6 rc5 released
Thu Dec 06, 2012 3:53 pm
show image
no to je hrozný, když tu chtějí psát anglicky a nespokojí se s překladačem od Google
Tak mu kdyžtak napiš, že s vypnutým balíčkem wireless všechno funguje (kromě toho bezdrátu samozřejmě), a když se zapne, tak všechny karty jsou v default nastavení (a vypnutý) a po zapnutí kterýkoliv okamžitě je vidět na CPU zatížení wireless balíčku a celý routerboard je nepoužitelný. Ještě, že přes winbox jdou vypínat balíčky. ...dík
normis
Re: v6 rc5 released
Thu Dec 06, 2012 3:54 pm
1. why do you have wireless package scheduled for disable?
2. why do you have some filters applied in wireless menu of winbox?
napismizpravu
Re: v6 rc5 released
Thu Dec 06, 2012 4:08 pm
1. enable R52H error > off-on wireless packeges (off R52H card) > test card CM10 (R52H off)
2. no filters enable (It showed the winbox)
honzam
Re: v6 rc5 released
He wrote:
With disabled wirelles package all works fine. When wirelles packages is enabled - then R52Hn and cm10 are in default settings. And when one of the card is enabled then cpu goes to 100% and routerboard is unusable
Stanislav Hrncir
Re: v6 rc5 released
Thu Dec 06, 2012 5:17 pm
Tady sa začíná rozjížďat multilingvistická debata :) Oujé
wispwest
Re: v6 rc5 released
Thu Dec 06, 2012 5:32 pm
Really excited to test the new simple queues.
Had a RB/433GL running up a local tower to test on, with about 40 queues. Was running 6.0beta3. Upgraded to RC5.
Link to Mikrotik never came back, have to make site visit now, way to go Mikrotik!!
I'll post back if it just needed rebooted, or if the whole thing is bricked. This should be beta5, not RC5!
linek1980
Re: v6 rc5 released
Thu Dec 06, 2012 5:41 pm
the demo.mt.lv - yes. On my device - no. Two different versions of ROS-6.rc5?
wispwest
Re: v6 rc5 released
Thu Dec 06, 2012 6:18 pm
UPDATE:
- Reboot didn't fix
- Brought back to office and MAC-Winboxed into it, to find the interface names got changed! Therefor addresses assigned were now "unknown". Interfaces now say Eth3,Eth4,Eth5, when it should be Eth1, 2, and 3.
It's the same thing I see when a backup file is made, and restored onto another Mikrotik that has different ports. Everything gets all messed up. This was just a F/W upgrade though...
uldis
Re: v6 rc5 released
Thu Dec 06, 2012 6:36 pm
on which board does it happen?
when the wireless cards are disabled the board works fine with wireless package enabled?
After which cards enable the board goes to 100% CPU?
jcem
Re: v6 rc5 released
Thu Dec 06, 2012 6:45 pm
wispwest!
what was your previous version before upgrade? I had simular problem when upgrading from pre ROS5.20
run command
/system check-installation
and see if you get any file errors - i did and had to do netinstall
could be that you had errors before upgrade, therefore your backup is
corrupted. Compare size of file with an older backup.
Check log for error when doing system backup
I had one installation going bad when upgrading from 5.20
to 5.22on an RB800 with userman. I got file
error(/system check-installation), error in log
when backup, all packages where not shown.
Wireless package was missing, but wireless still worked.
Had to netinstall and use an older backup file
On successful installations - I have fould no errors with ROS6.0RC5
RGDS
napismizpravu
Re: v6 rc5 released
Thu Dec 06, 2012 7:06 pm
...reboot-wireless packages enable (off all card) router OK
write http://forum.mikrotik.com/viewtopic.php ... 63#p344963
tron
Re: v6 rc5 released
Thu Dec 06, 2012 7:13 pm
Zdravím Čechy a Slováky :D (Greetings to Czechs and Slovaks)
Before update with RoS v5.22 -> 6to4 tunnel worked great - ping to IPv6 gateway was OK.
After update to RoS v6.05rc -> 6to4 tunnel didn't work. Gateway was unreachable. Nothing helped (re-setting interface, deleting/adding IPs, deleting/adding route...)
