How can I separate traffic on two ports of a switch chip of a rb1200?
Port 5 will have a cable, will pass traffic directly to port 4 linked to a firewall, both part of the switch of a rb1200. Ports 1, 2 and 3 should not see this traffic.
The idea is that I'll be using a separate firewall and i want to take advantage of the switch chip of a rb, if necessary to disable the firewall (hardware problems, for example) I can reconfigure the rb that is more than 30 km away.
The incoming traffic can not have vlan! Vlans only communication between the doors.
