MUM Europe 2020
Senux
4G LTE cards (4gen) support request on RouterOS 6
Sat Mar 23, 2013 1:21 am
It is necessary to have USB 4G LTE cards support and USB reset function - new Huawei E3276s, also konwn as M150-1 (Megafon) and K5007 (Vodafone) may be used with RB751, RB951 and others for main or alternative internet connection.
Looks like Mikrotik ignore LTE.
ginggs
Re: 4G LTE cards (4gen) support request on RouterOS 6
Sun Apr 07, 2013 10:18 am
More information in the thread 'Huawei E3276 problem' here:
http://lists.freedesktop.org/archives/l ... hread.html
Support for this type of Huawei modem was added to drivers/net/usb/cdc_ncm.c in Linux kernel 3.6.11:
http://www.gossamer-threads.com/lists/l ... el/1649246
estdata
Sat Apr 13, 2013 10:37 am
tip: Do you need to usb host cable
don't forget to give me karma if got help
Senux
Thu May 02, 2013 5:22 pm
No - you do not need any cables.
Is still no 4G in Latvia? Seems no or Mikrotik stucked in XX century.
normis
Fri May 03, 2013 2:10 pm
Senux, we do have 4G LTE in Latvia, and we support a number of cards. You must contact support, not ask for user help in this case. Only MikroTik support can add drivers.
kwagga
Tue Jul 16, 2013 3:30 pm
Hi Guys,
Does anyone have an update for USB LTE modems, such as the Huawei E3276 CAT4?
I know Huawei Hi-Link is a problem, but there are ways around it.
Werner van Heerden
wernergvh[@]gmail.com
HNDip(IS:Network Engineering) - MTCNA - MTCWE - CCENT - MCITP - MCTS
Diamond
Thu Jul 18, 2013 2:07 pm
+1 Request drivers for M100-1 also (Megafon)
normis
Thu Jul 18, 2013 2:15 pm
To add any 4G drivers, please email with your supout.rif file to support@mikrotik.com, and if possible, provide remote access with full rights to SSH.
Diamond
Thu Jul 18, 2013 4:32 pm
Not always internet-access is. For example - SXT in a village. So, best solution - drivers in the RouterOS package.
Diamond
Thu Jul 18, 2013 7:25 pm
Or, may be, pack drivers into a packages? It is easy to download and install.
normis
Fri Jul 19, 2013 2:11 pm
You want us to include untested drivers? We always test with real devices before adding any drivers.
alvnas1500
Mon Aug 05, 2013 9:35 am
Any news when support on 4G USB modems like e3276 will be ready? It has been supported by several linux dist for some time...
bysard
Tue Aug 06, 2013 3:02 pm
+1.
kwagga
Tue Aug 06, 2013 4:01 pm
+1.
+1
Werner van Heerden
Rumpa
Fri Aug 09, 2013 5:55 pm
+1 & M-100 (Megafon)!
Rumpa
Fri Aug 09, 2013 5:58 pm
+1
kwagga
Mon Aug 12, 2013 8:51 am
Maybe the Alcatel One Touch LTE L100V (http://www.alcatelonetouch.com/global-e ... l100v.html)
I see it's gaining market share due to it's fair price point.
Werner van Heerden
Diamond
Thu Aug 15, 2013 3:11 pm
M100-1 works under ROS6.2. Join :D
bysard
Wed Aug 28, 2013 2:17 pm
I got this modem for test today Huawei E3276. On INFO on PPP connection it shows enhanched 3G, but I cannot see the connection under LTE tab. I get transfers up to 2MB/s, so it seems as the modem is working only on 3G correct?
ikhromov
Thu Oct 03, 2013 10:47 am
+1 M150-1
lizarazu
Fri Nov 08, 2013 3:08 pm
Hello guys, Iam carefully read this thread but still dont understand, how I can get drivers for M150-1?
rb951g-2hnd routerOS 6.5
sry if necroposted
lizarazu
Fri Nov 08, 2013 3:17 pm
*repeat deleted*
dragoncity99
Fri Nov 08, 2013 5:01 pm
Requested Huawei E3276 LTE 4G to Mikrotik support for driver/kernel module on my RB951G-2HnD.
alger
Tue Dec 31, 2013 10:35 am
sry if necroposted
Megafon M150-1 = Huawei E3276
On my RB951Ui-2HnD with RouterOS v6.7 work perfectly
In russian: http://papa-admin.ru/articles/mikrotik/ ... 150-1.html
alger
Tue Dec 31, 2013 11:00 am
Отвечу по-русски, т.к. в основном вопросы по модему Российского оператора Мегафон.
