MUM Europe 2020
nmaton
change out interface in ip firewall nat
Sat Mar 09, 2013 11:22 pm
I'm unable to change the out-interface in ip firewall nat with a script.
I have the following set in a script :
/ip firewall nat set numbers=9 out-interface=<pptp-test>
When i issue that command in terminal the out-interface gets adjusted but not when it's run from a script.
Any ideas on how to change this ?
thanks
Nicolas Maton
nicolasmaton@gmail.com
CCNA/ CCDA
MTCNA / MTCTCE
Available for Mikrotik Consulting
ditonet
Forum Veteran
Forum Veteran
Re: change out interface in ip firewall nat
Sun Mar 10, 2013 12:35 am
Add comment to this NAT rule (e.g. 'my_NAT_rule') and use following command:
ros code
/ip firewall nat set [find comment="my_NAT_rule"] out-interface=<pptp-test>
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
jgellis
Sun Mar 10, 2013 1:26 am
ditonet is correct.
The "number" attribute you see when printing in the terminal (i.e. 9 in your script) is not a configuration item on the nat rules. They are generated during a print command only. To set or get any values in a script you should always use the [find] command to narrow your results. [find] by itself would return all nat rules in this case, [find comment="blah"] would return only those with that exact comment, [find comment="blah" chain=forward] would return... well you probably get it by now.
If you cannot find it dynamically/uniquely using attributes set within the rule, then I do exactly what ditonet suggests, give it a unique comment and [find] it by that.
- If I helped you solve your problem... I am now able to accept tax-deductible Karma donations!
nmaton
Sun Mar 10, 2013 1:41 am
Great info thank you all.
I had no idea scripting worked that way.
Thanks again :)
Nicolas Maton
CCNA/ CCDA
MTCNA / MTCTCE
Users browsing this forum: No registered users and 10 guests
