MUM Europe 2020
Automatic
Can only use Eth1 as a gatway?
Sun Mar 24, 2013 11:15 pm
I recently bought a "RB201 1UAS-2HnD-IN" routerboard router off you guys, however, I notice that if I use eth1 to connect to the modem (With the default configuration) I can connect fine (As I am now), however, if I am to unplug the modem from eth1 and plug it into eth2, and change the DHCP client respectively, it connects to the DHCP client but can't get any internet access.
Can I ask why? What option marks a port as "network worthy"? Only issue with this is that Eth1-5 seem to be the only gigabit ports and I'd prefer to not waste eth1 on a 25Mbit connection. I've also looked under "Interfaces" and there seems to be no differences in options, although, I don't see any options. I'm very new to this software so I'm not really sure what configuration pages you'd like to see, if you want to see any page, feel free to ask and I'll post a screen shot.
nmaton
Re: Can only use Eth1 as a gatway?
Sun Mar 24, 2013 11:51 pm
you should check in ip firewall nat
the masquerade rule should be corrected to the outgoing (wan) interface.
Nicolas Maton
nicolasmaton@gmail.com
CCNA/ CCDA
MTCNA / MTCTCE
Available for Mikrotik Consulting
Automatic
Mon Mar 25, 2013 12:47 am
Replying to you using Eth10, thanks so much.
Users browsing this forum: No registered users and 31 guests
