MUM Europe 2020
normis
RouterOS v6rc10 pre-released
Fri Feb 15, 2013 3:52 pm
What's new in 6.0rc10 (2013-Feb-15 10:47):
HotSpot server requires "address-list" configured to work properly
*) ppp - added bridge-path-cost & bridge-port-priority to ppp profiles;
*) ppp - made RSTP work over ppp links as well;
*) ppp - added last-logged-out to ppp secrets;
*) ppp - made MRRU work propererly on CCR;
*) hotspot, ppp - support multiple address-lists;
*) fixed problem - could not format disks larger than 2Gb on CCR;
*) fixed problem - repartitioning flash second time made system unbootable;
*) fixed problem - partition fall back settings got corrupted;
*) fixed problem - package made for other architectures could be installed,
making whole system non functioning;
*) sstp, ipsec - respect CRLs;
*) certificates - for certificates marked as trusted=yes,
CRL will be automaticly updated once in hour from http sources;
*) fixed ppp family interfaces - show it's status (bug introduced in rc8);
*) fixed p2p, connection-bytes firewall matcher;
*) fixed ip firewall nat action=same;
Upgrade includes several stability improvements for Cloud Core Routers.
http://www.mikrotik.com/download
plisken
Re: RouterOS v6rc10 released
Fri Feb 15, 2013 5:00 pm
congratulations for the people of mikrotik.
You guys always bring improvements to routeros, a sign that you mean it with us
Thank you for your efforts, I appreciate that
Chupaka
Fri Feb 15, 2013 5:13 pm
wow! AFAIR, I was talking about this on some EU MUM in '10 or '11 - it's time to pack up my back pack for Zagreb and generate new ideas :D
how should RADIUS send several address-lists to the router? as separate value pairs of the same name?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
honzam
Re: RouterOS v6rc10 pre-released
Fri Feb 15, 2013 6:23 pm
warning on download page: Hotspot not working
LAN, FTTx, Wireless. ISP operator
napismizpravu
Fri Feb 15, 2013 6:51 pm
RB433UAH (power 24V 2A)
RouterOS + MetaROUTER (opendchub,web server) > uptime 3h KO!,destroy,broken,died, no work proxy, >> reboot OK
zervan
Fri Feb 15, 2013 6:55 pm
Is it a bug in RC10 or hotspot is not implemented in v.6 RC at all? I've started to upgrade routers from 5.x to 6rc9 except those with hotspot function. I had a plan to upgrade them with 6rc10, but now I see that will not work.
Dusan Zervan from Slovakia
MTCNA, MTCRE
honzam
Fri Feb 15, 2013 7:13 pm
I thing it is bug in rc10. In rc9 hotspot works
Caci99
Fri Feb 15, 2013 8:49 pm
What is the option of multiple address-lists in hotspot and ppp? How can it be used?
I thought that the p2p matcher was somehow abandoned since the complicated nature of nowadays p2p clients.
What has been improved in here? (I doubt encrypted p2p connections are matched)
-Toni-
Don't crash the ambulance, whatever you do
grg
Fri Feb 15, 2013 9:02 pm
This is what I get after performing upgrade on my RB493G:
[admin@MikroTik] /ip service> print
 #   NAME                                      PORT ADDRESS        CERTIFICATE
 0   telnet                                      23
 1   ftp                                         21
 2 X www                                         80
 3 I ssh                                         22
 4 X www-ssl                                    443        none
 5 X api                                       8728
 6 I winbox                                    8291
[admin@MikroTik] /ip service> enable www
error - contact MikroTik support and send a supout file (2)
[admin@MikroTik] /ip service> enable winbox
I cannot connect to the services that are marked invalid.
doush
Long time Member
Long time Member
Fri Feb 15, 2013 9:09 pm
now pre-relased ??
it was "relased" a fer hours ago.
mikrotik ?
rafaeltdk
Fri Feb 15, 2013 9:10 pm
I need help, I need the quues tree functions, global out, and in global, and global total, however do not have the RC9?, in version 5.22 has my works normal full cache without them without full cache.
roxy74
Fri Feb 15, 2013 10:29 pm
but where is the 6rc10 files in the download page?
zervan
Fri Feb 15, 2013 10:43 pm
There is only main package (.npk) now, marked as "pre-release". It seems like RC10 was canceled because of some issues, so we should wait.
