samir494
Parent Proxy for hotspot user
Tue Dec 11, 2012 7:42 am
i cannot use internet from hotspot , i am able to login in hotspot
any one can guide for the same?
Mistry Samir
Unique and Different
India
9920670022
Give me more Karma
aacable
Re: Parent Proxy for hotspot user
Tue Dec 11, 2012 12:08 pm
I see no issue while looking at the diagram you posted.
What problem you are facing in the current scenario ?
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
samir494
Tue Dec 11, 2012 1:37 pm
thanks,
i am not access websites, if i used same proxy in laptop than only i can open web sites
i dont want to use proxy in laptop ,
so kindly guide to setup the same in mikrotik
Mistry Samir
India
9920670022
Give me more Karma
aacable
Wed Dec 12, 2012 5:40 am
Have you configured Transparent proxy ,
I don't remember exactly but you have to do it using squid.conf 'transparent' directive and some iptables rules.
check this article, it may help you?
http://aacable.wordpress.com/2011/08/08 ... ver-guide/
_____________
Regard's
Syed Jahanzaib
samir494
Wed Dec 12, 2012 9:53 am
thanks,
i did some iptable rules & NAT , i see error as below snap
Mistry Samir
India
9920670022
Give me more Karma
samir494
Fri Dec 28, 2012 6:45 am
is anybody resolved it?
Mistry Samir
India
9920670022
Give me more Karma
c0d3rSh3ll
Long time Member
Long time Member
Sun Dec 30, 2012 2:32 am
try this
ip fire nat
add action=dst-nat chain=dstnat comment="proxy access" disabled=no dst-port=80 protocol=tcp to-addresses=10.10.10.1 to-ports=8080
or configure your server-profile from hotspot (http proxy and http proxy port)
nothing
samir494
Mon Dec 31, 2012 7:20 am
hi,
its still same
Untitled.png [ 43.93 KiB ]
Mistry Samir
India
9920670022
Give me more Karma
samir494
Mon Dec 31, 2012 7:21 am
hi,
its still remain the same, no access to internet as attahched snap
Mistry Samir
India
9920670022
Give me more Karma
Stillhard
Mon Dec 31, 2012 8:19 am
Check your squid's cache/access log, i guess there's your clue (perhaps error with acl permission)
samir494
Tue Jan 15, 2013 12:12 pm
hi all,
is there anyone who solved this & working
Mistry Samir
India
9920670022
Give me more Karma
sergejs
Tue Jan 15, 2013 3:34 pm
Configure HotSpot parent proxy at
 /ip hotspot profile http-proxy=
samir494
Wed Jan 16, 2013 7:52 am
Dear,
its still no working
snap is attached
Mistry Samir
India
9920670022
Give me more Karma
samir494
Wed Jan 16, 2013 9:33 am
Thanks Sergejs
it works afterall
now i am able to surf normal sites but not HTTPS site like GMAIL.COM
what to do now ?
let me know
Mistry Samir
India
9920670022
Give me more Karma
sergejs
Wed Jan 16, 2013 3:09 pm
http-proxy should redirect only http requests. Do you have any problems with HTTPs, when http-proxy is disabled?
samir494
Sat Jan 19, 2013 5:58 am
thanks dear,
when i disable http-proxy in Mikrotik & use proxy-seeting in laptop i can access https sites also,
when i enable http-proxy in Mikrotik & disable proxy-seeting in laptop i can only access http sites ,, no https
kindly help me bit more
Mistry Samir
India
9920670022
Give me more Karma
samir494
Mon Jan 28, 2013 2:20 pm
is there any way to access https site with http-proxy enabled ?
Mistry Samir
India
9920670022
Give me more Karma
saintofinternet
Forum Veteran
Forum Veteran
Fri Feb 15, 2013 11:59 am
did you get any update on your problem?
-sid
by professionals, for professionals....
Don't forget to give KARMA!!!
samir494
Tue Feb 26, 2013 2:07 pm
-sid
not yet, i still using proxy for same
Mistry Samir
India
9920670022
Give me more Karma
ener
Wed May 15, 2013 5:13 am
hello maybe i can help you. i have encountered the same problem.. maybe we can do teamviewer and maybe i can remote config it for.. maybe i can fix..
samir494
Wed May 22, 2013 3:23 pm
ok sure ,, when is it possible for you
Mistry Samir
India
9920670022
Give me more Karma
ener
Fri May 31, 2013 3:48 pm
input ur proxy IP in NAT
Googler
Wed Jul 10, 2013 8:45 am
Did you manage to solve problem?
if so, how?
thank you
Users browsing this forum: blackhiden, Dante91, ericp, kams19, mseidler and 151 guests
