bocekr00t
2X Wan + 1 Lan Load Blance Help Me Please
Fri Mar 22, 2013 2:48 pm
hello
Below is set up where the error has
threw ping http://www.google.com "time out" is.
Thank you.
bocekr00t
Re: 2X Wan + 1 Lan Load Blance Help Me Please
Fri Mar 22, 2013 2:49 pm
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=221.132.112.8,8.8.8.8
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:2/2 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
bocekr00t
Fri Mar 22, 2013 6:37 pm
up up
bocekr00t
Sat Mar 23, 2013 11:07 am
hello friends
Is there any information on the subject, which
bocekr00t
Sat Mar 23, 2013 7:35 pm
I think this forum bevada no answer ...
paid to solve my problem my friend wanted it.
sent from paypal fee.
, send us a message.
keskinlikursat@hotmail.com
cbrown
Trainer
Trainer
Sat Mar 23, 2013 8:04 pm
What is your problem? You need to provide a better description.
C.Brown
cbrown[at]cbrown.co
Telegram: @chris4brown
MTCNA - MTCRE - MTCWE - MTCTCE
MTCSE - TRAINER-0179
bocekr00t
Sun Mar 24, 2013 12:13 am
throwing ping
new terminal == >>> ping http://www.google.com
timeout is timeout
why is that?
  is not working properly?
When running the line to the internet as a single
there is no problem.
but when I got engaged two Internet
I threw ping http://www.google.com
s time-out time-out begins.
Is there a mistake?
Why list blue lights routlist WAN2 ?
gtpro
Sun Mar 24, 2013 6:36 pm
Your problems is here
Delete these rules! You already have them.
cbrown
Trainer
Trainer
Sun Mar 24, 2013 6:46 pm
It should also be
3/0
3/1
3/2
C.Brown
cbrown[at]cbrown.co
gtpro
Sun Mar 24, 2013 6:49 pm
Hi, I know, he has the right rules above, he just need to delete the ones below.
bocekr00t
Mon Mar 25, 2013 1:52 am
hi
hello
I did, but the problem still
half-open web pages
guess the following
In one cause first İSP
After 2 to İSP
performance, as the system does not exist. big problem.
Please write an email or instant messenger address here " GTPRO ".
Thank you.
gtpro
Mon Mar 25, 2013 4:30 am
Hi, try this configuration
/ip dns set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=8.8.4.4,8.8.8.8
/ip firewall mangle
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
good luck.
bocekr00t
Mon Mar 25, 2013 2:20 pm
bocekr00t
Mon Mar 25, 2013 2:21 pm
/ip firewall mangle
good luck.
This is why blue?
wach video
http://youtu.be/bR0XgBB0TLo
bocekr00t
Mon Mar 25, 2013 6:35 pm
This problem is solved.
the problem stems from me
3 pcs mac address is the same as for the
This problem is solved mac addresses changed
thanks
gtpro
Mon Mar 25, 2013 7:18 pm
Good to know, but I see that you are using hotspot, hotspot and load balancing wont work wtih that configuration on the same routerboard. Just so you know.
Users browsing this forum: faxxe, mbovenka, mkx, newone, omnetwork, sindy, techclerk, Znevna and 145 guests
