estdata
v6 rc7 released
Fri Jan 18, 2013 8:59 pm
What's new in 6.0rc7 (2013-Jan-18 13:04):
*) dhcp relay - possibility to add relay agent information option;
*) lcd - options current-interface, time-interval and all-interface-mode
no longer get reset after reboot;
*) fix reboot in virtualized enviroment;
*) lcd - improve slideshow screen;
*) console - file print now shows file size as small number with suffix;
*) dhcp v4 - fix problem when sometimes client or server failed to send packets
most likely it happened on vlan interfaces;
*) ipv6 - added setting to disable forwarding;
*) added "/ip neighbor discovery settings" menu with "default=yes/no" setting;
don't forget to give me karma if got help
samsung172
Re: V6 RC 7.0 released
Fri Jan 18, 2013 10:02 pm
No fix to vrf? (not tested)
estdata
Fri Jan 18, 2013 10:57 pm
I think that this version has been tested
infused
Fri Jan 18, 2013 11:33 pm
Now on to RC8
slech
Long time Member
Long time Member
Fri Jan 18, 2013 11:42 pm
/interface print
ether1-wan-primary ether 1500 1526 00:0C:42:41:6A:85
ether2-lan ether 1500 1522 1522 00:0C:42:41:6A:86
/ip neighbor print
0 ether2... 192.168.2.1 00:0C:42:41:6A:86 MikroTik 6.0rc7 RB433UAH
1 ether1... 99.99.99.99 00:0C:42:41:6A:85 MikroTik 6.0rc7 RB433UAH
Why it show me itself, or this is normal ?
On demo2.mt.lv all is ok.
On demo.mt.lv is double.
sorry for my english
payday
Sat Jan 19, 2013 12:26 am
I downloaded new version of Winbox.exe from router and saved it on my desktop (as I always do) and after running Winbox, files listed below were created on my desktop:
advtool.crc, advtool.dll, dhcp.crc, dhcp.dll, hotspot.crc, hotspot.dll, mpls.crc, mpls.dll, ppp.crc, ppp.dll, roteros.crc, roteros.dll, roting4.crc, roting4.dll, secure.crc, secure.dll, system.crc, system.dll, wlan4.crc, wlan4.dll.
After I delete these files, Winbox creates files on desktop every time I start it.
lambert
Long time Member
Long time Member
Sat Jan 19, 2013 1:16 am
I think it is normal if the mikrotik is the only one doing discovery protocol on the interface.
If there are other devices participating in discover, I don't see the current RouterOS device listed on the interface. It's been that way from 5.x for me anyway.
marcin21
Sat Jan 19, 2013 3:40 am
I discovered that after upgrade from 5.18,5.20,5.22 to 6.0rc7
interfaces/bridges just dissapears. So far i've upgraded four x86 units
and three of them got up without bridges at all. Therefore Ip adresses
are binded to "unknown" interface. Mess...
First I thought that it was only 5.22>6,0rc7 path that introduces a problem.
But, few minutes ago I encountered the same situation upgrading 5.18>6.0rc7.
TonyJr
Sat Jan 19, 2013 4:21 am
it is weekend wait for the official forum post on monday, otherwise this thread will be ignored. they have done a good job this time :) please. patience!