I've upgraded my RB493G without any problems, maybe I'm lucky one :)
MTCNA, MTCRE
honzam
Fri Feb 15, 2013 10:51 pm
http://www.mikrotik.com/download - bottom of page
JanezFord
Fri Feb 15, 2013 11:01 pm
to MT:
Just wondering ... how many rc versions can we expect before final 6.0 comes out? 10? 20? 30? ... is there any timeline by when final version should be released or will this rcXX go on and on and on and on and on and on and on ....
yes, I could be described as impatient but anyway... keep up the good work adding new features (EIGRP please) and removing the bugs from ROS 5 and 6.
infused
Fri Feb 15, 2013 11:30 pm
Got a link for that boot file again? Haven't put it on yet. Ta.
patrickmkt
Fri Feb 15, 2013 11:35 pm
Great, checking CRL was a must that many of us were waiting for.
Chupaka
Fri Feb 15, 2013 11:46 pm
for example, you set some general traffic limit for all clients, but few of them are allowed/disallowed to use some resources - and you set it via one more address list
in v6, there's only 'global' parent, use it (they said, it was 'global-total' in v5, but, as far as I remember, there were some corrections later, so probably now it's what was 'global-out' previously)
rafaeltdk
Sat Feb 16, 2013 12:24 am
help check
ditonet
Forum Veteran
Forum Veteran
Sat Feb 16, 2013 12:39 am
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
rafaeltdk
Sat Feb 16, 2013 1:11 am
sorry, and very complex for me, I could not understand, and I need help before it was too simple, it was so choose now to do everything, and unfeasible for me, personal mikrotik any idea when we'll V6 in the Global out and in and total?
ditonet
Forum Veteran
Forum Veteran
Sat Feb 16, 2013 1:53 am
In RouterOS ver. 6.x 'global-in' and 'global-out' were replaced by 'global', hence link to packet flow diagram.
Just compare differences between ROS 5.x and 6.x.
HTH,
rafaeltdk
Sat Feb 16, 2013 2:36 am
ok great so grateful, however I am not an expert on mikrotik someone could help me? give access to mikrotik.
infused
Sat Feb 16, 2013 4:09 am
nevermind fixed it.
rafaeltdk
Sat Feb 16, 2013 10:59 am
complicated, nobody's ruling mikrotik, I see that the forum not only help each other, I bought this CCR to update my network however I have to leave it in a corner and thrown back to x86 due to lack of this function can not use the full cache my network, mikrotik need of parent: global in global and out, or something to do the same, if possible post a rule, thanks.
friend only global not working for me.
ronix
Sat Feb 16, 2013 11:05 am
try to use simple queue it will work ...
Bishop
Sat Feb 16, 2013 11:06 am
Where is PPP package?
zervan
Sat Feb 16, 2013 11:22 am
I do have it there (but not using).
MTCNA, MTCRE
Bishop
Sat Feb 16, 2013 12:03 pm
The previous version was 6.0rc9 updated by pressing the button "Check for Updates"
What am I doing wrong?
And now as to add additional package PPP?
zervan
Sat Feb 16, 2013 12:35 pm
Me too - everything was ok on RB493G and a pair of SXT 5HPnD.
Nothing - you did it right, but there was probably something wrong in RoS update system. Or maybe - what about "Free HDD space"? You use some extra packages and maybe there was not enough free space... Hmmm, your system says it has 512 MiB HDD? I don't have RB433AH, but I thought all of RB433xx have 64 MiB (as my RB433). :-?