I downgraded back to v5.22 and it is working again.
wispwest
Re: v6 rc5 released
Thu Dec 06, 2012 7:19 pm
wispwest!
run command
RGDS
I figured I would upgrade everything to 5.22 first, but this particular one already had 6.0beta3, so I just upgraded it from that one...
onnoossendrijver
Re: v6 rc5 released
Fri Dec 07, 2012 12:45 am
I'm still not able to install RouterOS 6rc5 on a USB stick.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
NetworkPro
Re: v6 rc5 released
Fri Dec 07, 2012 7:18 am
I have decent experience with the recent RC versions, Thank you MikroTik guys !!!
On two mipsbe I put the package from 5th December from the development page, it has RouterBOOT 3.02, if you could consult with your colleagues and let us know if we can install it on the router OR wait for the next build and install the RouterBOOT from there ?
Thanks.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
normis
Re: v6 rc5 released
Fri Dec 07, 2012 7:45 am
RouterBOOT 3.02 should also be included in the public release of RC5. It is good to install.
blingblouw
Re: v6 rc5 released
Fri Dec 07, 2012 1:05 pm
running on x86.
Cannot stop a kvm
when i stop it it just says stopping but never actually stops
Edit:
Also, when a reboot happens the tap adapters are NOT removed. and I get DUP responses when trying to ping VM
mrz
Re: v6 rc5 released
Fri Dec 07, 2012 1:40 pm
set vnc display id and connect and look at output.
Then do /kvm shut-down <kvm-name>
normis
Re: v6 rc5 released
Fri Dec 07, 2012 1:43 pm
clarify what process you used? works with Netinstall to USB
blingblouw
Re: v6 rc5 released
Fri Dec 07, 2012 1:53 pm
I did this, nothing happens the VM still continues to work. Only shutsdown if I power the VM down (in the vm go shutdown)
napismizpravu
Re: v6 rc5 install test 3
Fri Dec 07, 2012 2:46 pm
RB433UAH install number three
update 5.20 > 6.0rc5 > wireless packages CPU 100% ... cannot turn off wireless packages!, reset ...> KO! RouterOS
serial cabel > images
netinstal 6.0rc5 all packages > Kernel panic - not syncing: Attemped to kill init!
netinstall 6.0rc5 combine packages > Kernel panic....
netinstal 5.22 > install OK (bad sector 0,2% previously 0%)
winbox update 5.22 > 6.0rc5 > put the new wireless card > enable OK> restore configurations 5.22 >reboot> enable card CPU 100% wireless packages
netinstall 5.22>6.0rc5... configuration import compact all IP, IPv6, queues,...
Batman directory Comix RouterOS :D
Batmani, čerti a ještě to chce supermany, princezničky a bude routerboard jak z pohádky :lol:
normis
Re: v6 rc5 released
Fri Dec 07, 2012 2:49 pm
your wireless card is probably damaged. try to install some other card. in certain situations, enabling a defective card will result in this situation.
mrz
Re: v6 rc5 released
Fri Dec 07, 2012 3:04 pm
Tested all shutdown, reboot, start etc. Works fine if guest is RouterOS. What OS is installed on your guest?
blingblouw
Re: v6 rc5 released
Fri Dec 07, 2012 3:10 pm
Fedora 15. Runs fine on all other versions fo ROS. (5.11 - 5.20)
mrz
Re: v6 rc5 released
Fri Dec 07, 2012 3:15 pm
KVM host sends ACPI event to the guest. Try to check if your fedora accepts them.
napismizpravu
Re: v6 rc5 released
Fri Dec 07, 2012 3:18 pm
the cards work ...5.22 and now there are again 6.0rc5 work (no import config wireless 5.22)
normis
Re: v6 rc5 released
Fri Dec 07, 2012 3:19 pm
Sorry, language barrier. The card works now in rc5?
napismizpravu
Re: v6 rc5 released
Fri Dec 07, 2012 3:22 pm
yes
normis
Re: v6 rc5 released
Fri Dec 07, 2012 3:28 pm
how did you fix it?
onnoossendrijver
Re: v6 rc5 released
Fri Dec 07, 2012 4:07 pm
I use netinstall to install the routeros npk to usb stick.
Then I place the USB stick in the x86 machine where I want to run RouterOS, the following happens:
Welcome to MikroTik Router Software hard disk installation
Press Ctrl-Alt-Delete to abort
Loading drivers
Looking for harddrives.......................