TerAnYu
Sat Jan 19, 2013 10:23 am
After installing the problems started:
1. Decreased the frequency to 100 MHz
2. Constant rebooting and not revert back, if not to use RS232
RouterBOOT booter 3.02
RouterBoard 450G
CPU frequency: 100 MHz
  Memory size: 256 MiB
    NAND size: 512 MiB
RouterBoard 450G
CPU frequency: 680 MHz
    NAND size: 512 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
MikroTik 6.0rc7
MikroTik Login: Oops[#1]:
Cpu 0
$ 0   : 00000000 00000001 00000000 fffffffe
$ 4   : cec3d500 00000000 00000000 c02d2410
$ 8   : 0000003c c02391d4 0000cc34 cd0acb40
$12   : cdd7f42c 00000003 ffffffff 000086dd
$16   : cdc8f540 cec3d500 00000000 00000000
$20   : c0391fcc 00000001 00000000 00000000
$24   : 0000000c 134f4c7a
$28   : cf6d0000 cf6d1c58 cec3d500 c029cc50
Hi    : 00000064
Lo    : 000006ca
epc   : cf59ca68 udpv6_queue_rcv_skb+0x5c/0x77c [ipv6@0xcf580000]
    Not tainted
ra    : c029cc50 release_sock+0x94/0x108
Status: 1000d203    KERNEL EXL IE
Cause : 00800008
BadVA : 00000030
PrId  : 00019374 (MIPS 24Kc)
Process net (pid: 219, threadinfo=cf6d0000, task=cf5fde30, tls=7766d770)
Stack : cdc8f180 cd25c050 cd25c050 00000000 cec3d500 cdc8f540 c0420000 c029cc50
        000000a4 ffffffff cec3d70c cec3d70c 00000000 cec3d70c 00000000 cf6d1ee0
        cdfafea0 00000000 00000074 cf59df00 0000007c c02deb00 cf6d1efc cf6d1d30
        00000008 00000001 00000000 00000000 cf6d1cd8 cdfafea0 00000000 00000000
        0000000c 00000000 00000000 00001104 00000000 ff020000 00000000 00000000
Call Trace:
[<cf59ca68>] udpv6_queue_rcv_skb+0x5c/0x77c [ipv6@0xcf580000]
[<c029cc50>] release_sock+0x94/0x108
[<cf59df00>] udpv6_sendmsg+0x80c/0x980 [ipv6@0xcf580000]
[<c0298e34>] sock_sendmsg+0x84/0x9c
[<c029b424>] sys_sendto+0xcc/0x10c
[<c010dd10>] stack_done+0x20/0x44
Code: 8e020048  2403fffe  00621024 <8c420030> 30420004  14400008  32420004  02202021  00002821
---[ end trace df72217082fc4575 ]---
Kernel panic - not syncing: Fatal exception in interrupt
panicSaver: dumping panic to flash
flash: erase f
flash: prg f
spi_program_sector 0000000f
Rebooting in 1 seconds..
RouterBoard 450G
    NAND size: 512 MiB
Starting...
MikroTik 6.0rc7
Cpu 0
$ 4   : ceca2fc0 00000000 00000000 c02d2410
$ 8   : 0000003c c02391d4 000037c2 cd6a7660
$12   : ffffffff 00000003 ffffffff 000086dd
$16   : cf7bf6c0 ceca2fc0 00000000 00000000
$24   : 00000000 00000000
$28   : cf6d2000 cf6d3c58 ceca2fc0 c029cc50
Hi    : 00000020
Lo    : 69a36992
    Not tainted
Cause : 00800008
BadVA : 00000030
Process net (pid: 219, threadinfo=cf6d2000, task=cf5fa280, tls=770d7770)
Stack : cdfba3c0 cf7e9a50 cf7e9a50 00000000 ceca2fc0 cf7bf6c0 c0420000 c029cc50
        0000009f ffffffff ceca31cc ceca31cc 00000000 ceca31cc 00000000 cf6d3ee0
        cdfcd680 00000000 0000006f cf59df00 00000077 c02deb00 cf6d3efc cf6d3d30
        00000008 00000001 00000000 00000000 cf6d3cd8 cdfcd680 00000000 00000000
        00000004 00000000 00000000 00001104 00000000 ff020000 00000000 00000000
Call Trace:
---[ end trace 14a0ee4ef2829e9f ]---
flash: erase f
flash: prg f
RouterBoard 450G
    NAND size: 512 MiB
Starting...
MikroTik 6.0rc7
MikroTik Login:
I had to return to rc6.
ROS: 6.[latest]
tkgit
Re: v6 rc7 released
Sat Jan 19, 2013 2:05 pm
can mikrotik team add find & replace feature in winbox?
napismizpravu
6.0rc7
Sat Jan 19, 2013 3:30 pm
RB433UAH
RouterOS + enable MetaROUTER >>> random crash RouterOS
docmarius
Re: v6 rc7 released
Sat Jan 19, 2013 8:00 pm
and routing marks don't work... reverted to rc6 -> all ok.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
mattsawatzky
Re: 6.0rc7
Mon Jan 21, 2013 7:46 am
RB433UAH
Had this back in RC5 at least. Using a 750. Had to manually go out and recycle the router.
