estdata
v6 rc8 released
Mon Feb 04, 2013 6:46 pm
What's new in 6.0rc8 (2013-Feb-04 13:25):
*) ppp,pppoe,pptp,l2tp,sstp - only 2 change mss mangle rules are created for all ppp interfaces;
*) wireless - fixed AES encryption speed issues (upgrade suggested);
*) dhcpv6 server - handle info requests;
*) webfig - compressed all html resource files, speeds up opening of webfig page;
*) console - reduced width of address column in '/user print';
*) simple queues requires target arg to be specified when adding;
*) do not count packets for unknown protocols as rx_dropped;
*) snmp - provide POE info;
*) improved cpu usage reporting on CCR boards;
*) improved interface reading performance;
*) changed CLI interface order - first are ethernets, second wireless, third everything else.
Within group interfaces are ordered by name;
*) interfaces are deleted much faster, could be bottleneck on systems with many ppp sessions;
*) pptp,l2tp,6to4 tunnel encapsulation/decapsulation now resets packet marks to
have consistent behavior across tunnels;
*) fix simple queue interface matching when doing encapsulation in some tunnel,
could result in double accounted packets;
*) ip/ipv6 firewall has all-ether,all-wireless,all-vlan,all-ppp interface matchers
*) queue limits could be inaccurate for large limits (100M or more);
*) added initial OpenFlow support
don't forget to give me karma if got help
estdata
Re: v6 rc8 released
Mon Feb 04, 2013 6:52 pm
and I have an idea and proposal development, by means of the rc9 version will not be able to develop a graphical interface to the DDoS attack against protection?
w0lt
Re: v6 rc8 released
Mon Feb 04, 2013 7:38 pm
Not able to update via "System/Packages" yet.. still thinks 6.0rc7 is current.
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
jcem
Re: v6 rc8 released
Mon Feb 04, 2013 7:41 pm
"Interface window" in winbox stops sending data. When making
a new connection the windows is empty.
Also no SNMP - CPU, DISK
RB433AH ROS6.0RC8 4feb13
This was not the case with the friday 1feb13 release where SNMP shot to 100%
Jörgen
mars
Re: v6 rc8 released
Mon Feb 04, 2013 8:29 pm
still getting
System rebooted because of ping watchdog timeout
all rbs with ros6.0rc8
happens every couple of hours
estdata
Re: v6 rc8 released
Mon Feb 04, 2013 8:35 pm
still getting
watchdog disabled(off) and what is new ?
Attila
Re: v6 rc8 released
Mon Feb 04, 2013 9:08 pm
Dear Normis!
Multicast routing (PIM-SM) same source (IPTV channel) with different client IP (Set Top Box) not working in CCR1036 (RC6,RC7,RC8). Same ROS version (RC6,RC7,RC8) and same configuration (1. RP, 3. Interface) working correctly in RB2011.
Please investigate this problem...
Thx.
Attila
FutileNetworks
Re: v6 rc8 released
Mon Feb 04, 2013 10:43 pm
20:39:03 route,bgp,error tcp-md5-key currently cannot be enabled on CCR devices
Why wasn't this mentioned in the Changelog? When will it be fixed and when it is please include it in the Changelog!! My router is pretty much useless without this.
edit: found post where it will be fixed in rc9, thanks.
Last edited by FutileNetworks on Tue Feb 05, 2013 5:39 am, edited 1 time in total.
mars
Re: v6 rc8 released
Mon Feb 04, 2013 11:33 pm
with watchdog off the rb411 runs out of memory and hangs
and connection tracking off with 1 filter rule connection tracking is still on
honzam
Re: v6 rc8 released
Mon Feb 04, 2013 11:39 pm
post there:
/system resource print
/system routerboard print
LAN, FTTx, Wireless. ISP operator
ema
Re: v6 rc8 released
Tue Feb 05, 2013 12:53 am
I found firewall problem in rc8 - CCR1036
 /ip fire nat pri
 0   chain=srcnat action=src-nat to-addresses=185.15.0.3 src-address=192.168.24.0/22
 1   chain=srcnat action=src-nat to-addresses=185.15.0.4 src-address=192.168.14.0/23
 /ip fire fil pri
 0  chain=output action=log protocol=icmp log-prefix=""
and I get on output:
22:45:22 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.72.22->10.10.72.1, len 56
22:45:23 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.70.8->10.10.70.3, NAT (10.10.70.8->185.15.0.5)->10.10.70.3, len 50
22:45:23 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.72.22->10.10.72.1, len 50
22:45:24 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.70.8->10.10.70.3, NAT (10.10.70.8->185.15.0.5)->10.10.70.3, len 50
22:45:24 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.72.22->10.10.72.1, len 50
22:45:25 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.70.8->10.10.70.3, NAT (10.10.70.8->185.15.0.5)->10.10.70.3, len 50
22:45:25 firewall,info output: in:(none) out:eth5-PLANET-p3, proto ICMP (type 8, code 0), 10.10.72.22->10.10.72.1, len 50
I had a rule that NAT 10.10.0.0/16 to 185.15.0.5 but it was deleted.