У меня M150-1, не знаю должен ли он быть виден в закладке LTE. Могу предположить т.к. это модем не только 4G, но и 3G/2G, поэтому он видится как обычный 3G в Interface.
По инструкции голубой цвет индикатора это 4G, синий 3G.
Он у меня горит голубым цветом, следовательно работает на 4G.
Скорость сильно "плавает". Вот результат на данный момент:
bysard
Tue Dec 31, 2013 1:28 pm
You are showing megabits, I was talking about megabytes (1:8). I haven't tried this on ros 6.7.
alger
Tue Dec 31, 2013 8:11 pm
you have decided to me to teach mathematics or what's your question ?
bysard
Thu Jan 02, 2014 8:38 am
It is not a question at all.
evharten
Fri Jan 03, 2014 1:27 pm
Any support for the E392 already added ? if not i can put one online on a RB and give access.
https://www.mikroshop.nl - The Dutch Mikrotik Store!
uldis
Fri Jan 03, 2014 1:33 pm
for now we could try to add LTE (CDC ether) driver for the modems that has a web interface for configuration as it is not so hard to add support for that as all the configuration is done in the modems www module.
Some few CDC ether capable modems are added in the supported list:
http://wiki.mikrotik.com/wiki/Supported ... _LTE_cards
Mobistek
Fri Jan 03, 2014 4:42 pm
Needed driver for Huawei E3272 (M100-4)
RogerWilco
Sat Jan 04, 2014 2:23 am
@MirkoTik: any plans to support USB-to-WWAN (Direct IP) Sierra Wireless/Netgear for 320U and other SW USB modems to support LTE?
uldis
Mon Jan 06, 2014 6:57 pm
You can check with the latest DirectIP firmware for 320U if it is recognized as a LTE interface or not.
Neovr
Tue Jan 07, 2014 2:22 pm
планируется ли поддержка LTE модема E392 в режиме NDIS ? уж очень не стабильно работает в PPP...
RogerWilco
Wed Jan 08, 2014 12:28 am
Thanks, yes it is detected as a LTE device, however it gets stuck as per this post by another user: http://forum.mikrotik.com/viewtopic.php?f=2&t=78318
The modem works perfectly using the Sierra Wireless Direct IP drivers on Linux computers fine, it just seems RouterOS has some issues with it.
I'd offer you remote access but my ISP don't offer static IPs. I can give you access with the current IP, then you whip up a script to email you the new IP when you reboot the modem...
wolfeyes
Wed Jan 29, 2014 6:19 pm
I have tested the Vodafone K5005 usb dongle and behavior is quite appreciated I would say.
Tested on RB951 with ros v6.7
It is not recognized as an LTE interface on respective tab but as a normal huawei usb dongle (3G).
The problem is that reset ATDT commands are not applicable so modem reset cannot be done.
However it is quite stable but not for production deployments without supervision.
YASSKYLIGHT
Tue Feb 18, 2014 3:32 pm
So what about support Huawei E3272?
test10
Mon Feb 24, 2014 11:51 pm
+1, it's only work for ppp-connection, /interface lte is empty.
lemonmagic
Fri Feb 28, 2014 7:52 pm
Did you use the latest Firmware?
It's supposed to be working, as it is listed in the Supported Hardware Wiki Page with ROS v6.8.
dnsk
Tue Mar 04, 2014 9:09 am
+1. With Huawei e3272 in NCM lte interface list empty on v6.10.
Modem МТС 824F.
test10
Tue Mar 04, 2014 11:36 am
YES, 6.10 on my 951G-2HnD and last universal firmware for usb dongle 21.436.11.00.00.
wakadannacom
Mon Oct 20, 2014 5:29 pm
Request a support in ROS v6.x of Huawei GL04P LTE(4G).