normis
Mon Jan 21, 2013 12:24 pm
we checked two systems, x86. they both upgraded fine from v5.18 and v5.22 and kept all their bridge configuration. could you send us your complete config to support? maybe some other problem caused this. supout.rif files from v5 and v6 would be appreciated
hci
Long time Member
Long time Member
Mon Jan 21, 2013 5:41 pm
Upgraded some MIPSBE and PPC based routers with a few bridge interfaces and did encounter any issues. Perhaps this is just a x86 issue? Anyone else see this?
blingblouw
Re: v6 rc7 released
Mon Jan 21, 2013 8:37 pm
My bridges were fine after upgrading to rc7 but I am seeing lots of random reboots - think it has to do with KVM, sent support a mail
tetecko
Re: v6 rc7 released
Mon Jan 21, 2013 11:20 pm
how exactly is working this feature, how can I get my IPv6 address on box? I set up ipv6/setting/forward: no , but how I can get my IPv6 address now?
normis
Tue Jan 22, 2013 1:12 pm
What version of Windows are you using? What other software is running? Maybe some antivirus programs?
payday
Tue Jan 22, 2013 7:31 pm
It's funny, but I have just checked once again and it does not happen anymore. Did You fixed it telepathically? ;)
I guess that Winbox couldn't access some path and downloaded its files to current directory.
Anyway, everything is OK now, thank You. :)
doush
Long time Member
Long time Member
Re: v6 rc7 released
Tue Jan 22, 2013 7:38 pm
normis,
Why you dont make this post a universal sticky in all forum so people can see easily and test more ?
tetecko
Re: v6 rc7 released
Tue Jan 22, 2013 7:39 pm
I answer my self, its working, but you don't have chance see it :) there is nothing in ipv6/address nor in ipv6/routes but you get and adress and google is pingable .. :) miracle :)))
krakenant
Re: v6 rc7 released
Tue Jan 22, 2013 8:07 pm
I try not to bust your chops too much on beta and release candidate bugs, but the bugs I have come across with the CloudCore Router and DHCP are borderline reprehensible. The config we are using works everywhere on every piece of equipment on 5.22. On the latest RC7, DHCP doesn't work with a src address set, last night when I went from a pre-release RC7 to the officially released RC7, I had to wipe the configuration from the device and reconfigure it to get the DHCP server working, when rebooting the CCR today the DHCP failed to work until I disabled and and enabled it. Aside from that the CCR produced 200ms pings on a link that is normally 50ms, and only passed 100Mbps on a hotspot network that usually passes 160Mbps plus of traffic (edit: figured this one out, the firewall code isn't optimized to use all of the cores, not sure what the point in letting it go out was given the firewall is generally one of the biggest consumers of the CPU and a fix is at least two weeks out).
Needless to say we are back on an x86 box on 5.22 this morning. I submitted a ticket this morning as well with the above issues. Posting this as more of a heads up for other users.
andrijco
Re: v6 rc7 released
Wed Jan 23, 2013 12:31 pm
routeros rc7 tilegx
when 3 fullview bgp instances are processed simultaneosly
router crashes and rebooted
but when i enable one instance after another giving each of them time proccess routes it works great until bgp flap
is this known issue ?
or i need to submit support.rif ?
same problem i noticed on rc4 x86 platform
marcin21
Re: v6 rc7 released
Wed Jan 23, 2013 12:52 pm
Regarding these dissapearing bridges, I did some further investigations, and what I see,
is that those bridges don't dissapear but after full boot up of my
Intel D945G sejt, bridge appears after about 2 minutes! First I thought maybe because
i had admin managed mac adress and automac=no set on this bridge. But it's not the issue.
Time after boot up needed to bridge to appear made my hardwre watchdog rebooted
router. on 5.x problem doesn't exist.
As a proof I did manage to log into router "without" bridge1 and added it manually, then after
some time ( about 2min ) the bridge appears again so I've got two bridges called
"bridge1" and afaik it shouldn't be possible.
normis
Re: v6 rc7 released
Wed Jan 23, 2013 1:02 pm
You are using MAC address to connect. This is a very bad idea. Items will appear slowly, and this is not a bug. MAC address is for debug/extreme uses. Not for normal configuration.