Try to delete unnecessary files, download main package (http://download2.mikrotik.com/routeros/ ... .0rc10.npk) manually, then press System -> Packages -> Downgrade.
MTCNA, MTCRE
netwpl
Sat Feb 16, 2013 6:44 pm
hello,
since release .10, openvpn server @ rb2011 isnt working anymore.
ive already cleaned my certificates, renewed them and so on..
my mac client ( /w tunnelblick ) always says:
TCP connection established with [AF_INET]x.x.x.x:1194
2013-02-16 17:36:25 TCPv4_CLIENT link local: [undef]
2013-02-16 17:36:25 TCPv4_CLIENT link remote: [AF_INET]x.x.x.x:1194
2013-02-16 17:36:25 MANAGEMENT: >STATE:1361032585,WAIT,,,
2013-02-16 17:36:25 MANAGEMENT: >STATE:1361032585,AUTH,,,
2013-02-16 17:36:25 TLS: Initial packet from [AF_INET]x.x.x.x:1194, sid=3448459d 8f8f6847
2013-02-16 17:36:25 *Tunnelblick: Disconnecting; 'disconnect' button pressed
2013-02-16 17:36:25 *Tunnelblick: Disconnecting using 'killall'
2013-02-16 17:36:25 event_wait : Interrupted system call (code=4)
2013-02-16 17:36:25 SIGTERM[hard,] received, process exiting
2013-02-16 17:36:25 MANAGEMENT: >STATE:1361032585,EXITING,SIGTERM,,
no one has pressed the disconnect button ;)
my next step will be downgrading to rc .9
any ideas ?
cheers
Chupaka
Sun Feb 17, 2013 12:22 am
rafaeltdk, just use 'global' instead of 'global-out'
rafaeltdk
Sun Feb 17, 2013 1:30 am
Overall tried, however the simple quues not let pass the speed quue tree, would be a bug?
majkel
Sun Feb 17, 2013 12:53 pm
After 2 days of uptime I get many TX DROPS on all ports.. what it means? on 1036
When I reboot router.. TX drops are 0
I get this always after 2-3 days on all RC versions. When drops starts.. Its about 20-30 tx drops / s
cbrown
Trainer
Trainer
Sun Feb 17, 2013 3:08 pm
 0   telnet                                      23
 1   ftp                                         21
 2 X www                                         80
 3 I ssh                                         22
 5 X api                                       8728
 6 I winbox                                    8291
Same problem for me. I got a supout just haven't had time to send it. I switched back to my rc9 partition.
C.Brown
cbrown[at]ravenrocknetworks.com
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
estdata
Sun Feb 17, 2013 4:28 pm
 0   telnet                                      23
 1   ftp                                         21
 2 X www                                         80
 3 I ssh                                         22
 5 X api                                       8728
 6 I winbox                                    8291
I have this /ip service enable www procedure does not have any problems
don't forget to give me karma if got help
cbrown
Trainer
Trainer
Sun Feb 17, 2013 6:57 pm
The procedure itself isn't the problem. It is something wrong with the services. As you also see SSH is invalid.
C.Brown
infused
Mon Feb 18, 2013 6:11 am
It seems queues now work as intended. IE, bandwidth is correct.
Masyanich
Mon Feb 18, 2013 8:54 am
How can i download All packages of RC10?
janisk
Mon Feb 18, 2013 10:34 am
can you fgive any more details about configuration apart form what you have written (metarouter dies after 3 hour uptime)?
god007
Mon Feb 18, 2013 11:24 am
Hello.
First of all I want to thanks all of Mikrotik's staff - it is great work. Thanks!
I'm newbee in Microtik and RouterBOARD. Need your help.
I ve bought RB751G-2HnD - configure - all works - update up to v6rc10 - but have some troubles with http proxy from v5 until v6rc10.
