microtek
Re: Wireless disconnected, group key exchange timeout
Sat Jun 23, 2018 1:43 am
Very nice information. Thank you for sharing this.
Resnais
Mon Jun 25, 2018 9:03 pm
Regarding the group key interval 1min- it will cost you some mobile device battery power if youre into u-apsd wmm + no_keep_alive_frames thing.
No more last activities on wireless clients like (80+sec):
Ill try it with 2minutes group key interval and respond back.
samsung172
Tue Jun 26, 2018 1:20 am
this is a old issue. its 99% sure due to bad signal.
Kerbia
Tue Jun 26, 2018 3:34 am
Do you have the 6.42.4 running by now?
nkourtzis
Tue Jun 26, 2018 12:38 pm
I am also seeing this problem since a few days ago, with a MT map which connects as a WDS repeater to an RB951G, which is a repeater (non-WDS) of an ISP router. It works perfectly for maybe an hour at a time and then the map disconnects and starts logging these "key exchange timeout" messages..
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
gaborka
Tue Dec 25, 2018 6:39 pm
From changelog:
Channel
Installed Version 6.43.8
Latest Version 6.43.8
What's new in 6.43.8 (2018-Dec-21 07:10):
MAJOR CHANGES IN v6.43.8:
!) telnet - do not allow to set "tracefile" parameter;
Changes in this release:
*) bridge - fixed IPv6 link-local address generation when auto-mac=yes;
*) capsman - fixed "group-key-update" parameter not using correct units;
*) crs3xx - improved data transmission between 10G and 1G ports;
*) console - properly remove system note after configuration reset;
I set the group key update interval back to 1 hour. All connections seems to be stable (20+ minutes now).
gutekpl
Sun Mar 31, 2019 3:57 pm
I don;t think so. It's currently affecting my MiBOX which lies around 50cm from cAP AC and has full signal strength.
Earlier had this for random devices on random times. Changed 05min to 1h now, will see. using CAPsMAN on 6.44.0
Users browsing this forum: No registered users and 18 guests