Chupaka
Re: v6 rc7 released
Wed Jan 23, 2013 2:29 pm
identical interface names are not a bug?.. Normis, are you kidding? :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Re: v6 rc7 released
Wed Jan 23, 2013 2:41 pm
Connect to IP and then check. From MAC connection you can expect all kinds of wonders if the connection is slow.
fourroses
Re: v6 rc7 released
Wed Jan 23, 2013 5:08 pm
Same here on D645G SEJT, and I am not connected via winbox - I am on board directly, with kbd and LCD.
paoloaga
Re: v6 rc7 released
Wed Jan 23, 2013 8:39 pm
On RB951-2n (but I suppose it affects all the other routerboards) there is a problem setting the /ip dns cache-size parameter:
> /ip dns set cache-size=
CacheSize ::= Num[KiB]
Num ::= 512..4294967295 (integer number)
/ip dns set cache-size=2048KiB
value of cache-size contains invalid trailing characters
/ip dns export
# jan/02/1970 00:10:02 by RouterOS 6.0rc7
# software id = ITFF-9NIU
set allow-remote-requests=yes cache-size=2048000KiB max-udp-packet-size=512
/ip dns export verbose
# jan/02/1970 00:11:06 by RouterOS 6.0rc7
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 \
query-server-timeout=2s query-total-timeout=10s servers=""
I hope it's clear enough.
Chupaka
Re: v6 rc7 released
Wed Jan 23, 2013 10:33 pm
it's as it was designed.
you set this value as a number in kibibytes, you shouldn't add 'KiB'
'k', 'M', etc. are standard Terminal suffixes, they just add necessary number of zeroes (like in Queues, you set max-limit in bits per second as '1000000', '1000k' or '1M', but not '1000kbps' - that's wrong)
paoloaga
Re: v6 rc7 released
Wed Jan 23, 2013 11:57 pm
So why "/ip dns export verbose" outputs the following?
# jan/23/2013 22:54:44 by RouterOS 6.0rc7
# software id = 1FXC-EL87
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 query-server-timeout=2s query-total-timeout=10s servers=x.x.x.x,y.y.y.y
If you feed the same code on 6.0rc7 it won't be accepted.
Chupaka
Re: v6 rc7 released
Thu Jan 24, 2013 2:35 pm
I see...
at least rc4 accepts "set cache-size=2048KiB" format - so it was broken somewhere later. rc8 says 'invalid trailing characters' too
SoKaR
Re: v6 rc7 released
Thu Jan 24, 2013 4:33 pm
L2TP-Client default-encryption is crashing the Router. First i tried RC7 now RC6 but same result.
krakenant
Re: v6 rc7 released
Thu Jan 24, 2013 4:56 pm
Duplicate or delayed bridges would explain some of the DHCP server issues I ran into.
nz_monkey
Re: v6 rc7 released
Thu Jan 24, 2013 9:58 pm
routeros rc7 tilegx
This is due to the current routing implementation being single threaded.
A new routing engine is meant to be coming soon that will resolve this.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
LookinGooder
Re: v6 rc7 released
Thu Jan 24, 2013 10:46 pm
Little bug on RB751G with 6rc7:
In Winbox (Windows7x64):
-open "Files"
-select any file in window "File list"
-press button "copy"
-then move mouse cursor to my desktop
-right click, select "paste"
-the selected file is copied to the desktop.
Then if I move mouse cursor to the window "File list" again and try to repeat the operation - nothing happened.
Solved by closing and re-opening the "File List" or copy-paste something from/to the desktop.
P.S. On WinXP this causes error message: "Cannot read from the source file or disk".
wispwest
Re: v6 rc7 released
Fri Jan 25, 2013 6:16 pm
RC7 is STILL broke!!! RB1100AH locks up when logging into it. Same problem with my 433AH I replaced it with. CPU was only 20%. Was fine for one day. Then when we log in to change queues or firewall rules, it locks up and reboots.
LOG = Router rebooted from improper shutdown
SUPOUT = Can't create one because it locks up before it makes it file
DOWNGRADE BACK TO 5.22 = Fixes the lockup problem
el berto
Re: v6 rc7 released
Fri Jan 25, 2013 7:15 pm
Where is ppp-client menu gone?
mik0s
Re: v6 rc7 released
Fri Jan 25, 2013 7:35 pm
Troubles with v6 rc7 and Cloud Core. Need help http://forum.mikrotik.com/viewtopic.php?f=1&t=68771
apteixeira
Trainer
Trainer
Re: v6 rc7 released
Fri Jan 25, 2013 7:42 pm
Hello.
I am having problems with v6 rc7.
