MUM Europe 2020
planetcaravan
RB751G-2HnD without external antenna
Thu Dec 06, 2012 9:06 pm
Hi there,
I'm using an RB751G-2HnD without an external antenna connected.
Is it dangerous?
ohara
Odp: RB751G-2HnD without external antenna
Thu Dec 06, 2012 9:19 pm
It's not as long as you use default wireless config. It has built in antennas.
planetcaravan
Re: RB751G-2HnD without external antenna
Thu Dec 06, 2012 10:24 pm
What if I use "manual tx-power?"
ohara
Thu Dec 06, 2012 10:40 pm
That's not a problem, but don't change the tx-power to higher that the default card rates. Uldis once said on a MUM session that tx-power is only used to decrease the value and not to increase it. What you certainly should be careful with is tx-chains setup and antenna mode in the 'HT' tab. That particular topic is very long, but it covers your question in much detail:
http://forum.mikrotik.com/viewtopic.php ... na#p300771
normis
Fri Dec 07, 2012 10:52 am
this is true, what Uldis said
Users browsing this forum: No registered users and 100 guests