FATAL ERROR: No hard disk found
Press ENTER to reboot
On RouterOS 5.x and routeros 6betaX this works perfectly, but not on routerOS 6rcX.
Tried on Intel DN2800MT and Intel D945GCLF2 motherboards (both have an Atom CPU)
crhylove
Bug Report.
Fri Dec 07, 2012 8:23 pm
I had Hide Passwords checked and it was still showing my password. Not that it mattered at the moment, my boss knows my password. This is a potentially big deal though in some environments!
crhylove
Re: v6 rc5 released
Fri Dec 07, 2012 8:33 pm
Another Bug:
In IP > Hotspot > Walled Garden IP Entry
adding a url like securedserver.isp.net doesn't work, I get the error "Error in Dst. Address - ip address expected!"
napismizpravu
Re: v6 rc5 released
Fri Dec 07, 2012 8:55 pm
proxy random error "DNS resolving failed" (5x IP DNS servers, ISP1, ISP2, 2x Google IPv4 + IPv6)
mangle Layer7 Protokols :( (5.22 better)
edit: uptime 6.0rc5 1d (5.22 1-max3d)... proxy DNS good (remove Web Proxy Access rule double clone all...the first import /IP was not successful terminal)
crhylove
Re: v6 rc5 released
Fri Dec 07, 2012 10:06 pm
Drag and drop functionality is also broken in Winbox. Trying to copy an html file into the hotspot directory. Had to right click copy, then select the past icon at the top of the File List to make it work.
hci
Long time Member
Long time Member
Re: v6 rc5 released
Sat Dec 08, 2012 12:01 am
Attempted to upgrade a RouterBOARD 951-2n for rc4 to rc5. Appears to be bricked. Solid PWR and ACT lights. Nothing else lights up. Any possible fixes besides RMA?
Chupaka
Re: v6 rc5 released
Sat Dec 08, 2012 2:34 am
Upgraded my semi-test x86 Intel router (with two 82576 + one 82574L NICs if it matters) from 5.22 to 6.0rc5 - no networking, any /interface print command ended in timeout + supout suggestion. I tried to make supout, but when NetInstalling v5, I checked 'Keep old configuration' - and as a result saw absolutely empty config with all files (including backups, f*ck!!!11oneone) erased, so I don't know how to extract supout from that router :)
p.s. in WinBox, one can change supout file name - how to do that in Terminal? "/system sup-output" doesn't have any parameters...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Re: v6 rc5 released
Sat Dec 08, 2012 10:41 am
power it with pushed button, this will load secondary bootloader and run netinstall mode
normis
Re: v6 rc5 released
Sat Dec 08, 2012 10:42 am
I don't understand - did you manage to make the file or not? Try to send to support if you have anything
Vkins
Re: v6 rc5 released
Sat Dec 08, 2012 3:57 pm
<removed>
After flashing it again it worked properly. No idea what went wrong the first time. :)
Would still love to see a more...versatile implementation of UPnP along with NAT-PMP.
ddejager
Re: v6 rc5 released
Sat Dec 08, 2012 11:42 pm
I'm using a RB2011UAS-2HnD. I upgraded from v6rc2. No problems encountered with normal routing or wireless useage.
I decided to try to use external USB storage. I've tried with two different flash storaged devices, both formated in fat format. One device is a Cruzer, Micro 2GB. The other device is a SD-USB adapter with a 512 MB SD card. Both devices work fine when plugged into my Windows 7 computer. They also work if plugged into my Android phone using a Micro USB cable. When used on either the computer or phone, the LED on the device is either on all the time or flashing (depending on the USB flash device.)
If I use the exact same cable to plug either device into the router, the active LED on the device flashes very briefly and then nothing happens and the storage is not visible on the router. It is almost acting like it is not getting sufficient power from the router, but either device uses only a very small amount of power. Windows reports the SD-USB adapter as using 100 mA and reports the Cruzer as using 200 mA.
Why won't either device work with the RB? (I've not tested the USB storage on any prior software release on this device.)