This is the second time that the router lost connectivity.
I can only access using MAC from another router with the same version and when I try to ping any ip this is the result:
132 (No buffer space available)
Has anyone experienced this issue?
Bye.
wispwest
Re: v6 rc7 released
Sat Jan 26, 2013 4:15 am
ANOTHER RB100AH just locked up when I was logging in to change the speed on a simple queue. 2hr drive up to a mountain tower. NOT COOL MIKROTIK!!!!!
I know its my fault for testing beta, but this is RC7 shouldn't it be at least somewhat stable?!?!? Really getting tired of this, this is the 3rd router now doing the same thing.
payday
Re: v6 rc7 released
Sun Jan 27, 2013 3:33 am
"I know its my fault for testing beta" + "NOT COOL MIKROTIK!!!!!" = You are funny. :)
BTW: Watchdog didn't do it's job?
wispwest
Re: v6 rc7 released
Sun Jan 27, 2013 3:53 am
I would enable watchdog if I could log into long enough before it locks up!!!!!!
ste
AW: v6 rc7 released
Sun Jan 27, 2013 8:05 am
You missed a "!" ;-))
wispwest
Re: AW: v6 rc7 released
Sun Jan 27, 2013 8:12 pm
RC7 not SOMEWHAT stable!!!!!!!!!!!
nz_monkey
Re: v6 rc7 released
Sun Jan 27, 2013 10:09 pm
This conversion should help when dealing with RouterOS:
Beta = Alpha
RC though x.16 = Beta
.16 and higher = Stable
I never deploy a new RouterOS release unless I absolutely have to, and always test the features I use on VM's before deploying it.
paoloaga
Re: v6 rc7 released
Mon Jan 28, 2013 3:18 am
[admin@demo.mt.lv] > /ip dns export
# jan/28/2013 03:18:47 by RouterOS 6.0rc8
# software id = 0TLY-48W5
set cache-size=3048KiB max-udp-packet-size=512 servers=10.10.2.2
[admin@demo.mt.lv] > /ip dns set cache-size=3048KiB
Yes, still not fixed.
How should I manage it in my script? Should I remove "KiB" after the size, or should I wait for Mikrotik to fix it?
sergejs
Re: v6 rc7 released
Mon Jan 28, 2013 8:51 am
wispwest
Please attach Null Modem cable to your RouterBOARD 1100AH (during the lockup), is it possible to run any command on it?
Is there any response or output?
normis
Re: v6 rc7 released
Mon Jan 28, 2013 9:10 am
Connect serial cable and copy full output of the problem. If any crash happens, it will be visible on the serial output.
normis
Re: v6 rc7 released
doush
Long time Member
Long time Member
Re: v6 rc7 released
Mon Jan 28, 2013 4:40 pm
Ticket#2013011266000104
Still unreplied.
CCR is acting up when we export compact the configuration exactly like our x86 box that we would like to replace with it. x86 is also running RC7.
kgninfos
Re: v6 rc7 released
Mon Jan 28, 2013 7:13 pm
i am getting 50-75% cpu uses(RB2011UAS-RM) with just about 7-8 hotspot users and 3-4Mbps bandwidth max
i am using layer7 based traffic prioritization
http://wiki.mikrotik.com/wiki/Basic_tra ... _protocols
and simple queues for bandwidth management
is this normal
Surtpp
Re: v6 rc7 released
Tue Jan 29, 2013 12:26 am
Can I give a positive remark?
Using PPPoE client to run a VDSL2 modem I used to get 45ms pings (to XYZ server) on 5.22 and 6RC6. Nothing has changed except that now I put 6RC7 on the RB2011UAS-2HnD, and now I'm getting 30ms pings.
Maybe its the full moon? Who knows. But anyway, its nice!
Thanks MT.
SMARTNETT
Tue Jan 29, 2013 3:19 am
I HAVE THE SAME PROBLEM WITH X86 SYSTEM, 5.14 TO 6RC7 AND ALL THE INTERFACES CANT VIW VIA IP AL THE SYSTEM IS FINE BUT NEVER VIA IP
erebusodora
Re: v6 rc7 released
Tue Jan 29, 2013 8:29 am
This is because the bugs from the previous version unmade starting a new ..... With the new version like driving in the dark .. Surely they do not want to fix bugs in previous versions (5.21 or 6 RC6) and rush to version 7 or 8 or 9.
