MUM Europe 2020
pablot76
RB750 ISP static with a proxi
Wed Mar 20, 2013 12:29 am
Hi
I meed help please, i have a router board rb750 with five ports.
My isp provider is configured
WAN IP:10.32.0.0/16
MASK:255.255.0.0
GATEWAY:10.32.0.2
DNS:10.0.1.8;10.0.1.9
Proxy:10.0.1.6: port:3127
and i can redirect internet and data for lan to wan, i don´t know how configure my rb to work like a transparent proxy
if not i have to configure te proxy in each pc and so much work
the diagram is basic
Thanks for reply
Real
Re: RB750 ISP static with a proxi
Wed Mar 20, 2013 11:26 am
HI,
all information about proxy:
http://wiki.mikrotik.com/wiki/Manual:IP ... on_example
after adding firewall NAT rule and other seetings you have to add proxy server address and port in parent proxy field (10.0.1.6: port:3127) , in ip > Web proxy seetings.
pablot76
Wed Mar 20, 2013 12:34 pm
First, thanks
the proxy this before my rb750 in my lan not need a proxy.
my input wan is for the proxy 10.0.1.26:3128
not in the lan
Real
Tue Mar 26, 2013 10:31 am
The proxy is on ISP ?
if yes then in mikrotik proxy seetings add parent proxy server address,
If you want use your mikrotik proxy, then all configuration is in this exampe which i posted,
in booth configurations you dont need to configure proxy seetings in your Lan pc's.
Users browsing this forum: inteq and 50 guests