Edit: neither device shows up in the list of stores. (no USB store is listed, only the system store)
Edit2: Figured out that I needed to reboot the router before the USB storage will appear and can then be formatted.
samotoka
Re: v6 rc5 released
Sat Dec 08, 2012 11:54 pm
Did you format the usb like that
Proud owner of a RB2011UAS-2HnD-IN with ROS 6.19,
pc i586 2004 Mhz Athlon XP with ROS 3.30,
pc i586 330 Mhz Pentium II with ROS 3.30,
old pc 233 Mhz Cirix with ROS 2.9.27
ditonet
Forum Veteran
Forum Veteran
Re: v6 rc5 released
Sat Dec 08, 2012 11:56 pm
Format your USB drive using RouterOS built-in format tool.
Run Winbox, then 'System/Stores/Disks', select USB device and click 'Format Drive'.
RouterOS uses its own file system, not compatible with FAT :( .
http://wiki.mikrotik.com/wiki/Manual:St ... commands_2
HTH,
edit: Samotoka was faster than me :D
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
samotoka
Re: v6 rc5 released
Sat Dec 08, 2012 11:58 pm
pic is better for the newbie
ddejager
Re: v6 rc5 released
Sun Dec 09, 2012 12:03 am
HTH,
Thanks!
ddejager
Re: v6 rc5 released
Sun Dec 09, 2012 12:08 am
You answered my questions about USB storage so quickly...I have another question.
Again I have a RB2011UAS-2HnD board using v6rc5. I cannot get the "new" cable diagnostics to work as advertised. When I run the diagnostic for any ethernet port I get "status" and "auto-negotiation" reported back, but nothing about "cable-pairs". I've read in other postings that this only works on 5 of the 10 ports on this router (I forget if it was the gigabit or 100 mbit ports), but I cannot get it to work on any ports. I'm trying on ports that have no-link with various length cables plugged in.
Any suggestions?
ddejager
Re: v6 rc5 released
Sun Dec 09, 2012 12:16 am
HTH,
Thanks!
I think I thanked you too quickly. The devices do not show up in the /store print list. That is, no USB storage is shown as in the image by samotoka, so it is not available for formatting.
ditonet
Forum Veteran
Forum Veteran
Re: v6 rc5 released
Sun Dec 09, 2012 12:20 am
ddejager
Re: v6 rc5 released
Sun Dec 09, 2012 12:30 am
HTH,
Thanks!
OK. I figured it out. I noticed in the wiki doc a notation that the router needs to be rebooted after installing the USB storage. I rebooted and it now shows up as a USB store and I can format it. Now to use it.
napismizpravu
6.0rc5 curiosity
Sun Dec 09, 2012 9:09 pm
curiosity RB433UAH max CPU 118%
6.0rc5 uptime currently 2d (5.22 max uptime 1-3d)
kosztyua
Re: v6 rc5 released
Sun Dec 09, 2012 10:03 pm
I just spent 8 hours yesterday trying to install v6rc5 x86. I usually install routeros systems remotely, either through kvm or ipmi and so far I had no trouble with it. But not this time, when trying to install from virtual cd the installer says no cd; when booting to windows and using netinstall to install local drive, it says installed and then no boot; creating flash drive and loading that remotely through kvm, no luck; dd-ing flash files to local drive meh; etc etc . After 8 hours I accidently loaded the 5.22 iso instead of the 6 and it installed immediatly. FFS, dont remove that beta or development tag from download, this is far from any stable...
Chupaka
Re: v6 rc5 released
Sun Dec 09, 2012 10:51 pm
yes, I managed to make supout. but I cannot get it from router - no network to download, and downgrading with NetInstall to v5 wipes all configuration and files even with 'Keep old configuration' checked :) do I need to move HDD to Linux server for supout extracting? :) the only think I noticed is that in v6 there are half a dozen devices marked as 'unknown' in resources/pci, while v5 shows them all normally
blingblouw
Re: v6 rc5 released
Mon Dec 10, 2012 1:21 pm
This happens only in 6.0rc5 so far.
I even created a RouterOS KVM and it too has the same result
[admin@Office] /kvm> shut-down RouterOS_MT
[admin@Office] /kvm> shut-down FedoraNEW
command execution failed!