Rule one:If it works do not touch it or upgrades!
estdata
Re: v6 rc7 released
Tue Jan 29, 2013 11:11 am
6.0 RC7 is not possible to use an external hard disk drive is the problem, not connecting and are not visible from the outside. Routerboard OS disc that filesysteems uses?
2. fix please rstp and stp protokol, highly volatile Internet speed
kgninfos
Re: v6 rc7 released
Tue Jan 29, 2013 6:17 pm
i got my second random reboot
i the device was up for last 2 days and suddenly it got restarted and in log there is nothing(log cleared)
what's going on??
mtmx80
Re: v6 rc7 released
Tue Jan 29, 2013 8:58 pm
I experience the same. Router is up for 2-3 days and reboots while there shouldn't be any load on it (after midnight).
One more think:
[] > /system routerboard print
       routerboard: yes
             model: 2011UAS
     serial-number: 374702DC2387
  current-firmware:
  upgrade-firmware: 3.02
Where is current-firmware version? It was there in version 6.0rc6 and it was up to date.
[] > /system resource print
                   uptime: 19h48m6s
                  version: 6.0rc7
               build-time: Jan/18/2013 13:04:05
              free-memory: 101.2MiB
             total-memory: 128.0MiB
                      cpu: MIPS 74Kc V4.12
                cpu-count: 1
            cpu-frequency: 600MHz
                 cpu-load: 1%
           free-hdd-space: 46.9MiB
          total-hdd-space: 64.0MiB
  write-sect-since-reboot: 3329
         write-sect-total: 367793
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB2011UAS
                 platform: MikroTik
what's going on??
LAQ
Re: v6 rc7 released
Wed Jan 30, 2013 12:19 am
Several Issue's..
We use XENServer to virtualize our routers the DC and testing v6 RC7..
In HVM Mode we cannot run the installer and does not get to the initial module selection page.
If we Install 5.22 and upgrade to v6 RC7 on rebooting we end up with a kernel panic on rebooting the vm after the module upgrades.
Regards
Lee
jhheider
Re: v6 rc7 released
Wed Jan 30, 2013 1:48 am
Insane number of reboots on a 750 with 6.0rc7:
Jan 28 12:11:13 RB750 router was rebooted without proper shutdown
Jan 28 16:18:52 RB750 router was rebooted without proper shutdown
Jan 28 17:08:49 RB750 router was rebooted without proper shutdown
Jan 28 21:28:27 RB750 router was rebooted without proper shutdown
Jan 28 22:18:28 RB750 router was rebooted without proper shutdown
Jan 28 22:38:30 RB750 router was rebooted without proper shutdown
Jan 28 23:38:27 RB750 router was rebooted without proper shutdown
Jan 29 03:08:29 RB750 router was rebooted without proper shutdown
Jan 29 03:58:30 RB750 router was rebooted without proper shutdown
Jan 29 05:08:27 RB750 router was rebooted without proper shutdown
Jan 29 05:38:27 RB750 router was rebooted without proper shutdown
Jan 29 06:58:27 RB750 System rebooted because of kernel failure
Jan 29 06:58:27 RB750 router was rebooted without proper shutdown
Jan 29 09:38:27 RB750 router was rebooted without proper shutdown
Jan 29 10:08:29 RB750 System rebooted because of kernel failure
Jan 29 10:08:29 RB750 router was rebooted without proper shutdown
Jan 29 11:28:28 RB750 System rebooted because of kernel failure
Jan 29 11:28:28 RB750 router was rebooted without proper shutdown
Jan 29 11:48:29 RB750 router was rebooted without proper shutdown
Jan 29 13:38:34 RB750 router was rebooted without proper shutdown
Jan 29 14:18:27 RB750 router was rebooted without proper shutdown
Jan 29 16:28:30 RB750 router was rebooted without proper shutdown
Jan 29 16:48:28 RB750 router was rebooted without proper shutdown
Jan 29 17:28:27 RB750 router was rebooted without proper shutdown
Jan 29 18:08:27 RB750 router was rebooted without proper shutdown
Ticket #2013013066000026. Two auto-sups and a manual.
kgninfos
Re: v6 rc7 released
Wed Jan 30, 2013 6:25 am
i think my cpu uses is 100% due to ddos
in connection log i can see an ip 69.171.248.16 and port 80 in list but when the site is opened it shows
for (;;); {"t":"refresh","reason":120,"seq":0}
also am getting a lots of connection to a specific ip can any one tell is there any issue(screenshot attached)
meschaninovn
Re: v6 rc7 released
Thu Jan 31, 2013 9:09 pm
In the menu "ip - neighbor list" all dynamic interfaces are available for the detection... i can`t disable this...
