edmundas
ccr 1016 ver 6.0rc8 and bugs [solved!]
Thu Jan 31, 2013 6:03 pm
I installed ccr 1016 replacing 2011. With 2 bridges. Bridge 1 ether 1 to 6 and bridge2 ether 8-10. Extensive drops on some ports and 2 ports (6 and 10) were unable to communicate with the devices.I'd to use switches to run the network. Neighbour discovery adds every interface like pppoe users, making list unreadable. Sent the support file to the support.
sergejs
Re: ccr 1016 ver 6.0rc8 and bugs
Fri Feb 01, 2013 9:07 am
Please send your request to support@mikrotik.com, there is no e-mail from you at the moment. We will research your issue.
Though I have checked mine CCR that works as bridge/switch, /ip neighbor table looks correct on them.
edmundas
Fri Feb 01, 2013 1:09 pm
support.rif has already been sent and support has reverted on the same.
had u tested neighbours with pppoe server on ?
shall i give u read only account in mail ?
edmundas
Re: ccr 1016 ver 6.0rc8 and bugs[Solved]
Thu Feb 07, 2013 6:58 pm
just received rc9 from mikrotik and the problem is resolved.
Dobby
Fri Feb 08, 2013 5:04 pm
Deleted because not related.
GREG3f
Re: ccr 1016 ver 6.0rc8 and bugs [solved!]
Sat Mar 09, 2013 7:53 pm
Is this corrected or is it supposed to show EVERY interface? As stated, this makes the list difficult to read. I can filter list to not contain PPP in interface name as a work around, but would prefer not to see 400 PPPoE interfaces by default.
Situation exixts in RC11 on X86.
