MUM Europe 2020
xMikes04
RB1100AHx2
Thu Jan 03, 2013 10:11 am
Our company used to have Drytek router and now we switched to RB1100
-ISP inbound spd is 10/10Mbps
-Network contains around 60PCs.
With Drytek router there was aprox. 6Mbps up/down on each computer bud when we switched to RB connection speed drops to 1/1Mbps.. any ideas? :?
Im new to this so if u wanna know some more info ill provide it.
Thanks Tom
wulfgard
Re: RB1100AHx2
Thu Jan 03, 2013 2:12 pm
Hello
check link speed and duplex
thierry
System and Network Engineer
Mikrotik Trainer - MTCNA MTCRE
Official French Mikrotik Distributor
isteedman
Re: RB1100AHx2
Thu Jan 03, 2013 6:16 pm
Please post your configuration and a basic network layout. (switches, ect.) also, what type of internet connection is it?
Ian Steedman
xMikes04
Re: RB1100AHx2
Fri Jan 04, 2013 1:07 pm
Link speed is good Mikrotik shows on ping speed 9.1Mbps (towards google) so its ok bud that is speed in eth1(WAN), eth2 goes to switch (D-Link 1Gb switch dunno exact name.... its "stupid" switch no managment there) and when i connect NTB it shows 1Mbps/1Mbps :? and its problem in whole network.
isteedman: what ecactly u wanna know that config?
# ADDRESS NETWORK INTERFACE
0 192.168.5.1/24 192.168.5.0 LAN - ETH2
1 195.250.xxx.xxx/29 195.250.xxx.xxx WAN - ETH1
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 dhcp_in... LAN - ETH3 bb_dhcp_lan_pool 3d
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 195.250.xxx.xxx 1
1 ADC 192.168.5.0/24 192.168.5.1 LAN - ETH2 0
2 ADC 195.250.xxx.x/29 195.250.xxx.x WAN - ETH1 0
is that enough? Its etnernet based connection from optic fibre
wulfgard
Re: RB1100AHx2
Fri Jan 04, 2013 2:46 pm
verify speed and duplex to local switch
this sounds like half duplex on one side
can you connect a computer direct to RB without switch and test
xMikes04
Re: RB1100AHx2
Fri Jan 04, 2013 3:37 pm
wulfgard: ur probably right sir... In Interface status under rate is check button "Full Duplex" which is unchecked... how is this possible? And how to fix this?
wulfgard
Re: RB1100AHx2
Fri Jan 04, 2013 3:46 pm
try to enforce on RB side
check speed 100 or 1000 + full duplex and uncheck autoneg
xMikes04
Re: RB1100AHx2
Tue Jan 08, 2013 12:25 pm
wulfgard: Perfect that was the problem!!
Many thanks for all!!
wulfgard
Re: RB1100AHx2
Tue Jan 08, 2013 12:35 pm
you are welcome
thanks
Users browsing this forum: Google [Bot], Issarin and 29 guests