All works - but when router has big loading (2-3 users with a lot of http queries) it goes into reboot. In logs I see only:
jan/02/1970 03:01:16 system,error,critical router was rebooted without proper shutdown by watchdog timer
Thats all. If want some more logs or switch on loglevel - please give link where I can read how to make it - I will attach all data to find the issue and make RouterOS better.
napismizpravu
Mon Feb 18, 2013 3:38 pm
I already wrote here a few times
RouterOS + enable MetaROUTER >> random KO RouterOS routerboard,frost services RouterOS (MetaROUTER still functional) = unusable
RouterOS + down inactive MetaROUTER >> quite reliable, problems are not
janisk
Mon Feb 18, 2013 3:42 pm
ok, on what router is this? i have tried on MIPS and PPC router and have no issues running it. Can you give any details on what exactly you are attempting to do. (Also what guest you are running, have you tried to run RouterOS)?
napismizpravu
Mon Feb 18, 2013 3:57 pm
[quote="janisk"][quote="napismizpravu"]
????? it is written
opendchub,web server (no PHP,no MySQL) Lighttpd (currently trunk "openwrt-mr-mips-rootfs-31411-basic.tar.gz" http://openwrt.wk.cz/)
Chupaka
Mon Feb 18, 2013 4:36 pm
sorry, I don't understand you. but as far as I remember, in v6 simple queues and queue tree are processed separately, so you cannot catch traffic in queue tree by simple queue
hci
Long time Member
Long time Member
Tue Feb 19, 2013 1:00 am
On RC10 I am having issues with hotspots not allowing users to authenticate. Seems to claim radius server problem even though I am not using an external radius server. I am also having issues with PPPoE server handing out IPv6. It does not seem to bind the correct /64 to the PPPoE session out of the /48 IPv6 pool I am using.
fx242
Tue Feb 19, 2013 2:49 am
Just upgraded my RB333 to rc10: Both Ethernet ports 1 & 2 DISAPPEARED after "reset configuration", and aren't listed on interface list anymore
Neilson
Tue Feb 19, 2013 4:25 am
I think this is a known issue
from the downloads page: (hotspot not working) on all rc10 pre release downloads
Regards
Alexander
Masyanich
Tue Feb 19, 2013 10:54 am
fixed p2p, connection-bytes firewall matcher (!)
Still doesnt work on CR10 CCR....
god007
Tue Feb 19, 2013 10:57 am
Have you got any ideas about my situation that I described some posts ago?
Thank you!
uldis
Tue Feb 19, 2013 11:15 am
please write to support@mikrotik.com with support output file so we could check your configuration
uldis
Tue Feb 19, 2013 11:17 am
did you make a support output file and sent it to support@mikrotik.com?
Masyanich
Tue Feb 19, 2013 11:40 am
And i stiil having troubles with NTP.
Ticket#2013021966000297
Thank you
zervan
Tue Feb 19, 2013 2:37 pm
I can't assign more LEDs to show signal level on SXT, RoS v6RC10:
/system leds add interface=wlan type=wireless-signal-strength leds=led1,led2,led3,led4,led5
failure: Maximum led group size reached, only one led per action available!
Is it a bug? This command is working on RC9 - but I don't know if the LEDs are really on. I'm sure it was working in ROS 5.x.
MTCNA, MTCRE
becs
Tue Feb 19, 2013 2:41 pm
It is a bug, will be fixed in v6.0rc11.
shiny
Tue Feb 19, 2013 3:23 pm
hello,
any ideas ?
cheers
I can confirm openvpn does not work on rc10.
neandero
Tue Feb 19, 2013 5:42 pm
I believe this change was a major mistake:
*) global-in, global-out, global-total parent in /queue tree is
   replaced with global that is equivalent to global-total in v5;
everything related to cache server stopped and I've done everything without any hope only go back to OS 5.
janisk
Tue Feb 19, 2013 5:54 pm
neandero can you shed some details on what you have configured now and what exactly is the problem.
neandero
Tue Feb 19, 2013 6:35 pm
Ok, i show you my code, you make this work on os 6 and i will be ready to test it.