Their states stay like this until the router (host) is manually restarted
11 name="FedoraNEW" cpu-count=1 memory=640MiB disk-images=hda:FedoraNEW kernel="" kernel-cmdline="" initrd="" vnc-server-address=0.0.0.0 vnc-server-display=11 snapshot=no state=restarting
12 name="RouterOS_MT" cpu-count=1 memory=128MiB disk-images=hda:RouterOS kernel="" kernel-cmdline="" initrd="" vnc-server-address=0.0.0.0 vnc-server-display=0 snapshot=no state=stopping
When the host is restarted so is the KVM BUT the original tap interfaces are not removed from the interface list
hci
Long time Member
Long time Member
Re: v6 rc5 released
Mon Dec 10, 2012 7:07 pm
Pushed and held reset button, powered up. Both Pwr and Act lights come on and never go out. Ethernet never comes up.
normis
Re: v6 rc5 released
Mon Dec 10, 2012 7:16 pm
pushed and held reset button, powered up. Both Pwr and Act lights come on and never go out. Ethernet never comes up.
you have RB951-2N? did you try launching netinstall on the PC when device is in this state ?
hci
Long time Member
Long time Member
Re: v6 rc5 released
Mon Dec 10, 2012 7:22 pm
Have Netinstall up but since the 951-2n will not bring up an ethernet link I don't think it will do any good. Have tried reset button many times now. Followed directions below for reset button and netinstall.
http://wiki.mikrotik.com/wiki/Manual:Netinstall
napismizpravu
Re: v6 rc5 proxy error
Mon Dec 10, 2012 7:57 pm
proxy KO!
/ip proxy access print >> no listing
same error 5.22
http://forum.mikrotik.com/viewtopic.php ... =2#p344809
RB433UAH
5.22 max uptime 1d-3d
6.0rc5 max uptime 3d :D
send supout mikrotik?
edit:
winbox>reboot>ether off, routerboard frozen>power off-on>proxy enable, statistics access filters cleared, USB Flash confusion of names > power off-on> after start good
farzin
Re: v6 rc5 released
Tue Dec 11, 2012 5:05 pm
hi , thanks for the new release . but from 2 days ago that i have upgraded my 2 x86 routers , one of them is malfunctioning , i have described the problem of ip route cache increasing in the following topic :
http://forum.mikrotik.com/viewtopic.php?f=2&t=51127
and another buggy thing is that when i use /system reboot , it shut downs :|
estdata
Re: v6 rc5 released
Tue Dec 11, 2012 9:35 pm
how did you fix it?
hi, normis
routerboard 2011UAS-2HnD is supported for 6.0 RC5 version ?
don't forget to give me karma if got help
meschaninovn
Re: v6 rc5 released
Wed Dec 12, 2012 3:03 am
I have a problem with ssh in 6.0rc5
An error was occured when i tried to connect to remote host..
- "mepty: session finished"
janisk
Re: v6 rc5 released
Wed Dec 12, 2012 11:10 am
we will fix it, in the mean time use New Terminal and ether there command '/system ssh <ip address>'
3bs
Re: v6 rc5 released
Wed Dec 12, 2012 11:40 am
And again not work igmp proxy :?
WBR, 3bs =)
normis
Re: v6 rc5 released
Wed Dec 12, 2012 11:41 am
did it work in previous RC?
3bs
Re: v6 rc5 released
Wed Dec 12, 2012 11:43 am
no, it worked at rc2
WBR, 3bs =)
normis
Re: v6 rc5 released
Wed Dec 12, 2012 11:44 am
no, work at rc2
when you write "again", it means that it worked in rc4, but not in rc5. So to clarify - IGMP proxy is still not fixed (in any v6 version)
3bs
Re: v6 rc5 released
Wed Dec 12, 2012 1:30 pm
no, it worked in rc1 and rc2, from rc3 not work
WBR, 3bs =)
normis
Re: v6 rc5 released
Wed Dec 12, 2012 1:32 pm
I can give you a test version, please email support for the link
3bs
Re: v6 rc5 released
Wed Dec 12, 2012 1:43 pm
it would be great, bad3bs@gmail.com
thanks, but it dont include multicast package :)
WBR, 3bs =)
honzam
Re: v6 rc5 released
Wed Dec 12, 2012 3:31 pm
RB711 wireless client. Simple configuration, only NAT and DHCP. Upgrade from rc5 to rc6 then 100% cpu
No routing on client. Only console and mac-telnet works. Winbox dont work after upgrade
ddejager
Re: v6 rc5 released
Wed Dec 12, 2012 4:38 pm
Any suggestions?