My RB951G-2HnD need this driver for usb :
"HUAWEI Data Cards Linux Driver"
http://consumer.huawei.com/en/support/d ... /index.htm
duronus
Tue Sep 22, 2015 1:57 pm
Good day, i have a LTE modem ZTE MF831 4G LTE USB Modem but firmware 6.32.2 doesn't recognise it, possible to run on mikrotik, and what do I need to do?
info from resurce USB ---Vendor ID 0x19d2 Device ID 0x1225 serial number MF8310ZTED000000CP261718HNL0ZVY1TGG47X8_8_6D74&&&&&&&&&&&&&&&&&0
Добрый день, есть LTE модем ZTE MF831 4G LTE, на прошивке 6.32.2 модем виден в USB судя по диоду подключается к сети (переходит на синий) но не виден в LTE есть ли возможность его запустить и если есть что для этого нужно
duronus
Tue Sep 22, 2015 7:30 pm
I have connect this in my mikrotik RB951G-2HnD and modem is work, but in 3g network? posseble in 4g need more
milliwatts
Я попробывал этот модем на RB951G-2HnD и он заработал, но у меня только 3G сеть возможно для работы в 4G нужно больше тока?
duronus
Wed Sep 23, 2015 2:08 pm
Now modem working is ok, helped complete shutdown of the device
aforster
Tue May 31, 2016 5:16 am
Any news on supporting E3276?
Thanks.
Senux
Tue May 31, 2016 11:51 pm
Thanks.
Huawei E3276s in stick mode is working with RB951G-2HnD with version 6.xxx as PPP client. Additional USB power must be used, etc. powered USB hub. Biggest problem is with weak Mikrotik power supply over USB port.
Rokoch
Wed Feb 27, 2019 2:28 pm
Hello
I have Huawei E3276s-150 modem and when I connect this to the mikrotik router then it see it but I couldn't connect. In log I can see:
usb3:0: sent +++
usb3:0: sent ATH
What could be wrong?
Please help me.
Rokoch
Sun Mar 03, 2019 7:49 pm
I resolved my problem.
My modem is E3276s-150 in stick mode.
For correct modem works we need to change mode of this device to modem mode.
For do that we need put our Huawei E3276s-150 to the mikrotik or any computer USB port and then connect with them by serial port using terminal.
In example on routerboard when we put Huawei to the USB port and use winbox->New Terminal, we should check which port of the usb use our device:
/system resource usb print
/port print
(In my option that was usb1)
Next we need to use terminal. (Tip: When we got this message: "failure: port's channel is already in use" the we should disable ppp-outX interface i.e. /interface ppp-client disable ppp-out1 or just choose diferent channel fo terminal connect i.e. ) /system serial usb1 channel=1. Be sure you have disable automatic sms receive (/tool sms set receive-enabled=no) and you don't have run info on /interface...
So we run terminal:
/system serial usb1
Now we can check if we are properly connected by typing AT and confirm by ENTER. We should got feedback: OK
Enter: AT
Respone: OK
Now I suggest to check and save our actual configuration of modem typing AT^SETPORT? (I found the default is ^SETPORT:A1,A2;10,12,16,A1,A2):
Enter: AT^SETPORT?
Respone: ^SETPORT:A1,A2;10,12,16,A1,A2
Now we change mode to modem mode, typing:
Enter: AT^SETPORT="A1,A2;10,12,13"
Respone: ^SETPORT:A1,A2;10,12,13 (something like that)
I suggest to set forcing network operation by device to "first LTE when LTE isn't avilable then switch to 3G". We can check our actual configuration typing AT^SYSCFGEX?. Be careful with commas (two) on the end because they are important.
So we set forcing netwrok:
Enter: AT^SYSCFGEX="0302",3FFFFFFF,1,2,800C5,,
Respone: ^SYSCFGEX:"0302",3FFFFFFF,1,2,800C5,, (something like that)
Now we need to restart our modem. We can do that using command or just unplug and plug back modem to the usb port. This is command:
AT^reset
Now we can close console typing Ctrl+A next Q.
Useful commands:
AT^SETPORT=? - show available modes
AT^SYSCFG=? - show available system mode, GW access sequence, band, roaming support and domain.
I'm a little surprised that information wasn't write on Mikrotik wiki (Manual:Peripherals) for Huawei E3276-150.
Based on websites:
http://4pda.ru/forum/index.php?showtopic=582284&st=600
https://superuser.com/questions/586049/ ... tl8CBkWM1o
https://papa-admin.ru/mikrotik/86-mikro ... 150-1.html
http://www.mariuszdybala.cba.pl/artykul ... e3276.html
https://gist.github.com/artizirk/20acc2ab07fe6cad9fcc
https://vutlan.atlassian.net/wiki/space ... ms+setting
P.S My modem(E3276s-150) works on 951G-2HnD without any additional USB power hub. But I'm testing it for a short time so I don't sure about this in a future work.
pavlov
Sat Apr 27, 2019 2:26 am
Thank you man, now my modem e3276s-151 works with mikrotik
Users browsing this forum: Bing [Bot], biravaian and 75 guests