I have to disable all nat rules to switch off nat this packets. After switching on I still have NAt 10.10.0.0/16 to 185.15.0.5
nz_monkey
Re: v6 rc8 released
Tue Feb 05, 2013 5:40 am
THANK YOU, THANK YOU, THANK YOU Mikrotik :)
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
engineertote
Re: v6 rc8 released
Tue Feb 05, 2013 9:49 am
in the download page there was RC08 few minutes back , now its RC07 only ??
Ahmed
MTCNA , MTCTCE , MTCRE , MTCINE
normis
Re: v6 rc8 released
Tue Feb 05, 2013 9:53 am
RC8 has a critical issue with Certificates. We temporarily pulled it off the website. If you don't use certificates, you can keep using RC8
przent
Re: v6 rc8 released
Tue Feb 05, 2013 11:46 am
The "All packages" link for 6.x is missing completly after your pull back operation. I`ve just bricked a testboard with partitions on it and there is no 6.x (all packages) to download and use netinstall... Lucky that that was a test board...
normis
Re: v6 rc8 released
Tue Feb 05, 2013 11:48 am
ALL files from RC9 with fixed certificates:
http://www.mikrotik.com/download/share/ ... 6.0rc9.zip
sergejs
Re: v6 rc8 released
Tue Feb 05, 2013 1:10 pm
ema
Please make sure you have not deleted firewall rule by yourself accidentally. We have upgraded many routers to rc8, and NAT rules were untouched on every of them.
For disabled NAT and logging wrong behavior, if you think that v6.0rc8 does not work properly with NAT or not NAT packets, please make support output file and send it to support department (support@mikrotik.com), thank you very much for help.
pchaxor
Re: v6 rc8 released
Tue Feb 05, 2013 2:34 pm
Where did they move the Beta downloads to?
I am not able to find them... weird.
normis
Re: v6 rc8 released
Tue Feb 05, 2013 2:56 pm
what beta downloads ?
YazzY
Re: v6 rc8 released
Tue Feb 05, 2013 3:00 pm
All the RC downloads are gone from the download website.
honzam
Re: v6 rc8 released
Tue Feb 05, 2013 3:42 pm
wait for fix, or use pre-release rc9 http://www.mikrotik.com/download/share/ ... 6.0rc9.zip
normis
Re: v6 rc8 released
Tue Feb 05, 2013 3:44 pm
it has RC7. As Honzam also repeated, you can either use RC7, or use the pre release of RC9. Of if you don't use certificates, keep using the RC8
hci
Long time Member
Long time Member
Re: v6 rc8 released
Tue Feb 05, 2013 5:57 pm
What do you mean by use certificates? The only way I think I use them is connecting securely with winbox and ssh to the Mikrotik. Is that an issue?
paoloaga
Re: v6 rc8 released
Tue Feb 05, 2013 8:11 pm
I hope it's not too much off-topic. Where can I find mipsbe, PPC and TILE 6.0rc8 (all_packages .zip files)? Anyone willing to share their downloads? I don't need it for production, just I didn't download it in time, and now that's pulled, it would leave an empty hole in my ROS collection! :-)
pchaxor
Re: v6 rc8 released
Tue Feb 05, 2013 8:25 pm
Ok they were gone .. RC that is so it must have got fixed since I posted. Looks fine now.
honzam
Re: v6 rc8 released
Tue Feb 05, 2013 10:17 pm
http://www.mikrotik.com/download/share/ ... 6.0rc8.zip
onnoossendrijver
Re: v6 rc8 released
Sun Feb 10, 2013 2:56 pm
Thanks! This is a GREAT improvement! On some devices: before: <1 mbit/s, now: 160 mbit/s.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
Users browsing this forum: MSN [Bot] and 94 guests