Did anyone get the cable diagnostics to work on a RB2011UAS-2HnD?
mrz
Re: v6 rc5 released
Wed Dec 12, 2012 4:45 pm
Yes it works.
[admin@bumba] > /interface ethernet cable-test 0
       status: no-link
  cable-pairs: open:0,open:0,open:0,open:0
Basiley
Re: v6 rc5 released
Wed Dec 12, 2012 4:59 pm
from [relatively]small things - dreaming about NAT-T support. also better handling PMP.
uldis
Re: v6 rc5 released
Wed Dec 12, 2012 5:30 pm
please redownload the latest RouterOS v6.0rc6 and test again. Make a support output file if you still see this problem and send to support@mikrotik.com
chojrak11
Re: v6 rc5 released
Wed Dec 12, 2012 10:10 pm
Reverse Path Filtering finally implemented! Thanks Mikrotik :)
After updating a few routers to 6.0rc5 I observe "RX Drops" which weren't counted in 5.21. I'm not quite sure what would be causing it -- the routers are different hardware on different networks and different topologies (one with VLANs, the other without etc.) Everything seems to work just fine, as it did on 5.21, just the stats are alarming. But in interface details they're all zeros. I tried to log those drops trying topic "interface" but nothing appeared in the log.
See the screen below. Thanks.
tcmeggs
Re: v6 rc5 released
Thu Dec 13, 2012 3:42 am
I installed this and previously my RB433AH had no problems handling 50MB of inbound traffic. After upgrading to v6rc5 it seems to cap at around 10-12mb inbound on ether1 and starts to drop pings, cpu and memory slowly climbs.
ddejager
Re: v6 rc5 released
Thu Dec 13, 2012 11:03 pm
Yes it works.
       status: no-link
Interesting because on my router the exact same command does not produce the cable-pairs: line. Any suggestions?
paoloaga
Re: v6 rc5 released
Thu Dec 13, 2012 11:07 pm
Check that routerboot is upgraded to the latest version.
ddejager
Re: v6 rc5 released
Thu Dec 13, 2012 11:56 pm
Yes it works.
       status: no-link
I think I figured out the problem. It seems that the cable-test will not work if the ethernet switch port is a master-port for other switch ports. When the switch port is a master port, the status shows up as "link-ok" even if the physical port has no device connected. When in the link-ok state, the cable-test will not report the cable-pairs. I wonder if this is a bug?
payday
Re: v6 rc5 released
Fri Dec 14, 2012 12:08 am
Yes it works.
       status: no-link
More interesting is that it works well on one of my RB2011UAS-2HnD and it doesn't on another one :D . Both are running v6.0rc5. Only difference is that the one (that has this feature working) has bridged ports and second one (on which this feature doesn't work) has switched ports (using "master port" option).
Correction: It was on v6.0rc4. Now it doesn't work on both.
publicreg
Re: v6 rc5 released
Fri Dec 14, 2012 1:11 pm
i have problem with usb UPS on RB751U-2Hnd.
version 5.22 - works
version 6.0rc4 - not works
version 6.0rc5 - not works
[admin@rb751u] > system resource usb print
 # DEVICE VENDOR                                             NAME                                             SPEED
 0 1:1    Linux 3.3.5 ehci_hcd                               RB400 EHCI                                       480 Mbps
 1 1:2    APC                                                Back-UPS ES 700G FW:871.O2 .I USB FW:O2          1.5 Mbps
[admin@rb751u] > system ups add port=usb1
input does not match any value of port
i also tested UPS support on RB493G ROSv6_rc4 and there works without problem.
Dan
napismizpravu
Re: v6 rc5 released
Fri Dec 14, 2012 8:46 pm
RB433UAH
proxy error + profile + ? http://forum.mikrotik.com/viewtopic.php ... =1#p346441 uptime 2d 9h (can not create supout routerboard frozen)
power off-on no view "Cache Drive" ( winbox,web),winbox reboot OK
what is fixed in the current version 6.0rc6? (add NTP server packages test assembly)
napismizpravu
Re: v6 rc5 released
Mon Dec 17, 2012 1:02 am
terminal:
system resource pci pr
6.0rc5
miniPCI CM10 > AR5413 802.11abg NIC (rev: 1)
miniPCI R52H > AR5413 802.11abg NIC (rev: 1)
5.22
miniPCI TP-LINK TL-WN360G > AR5007G Wireless Network Adapter (rev: 1)
chaos miniPCI chipset?