mangle
chain=prerouting action=mark-packet new-packet-mark=cache passthrough=no dscp=12
nat
chain=dstnat action=dst-nat to-addresses=10.10.10.250 to-ports=8080 protocol=tcp src-address=192.168.0.0/16 dst-port=80
queue tree
name="Cache" parent=global-out packet-mark=cache limit-at=0 queue=default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
But please make sure you provide a working code not just to test, as you know i must stop all services to first upgrade the system and then implement your code. and if it didn't work i then must downgrade and recode it back..... you know all this is time related for every subscriber. !!!
thank you,
rafaeltdk
Tue Feb 19, 2013 11:48 pm
please bring back global in, and global out, etc., please, because I have the same problem related to that friend stopped my cache.
Chupaka
Wed Feb 20, 2013 12:07 am
use Backup functionality :)
do you use simple queues for limiting your customers? seems that it's the actual problem, not the 'global' itself: AFAIR, now Simple Queues and Queue Tree are separated and cannot affect each other. you need to create Simple queue for Cache traffic
p.s. describe your problems, do not make others to just guess it...
LennonNZ
Wed Feb 20, 2013 1:26 am
I have a RB751U-2HnD running NAT to a PPPoE Connection on v6rc10
After a while (say 5-6 Hours) the web server gets slow and starts to kick me out of the web interface all the time.
Then after a day or so the web server is not available at all. There is no excess memory usage. nothing in logs.
Winbox and ssh access work fine.
When I was running V5 on the router there was no problems at all and the web interface worked all the time.
DrDeft
Wed Feb 20, 2013 1:38 am
There is the big problem after upgrading RouterOS rc9 to rc10.
All information (screenshots and support files) in the attached zip.
On rc10 after reboot some settings dissapeared.
Brige interface dissapeares, pridge ports dissapears, dhcp on bridge "LANs" settings stop working, ip on bridge "LANs" stops working AFTER REBOOT !!!
neandero
Wed Feb 20, 2013 5:12 am
you are correct, I do use simple queues but using PCQ as its type! if global in and global out was eliminated should simple queue be unuseful at all?
I just wish to follow every upgrade you guys make, but at this particular situation I am not able anymore!
either you guys have to do a rework, or i have to find a different route. either way a word must be said to make it noteable.
thanks,
macgaiver
Wed Feb 20, 2013 11:07 am
"global-out" and "global-in" was merged into "global" for performance reasons.
Simple queue was moved to separate independent place just after "global" - this way eliminating century old problem of remembering that simple queues shared "global-in" and "global-out" with queue tree queues placed there, also adding back some of the functionality that might be lost because of "global-in" and "global-out" merger.
So if you had some complex queuing going - you should adjust to these changes.
In case of web-proxy - if you like to avoid limiting proxy traffic or place a separate limitation to it - just use mangle to capture that traffic and place a simple queue for that mark before your regular simple queues. in v6.x simple queues is still working in order, so if packet is captured by first queue it will not go to other queues.
In general QoS in v6.x is much more easy than it was in previous versions. especially when you have to explain it from zero.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
deivisfp
Wed Feb 20, 2013 6:22 pm
Hello guys,
If the option change-mss is enabled on PPPoE profile the dynamic simple queue doesn't work properly.
The lab:
PPPoE-Server(Mikrotik x86) -> PPPoE-Client (Ubuntu Linux)
No radius, no usermanager.
We first established five connections with 10 Mbps each one (50 Mbps). Ok queue works great, so we put more five connections and the queue still working properly (100 Mbps), more five (150 Mbps)... still working... but after more five connections (200 Mbps), the traffic on the server was at 500+ Mbps.
Could you please check this?
Thank you very much!
Deivis Fernandes Pirani
Consultoria Especializada para ISPs
Mikrotik Certified Consultant - MKBR0038
http://www.deivis.eti.br/
drpater
Thu Feb 21, 2013 9:35 am
Hello.
