spike232
IPSec between 3 sites
Wed Jan 09, 2013 9:41 pm
I have 3 sites A, B and C each with a Mikrotik Router
I have working IPSec VPNs between A => B and B => C
Is it possible to send traffic from A to C without creating a new tunnel directly between them eg route thought B?
tomaskir
Trainer
Trainer
Re: IPSec between 3 sites
Wed Jan 09, 2013 11:55 pm
Use a GRE tunnel with IPSec in transport mode.
Then use OSPF for routing, and you can route inside of the VPN from A to C.
If you are using IPSec in tunnel mode, you have to create another tunnel between A and C.
andriys
Thu Jan 10, 2013 12:41 pm
Yep, it is possible. Even with pure policy-based IPec setup. Just extend your IPsec policies. Send here your current IPsec config if you'd like someone to try to assist you with the configuration.
spike232
Thu Jan 10, 2013 9:37 pm
This is what I have so far... not really sure what I need to add to B??
ros code
#Router A
/ip ipsec peer
add address=B.B.B.B/32 dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha1 lifetime=8h secret=?????
/ip ipsec policy
#A->B
add dst-address=172.16.0.0/16 level=unique proposal=default sa-dst-address=B.B.B.B sa-src-address=A.A.A.A src-address=10.120.5.0/24 tunnel=yes
#A->B->C??
add dst-address=10.5.3.0/24 level=unique proposal=default sa-dst-address=B.B.B.B sa-src-address=A.A.A.A src-address=10.120.5.0/24 tunnel=yes
ros code
#Router B
/ip ipsec peer
add address=A.A.A.A/32 dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha1 lifetime=8h secret=?????
add address=C.C.C.C/32 dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha1 lifetime=8h secret=?????
/ip ipsec policy
#B->A
add dst-address=10.120.5.0/24 level=unique proposal=default sa-dst-address=A.A.A.A sa-src-address=B.B.B.B src-address=172.16.0.0/16 tunnel=yes
#B->C
add dst-address=10.5.3.0/24 level=unique proposal=default sa-dst-address=C.C.C.C sa-src-address=B.B.B.B src-address=172.16.0.0/16 tunnel=yes
ros code
#Router C
/ip ipsec peer
/ip ipsec policy
#C->B
add dst-address=172.16.0.0/16 level=unique proposal=default sa-dst-address=B.B.B.B sa-src-address=C.C.C.C src-address=10.5.3.0/24 tunnel=yes
#C->B->A??
add dst-address=10.120.5.0/24 level=unique proposal=default sa-dst-address=B.B.B.B sa-src-address=C.C.C.C src-address=10.5.3.0/24 tunnel=yes
andriys
Fri Jan 11, 2013 10:29 am
The rules you've added to A and C seem to be correct. On B you need to add the following:
ros code
add dst-address=10.120.5.0/24 level=unique proposal=default sa-dst-address=A.A.A.A sa-src-address=B.B.B.B src-address=10.5.3.0/24 tunnel=yes
add dst-address=10.5.3.0/24 level=unique proposal=default sa-dst-address=C.C.C.C sa-src-address=B.B.B.B src-address=10.120.5.0/24 tunnel=yes
spike232
Sat Jan 12, 2013 12:04 am
Thanks! I will give it a try