normis
Re: v6 rc5 released
Mon Dec 17, 2012 9:56 am
terminal:
6.0rc5
5.22
the card itself isn't reporting the name of the chip, so we show generic driver that is used. it will not always match with the actual chipset.
normis
Re: v6 rc5 released
Mon Dec 17, 2012 10:31 am
If anyone is posting Winbox problems, make sure you are tesing with latest Winbox.exe from the RC5 router, and that you are using The IP ADDRESS TO CONNECT. MAC connection is not stable, and don't use it unless IP connection is not available.
napismizpravu
Re: v6 rc5 released
Mon Dec 17, 2012 9:59 pm
RB433UAH
http://forum.mikrotik.com/viewtopic.php ... =2#p346441
uptime 3d 00h 40m +-
scheduler destroy skript RouterOS ?
Parallel download (tool fetch address=) error RouterOS ?
I have deactivated script scheduled, watchdog off.
chojrak11
Re: v6 rc5 released
Tue Dec 18, 2012 4:21 am
If anyone is posting Winbox problems, make sure you are tesing with latest Winbox.exe from the RC5 router.
Thanks for the suggestion, after downloading fresh Winbox.exe (123KB) no changes to my RX Drops problem. Still the same -- all stats are zero in "RX Stats" tab of an interface, nonzero and raising in Interface List window... (so far on RB433AH, RB411AR, RB411UAHR, RB532, on VLAN, Bridge and plain Ethernet). See my previous post above for screenshot and details.
chojrak11
Re: v6 rc5 released
Wed Dec 19, 2012 5:47 am
Mikrotik support answered me that RX Drops represent packets that were received by the router, but weren't destined for it. So it's nothing new, it just started to count them properly :-)
grg
Re: v6 rc5 released
Wed Dec 19, 2012 9:21 am
I cannot find ROS v6.0rc5 tile package download on MikroTik web site for new CCR devices. I'm looking for extra package: NTP. Is this something that has to be addressed through MikroTik support?
Thanks.
doush
Long time Member
Long time Member
Re: v6 rc5 released
Wed Dec 19, 2012 4:55 pm
Did you receive the CCR ?
grg
Re: v6 rc5 released
Wed Dec 19, 2012 5:19 pm
Yes. :)
doush
Long time Member
Long time Member
Re: v6 rc5 released
Wed Dec 19, 2012 5:44 pm
Lucky you ! Whats the version on it ?
honzam
Re: v6 rc5 released
Wed Dec 19, 2012 7:17 pm
Yes. :)
On development site is 6.0rc6 for TILE
grg
Re: v6 rc5 released
Wed Dec 19, 2012 9:53 pm
Device: CCR1036-12G-4S
Software: RouterOs v6.0rc5
grg
Re: v6 rc5 released
Wed Dec 19, 2012 10:04 pm
Yes. :)
This development site you are talking about, is it for "selected" people only? I don't think I have seen such before.
honzam
Re: v6 rc5 released
Wed Dec 19, 2012 11:03 pm
Write support@mikrotik.com to access pre-release version http://www.mikrotik.com/download/share/ ... 6.0rc6.npk
MT support - CCR is already at end users. Put the download link on main page (rc5 or rc6)
napismizpravu
Re: v6 rc5 released
Thu Dec 20, 2012 3:11 am
RB433UAH
same problem (script scheduled deactivated) uptime 2d 4h proxy, profile info KO
metarouter, samba, NAT work OK
again error winbox reboot > routerboard frozen> power off-on > working
I use a proxy to block ads webpages.
Nick Kett
Re: v6 rc5 released
Fri Dec 21, 2012 6:55 am
upgraded from 5.7 directly to 6rc5 on a RB1100AHx2.
Ethernet1 (first physical port) went missing from my configuration, ie was not to be seen in winbox (lucky I was connected via a different port)
The port was configuered as a slave on a bonding interface.. it was missing there to and could not be seen to re-select.
Downgraded back to 5.22... like "magic" ethernet port was visiable again.
Can send rif file if wanted .
What email address?
Users browsing this forum: Bing [Bot], fusa, maximo, MSN [Bot] and 93 guests