Chupaka
Re: v6 rc7 released
Thu Jan 31, 2013 11:19 pm
try
ros code
/ip neighbor discovery settings set default=no
meschaninovn
Re: v6 rc7 released
Fri Feb 01, 2013 12:17 am
try
ros code
Thanks)
estdata
Re: v6 rc7 released
Fri Feb 01, 2013 7:20 am
is this normal
Why you are using a Layer-7. And if you look at the cpu so high up, over your log,
or/interface port1 torch
I will rise 20-40% of cpu if you throw things or big traffic
Steady even if someone DDoS attack to you
kgninfos
Re: v6 rc7 released
Fri Feb 01, 2013 6:37 pm
i figured out the issue
it was due to the layer 7 prioritization
disabled that and CPU load is not 4-5%
paoloaga
Re: v6 rc7 released
Sun Feb 03, 2013 3:51 am
[admin@demo.mt.lv] > /system resource print
uptime: 6h34m47s
version: 6.0rc8
build-time: Feb/01/2013 14:37:45
free-memory: 32.7MiB
total-memory: 64.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 300MHz
cpu-load: 38%
free-hdd-space: 49.7MiB
write-sect-since-reboot: 11435
write-sect-total: 2255972
bad-blocks: 0.1%
board-name: RB433
platform: MikroTik
# feb/03/2013 03:46:58 by RouterOS 6.0rc8
Please, fix this... I think it's really simple! The resulting export script should be compatible...
I don't think I need to open a ticket and/or send a supout.rif... do I?
Thanks!
normis
Re: v6 rc7 released
Mon Feb 04, 2013 11:07 am
Hm, sorry but can't repeat it yet.
ros code
[admin@MikroTik] /ip dns> set cache-size=30000
[admin@MikroTik] /ip dns> print
                servers:
        dynamic-servers: 192.168.88.1,10.5.8.1
  allow-remote-requests: yes
    max-udp-packet-size: 4096
   query-server-timeout: 2s
    query-total-timeout: 10s
             cache-size: 30000KiB
          cache-max-ttl: 1w
             cache-used: 10KiB
[admin@MikroTik] /ip dns> export
# jan/07/1970 21:28:30 by RouterOS 6.0rc7
# software id = LB6Y-8QAY
set allow-remote-requests=yes cache-size=30000KiB
/ip dns static
add address=192.168.88.1 name=router
[admin@MikroTik] /ip dns> /ip dns
[admin@MikroTik] /ip dns> set allow-remote-requests=yes cache-size=30000KiB
paoloaga
Re: v6 rc7 released
Tue Feb 05, 2013 12:18 am
On what ROS version are you trying it? This behaviour appeared only in 6.0rc7 (tested on RB951-2n and RB1200), and it's still like this in 6.0rc8 (build-time: Feb/04/2013 13:25:4) found on demo.mt.lv.
To reproduce this, just log into demo.mt.lv and issue the command:
[admin@demo.mt.lv] /ip dns> set allow-remote-requests=yes cache-size=30000KiB
P.S.: about build time: I don't tink that seconds lack the leading 0 intentionally (13:25:4).
ditonet
Forum Veteran
Forum Veteran
Re: v6 rc7 released
Tue Feb 05, 2013 2:02 am
ros code
[admin@dydyrydy14780554] /ip dns> set cache-size=8192KiB
[admin@dydyrydy14780554] /ip dns> /
[admin@dydyrydy14780554] > /system resource
[admin@dydyrydy14780554] /system resource> print
                   uptime: 5h26m41s
                  version: 6.0rc8
               build-time: Feb/04/2013 13:25:46
               board-name: RB751U-2HnD
As paoloaga wrote, this problem appeared in ver. 6.0rc7 and still exists.
