I’m trying to setup a mikrotik router board 532, I can connect the router board via serial port after that it says starting services and then hang’s up, I have tried to reset the configuration but still having the same problem. It doesn’t give me access to the Ethernet port, I cannot connect thru the Ethernet port, so is there any possible solution to get this issued solved
RouterBOOT booter 1.5
RouterBoard 532
CPU frequency: 264 MHz
Memory size: 32 MB
Press any key within 1 seconds to enter setup.
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