In 6rc10 is possible to add more than one Address List in ppp profile, but when i send same parameter from radius, string addresslist1,addresslist2 received as single word, that lead to adding one new address list with name "addresslist1,addresslist2"
There is debug log:
09:02:58 radius,debug,packet MT-Address-List = "addresslist1,addresslist2"
There is config print
5303 D addresslist1,addresslist2 10.0.130.97
Seems this is a bug?
mmorgan24
Thu Feb 21, 2013 8:24 pm
Not happy - I purchased over 50 MT routers in the last 24 months and have been very happy. I sent a guy from the office to MUM in New Orleans and he was wowed by the new Cloud Core Routers. I purchased two of them for a large scale VPN solution and also 60 MT750GL routers. The CC-1036 came with RC6 and had tons of OVPN and certificate issues. The latest release still has the same problems - opens OPVN session for 20 seconds then drops. What am I to do? I've depended on and been happy with Mikrotik's until now - I'm stuck holding the bag for all of these devices until I can get it working?
With lack of UDP on OVPN and the money I have tied up right now I want to know when I can expect a functional CC and OVPN solution. I've even ordered a few Ubiquiti EdgeMax LITE routers just to see what else is out there.
ste
Thu Feb 21, 2013 9:20 pm
You cant blame MT for using prereleased software.
majkel
Thu Feb 21, 2013 9:24 pm
Its sad that there is no stable RC version for 1036 ;(
mmorgan24
Thu Feb 21, 2013 9:25 pm
I can blame them for releasing hardware that won't work WITH ANY OF THEIR SOFTWARE though. Thanks.
FutileNetworks
Thu Feb 21, 2013 10:15 pm
Before I purchased our CCR1036 I knew very well that these were not for production environments and that the software was not release quality yet, having said that I too would like to see UDP in ovpn and more stability under heavy load on the CCR, this is by far the most powerful router MikroTik have made on a brand new hardware platform, it was never going to work perfectly 'out the box'. We need to support MikroTik while they work out all the bugs and increase stability and performance, so far I'm impressed with what I see. (except Ticket#2013012466000127 still no solution!).
Have you provided config, supout files and verbose logs (both ends) of the issue to MikroTik when the ovpn session drops?
mmorgan24
Thu Feb 21, 2013 10:34 pm
I have done what I have been asked to do - saying we should "support them" doesn't mean I should pay and be their guinea pig on beta code for released hardware with my money. What would Juniper and Cisco do - sell hardware to the masses and then work on software afterwards??
How did you know the product wasn't for production environments? Did something in the product description tell you it wasn't ready for prime time?
FutileNetworks
Fri Feb 22, 2013 12:08 am
It's written on the distributors website where I bought our CCR: "Please note that the CCRs run RouterOS 6 which is not fully released yet. It is not recommended to use the CCRs in production until it is fully released." I also read this forum so I was aware of many issues.
sp8qjf
Fri Feb 22, 2013 12:39 am
I have 5.24 in CCR
Chupaka
Fri Feb 22, 2013 12:51 am
I have 5.24 in CCR
haha, how? =)
mmorgan24
Fri Feb 22, 2013 8:03 am
I moved the 60 second timer on the OVPN server config after upgrading to RC10 and now the sessions stay up past the 20 second timeout I was seeing earlier - clearly this is come sort of counter bug.
I hope they get this worked out - I really don't want to purchase some vendors "industrial PC" MT box and hope for the best. Later!
PUT UDP SUPPORT INTO ROUTEROS NOW NOW NOW!!!!
normis
Fri Feb 22, 2013 9:30 am
The same is also on our own web site. And other distributors tell you the same too. The initially available batch (all units currently out there) are sold as "pre production testing batch"
doush
Long time Member
Long time Member
Fri Feb 22, 2013 3:28 pm
I have 5.24 in CCR
Tell us how ?
normis
Fri Feb 22, 2013 4:57 pm
not possible
Users browsing this forum: Google [Bot], mzahor123 and 103 guests
