Sandor1k
ROS 6.0 rc8 do not work dhcp client on vlan
Mon Feb 04, 2013 5:40 pm
do not work dhcp client on vlan, works on ethernet. Netcard intel i350t2, on intel CT desktop work. wrote to say that such a support driver. How to fix the problem?
Ticket#2013012866000825
Regards, Alexandr
sergejs
Re: ROS 6.0 rc8 do not work dhcp client on vlan
Mon Feb 04, 2013 5:47 pm
We are looking for solution for your problem. It is the problem of the specific network interface card driver, it has nothing to do with rc8 version.
estdata
Mon Feb 04, 2013 6:49 pm
sergejs ,
If the problem solved also the micro usb and connect a hard disk of the router?
don't forget to give me karma if got help
Sandor1k
Mon Feb 11, 2013 5:12 pm
Is there a shift in a positive way?
Sandor1k
Fri Feb 15, 2013 4:41 pm
Is it just I have a problem?
nosovk
Fri Feb 15, 2013 6:18 pm
Not only you.
And there is still that problem on ROS 6.0 rc9
I use RB433UAH plus sereral RB751U/RB751G routers.
Аренда Програмного обеспечения
https://www.CloudZZ.com
Микротики на Украине оптом
mikrotik.kharkov.ua
Sandor1k
Mon Mar 11, 2013 11:39 am
Good day, there is a solution? I bought a motherboard, 5.x not fully support it (chipset Q77), and 6.x is not working on vlan dhcp
Sandor1k
Wed Mar 27, 2013 2:32 pm
Whether the solution to my problem?
Users browsing this forum: Bing [Bot], ckl88, rioven, tdw, thekev, unam83, Xgraver and 213 guests
