memoit
Accessing Link Before Mikrotik Router
Tue Dec 18, 2012 6:48 pm
Hi Dears
i have Mikrotik RB 1100 AH with real ip x.x.x.x
& it provide my network With LAN IP 10.5.10.1/24
& it's connected with the ISP through Data Link (Rocket M5 from UBNT) i want to access the Data link from my LAN network
without Disconnection the Ethernet cable from mikrotik
pls see the attached picture
Dobby
Re: Accessing Link Before Mikrotik Router
Sun Dec 23, 2012 8:04 pm
Deleted because not related.
adairw
Sun Dec 23, 2012 10:31 pm
I would create a vlan on the MikroTik wan interface and bridge it with your lan or put its own subnet on it so its routable. On the rocket connected to the mtk create a vlan on the lan interface that matches what you set on the mtk. Set the vlan as the management vlan on that radio.
What I am unsure about is the best way to carry that vlan across the wireless and to the other side. I know you would build a vlan on the wlan interface and set it as management but unsure how exactly to setup the bridge between the lan of one and the wlan of the other.
If I get around a radio I can play with I'll see exactly what needs too happen.
But basically the wan traffic will flow untagged between the two lan ports of the rockets and you'll have a tagged management vlan for management. Be sure to increase the mtu on the two rockets to allow passing the vlan.
Sent from my Nexus 7 using Tapatalk 2
Users browsing this forum: Bing [Bot], px48051rqs, sindy and 107 guests