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
normis
Re: v6 rc7 released
Tue Feb 05, 2013 8:54 am
I have latest rc8 and CCR router. I don't see this issue. Try this on som other router, no DEMO router where you have no write permissions.
incubusru
Re: v6 rc7 released
Tue Feb 05, 2013 11:55 am
ether3, ether4 - 10gb
Dropping tx packets on vlan193. How it fix?
normis
Re: v6 rc7 released
Tue Feb 05, 2013 12:06 pm
you don't need to fix that. those are invalid packets that are being ignored in the router. RC8 and above will not show them
incubusru
Re: v6 rc7 released
Tue Feb 05, 2013 12:28 pm
Did it normal, when tx drops +50~+150 per second, but rx drops always zero?
ps
drops invalid ip packets or ethernet frames?
paoloaga
Re: v6 rc7 released
Tue Feb 05, 2013 6:33 pm
This is ROS 6.0rc7 on a RB2011UAS:
[admin@AgalandGW] > /system resource print
uptime: 2w3d20h2m17s
version: 6.0rc7
free-memory: 97.9MiB
cpu-count: 1
cpu-load: 14%
free-hdd-space: 110.8MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 8169
write-sect-total: 45721
bad-blocks: 0%
platform: MikroTik
[admin@AgalandGW] > /ip dns set cache-size=2048KiB
I don't have an RC6.0rc8 at hand, right now, I will try to download it later.
Anyway, on the demo router, the error appears at the command parsing level, before reaching the user write permission deny.
ditonet
Forum Veteran
Forum Veteran
Re: v6 rc7 released
Wed Feb 06, 2013 12:33 am
paoloaga and me made tests on 'mipsbe' platform, maybe 'tile' is not affected with this issue?
Demo routers are also 'mipsbe'.
Regards,
pyfgcrl
Re: v6 rc7 released
Thu Feb 07, 2013 5:19 am
Any chance that 6rd is going to find its way into RouterOS v6? at&t and many large ISPs like it are now using 6rd to deploy IPv6. Not having it in RouterOS is a big issue for our clients that use RouterOS on the edge.
normis
Re: v6 rc7 released
Thu Feb 07, 2013 9:14 am
you are right, this only affects MIPS-BE platform
heviejob
Re: v6 rc7 released
Thu Feb 07, 2013 7:58 pm
I upgraded a RB450G not its bricked. I can't access it via winbox
nor reset the unit. How can I recover it.
It had 5.23 the upgraded to v6rc7.
normis
Re: v6 rc7 released
Fri Feb 08, 2013 7:58 am
connect serial console, and see what it says. netinstall will probably recover it: http://wiki.mikrotik.com/wiki/Manual:Netinstall
alexjhart
Re: v6 rc7 released
Fri Feb 08, 2013 10:05 am
I am dealing with random reboots on rc7 with CCR1036.
Alex Hart
The Brothers WISP
normis
Re: v6 rc7 released
Fri Feb 08, 2013 12:28 pm
Please try the version with fixes for this problem: http://www.mikrotik.com/download/share/ ... 6.0rc9.npk
heviejob
Re: v6 rc7 released
Mon Feb 18, 2013 8:20 pm
Netinstall recovered it. Am waiting for the stable version now.
alexjhart
Re: v6 rc7 released
Sat Feb 23, 2013 6:32 am
I haven't had any issues with reboots while on rc9 (13 days uptime so far). Many thanks! :)
Alex Hart
The Brothers WISP
ConnectiviaSrl
Re: v6 rc7 released
Mon Mar 18, 2013 8:08 am
We had the same problem. The bridges disappear after reboot in both cases : connected trough MAC or IP. moreover the local connection used to manage the router is with 0.1ms so no slow connection issue can be involved.
Th sub thread started by marcin21 apparently has no final solved answer so I do not know if it was solved or less.
please whenever solution or workaraoud where found , show them to us.
Networking - R&D Team @ Connectivia Srl
http://www.connectivia.it
rower
Re: v6 rc7 released
Thu Mar 21, 2013 4:23 pm
Beta = Alpha
i just wander, if you do feel that it is right ?
ConnectiviaSrl
Re: v6 rc7 released
Thu Mar 21, 2013 4:51 pm
not 100% because on other x86 nodes it 's working like a charme. so?
normis
Re: v6 rc7 released
Fri Mar 22, 2013 9:07 am
This thread is about an old version. Please upgrade to rc11 or rc12 and if problem repeats, post in the relevant topics.
Users browsing this forum: arm920t, juzeal, martinclaro and 71 guests
