MUM Europe 2020
majkel
Dealing with massive DDoS
Tue Mar 26, 2013 12:11 pm
Hello :)
I need help with optimization of my firewall rules.. I have CCR 1036 with 14Gbit of band
When I get ddos atack on UDP everything is grate.. I observed attack near 8Gbit and Cpu of all cores was mayby 5%
The problem is when I get ddos attack on TCP..
on attacks near 500mbit the all cores using 100% cpu..
on 250mbit - about 50%
on 50mbit attack 10%
Can someone help me with this?
TCP syncookes are enabled in firewall connection tracking.
Thenk u
7 ;;; Blokada UDP Port 80
chain=forward action=drop protocol=udp port=80
8 chain=input action=accept src-address=80.72.*.*
9 ;;; White Lista
chain=forward action=accept src-address-list=white_list dst-address-list=""
10 ;;; accept established connection packets
chain=input action=accept connection-state=established
11 ;;; accept related connection packets
chain=input action=accept connection-state=related
12 ;;; drop invalid packets
chain=input action=drop connection-state=invalid
13 ;;; detect and drop port scan connections
chain=input action=drop protocol=tcp psd=21,3s,3,1
14 ;;; suppress DoS attack
chain=input action=tarpit protocol=tcp src-address-list=black_list connection-limit=3,32
15 ;;; detect DoS attack
chain=input action=add-src-to-address-list protocol=tcp address-list=black_list address-list-timeout=1d connection-limit=100,32
16 ;;; jump to chain ICMP
chain=input action=jump jump-target=ICMP protocol=icmp
17 ;;; jump to chain services
chain=input action=jump jump-target=services
18 ;;; Allow Broadcast Traffic
chain=input action=accept dst-address-type=broadcast
19 chain=input action=log log-prefix="Filter:"
20 ;;; 0:0 and limit for 5pac/s
chain=ICMP action=accept protocol=icmp icmp-options=0:0-255 limit=5,5
21 ;;; 3:3 and limit for 5pac/s
chain=ICMP action=accept protocol=icmp icmp-options=3:3 limit=5,5
22 ;;; 3:4 and limit for 5pac/s
chain=ICMP action=accept protocol=icmp icmp-options=3:4 limit=5,5
23 ;;; 8:0 and limit for 5pac/s
chain=ICMP action=accept protocol=icmp icmp-options=8:0-255 limit=5,5
24 ;;; 11:0 and limit for 5pac/s
chain=ICMP action=accept protocol=icmp icmp-options=11:0-255 limit=5,5
25 ;;; drop everything else
26 ;;; Drop everything else
chain=ICMP action=drop protocol=icmp
27 ;;; accept localhost
chain=services action=accept dst-address=127.0.0.1 src-address-list=127.0.0.1
28 ;;; allow MACwinbox
chain=services action=accept protocol=udp dst-port=20561
29 ;;; allow winbox
chain=services action=accept protocol=tcp dst-port=8291
30 ;;; MT API
chain=services action=accept protocol=tcp dst-port=8728
31 ;;; MT Discovery Protocol
chain=services action=accept protocol=udp dst-port=5678
32 ;;; allow SNMP
chain=services action=accept protocol=tcp dst-port=161
33 ;;; allow DNS request
chain=services action=accept protocol=tcp dst-port=53
34 ;;; Web
chain=services action=accept protocol=tcp dst-port=2222
35 ;;; Allow DNS request
chain=services action=accept protocol=udp dst-port=53
36 chain=services action=return
37 ;;; ETOP DNS
chain=forward action=accept src-address-list=ETOP
38 ;;; ETOP DNS
chain=forward action=accept dst-address-list=ETOP
39 ;;; allow related connections
chain=forward action=accept connection-state=related
40 ;;; Prawid owe pakiety
chain=forward action=accept connection-state=established
41 ;;; drop invalid connections
chain=forward action=drop connection-state=invalid
42 ;;; SYN Flood protect
chain=forward action=jump jump-target=SYN-Protect tcp-flags=syn connection-state=new protocol=tcp
43 chain=SYN-Protect action=accept tcp-flags=syn connection-state=new protocol=tcp limit=1000,100 dst-limit=0,5,dst-address/1m40s
44 chain=SYN-Protect action=drop tcp-flags=syn connection-state=new protocol=tcp
45 chain=forward action=jump jump-target=detect-ddos connection-state=new
46 chain=forward action=log connection-state=new hotspot="" log-prefix="ddos_udp:"
47 chain=detect-ddos_TCP action=return dst-limit=30/1m,5,src-and-dst-addresses/10s
48 ;;; packet size 500-65000
chain=detect-ddos action=add-src-to-address-list address-list=ddoser address-list-timeout=1h packet-size=500-65000
49 ;;; Rate limit UDP
chain=detect-ddos action=return dst-limit=30/1m,5,src-and-dst-addresses/10s
50 chain=detect-ddos action=return src-address=80.72.*.*
51 chain=detect-ddos action=return src-address=80.72.*.*
52 chain=detect-ddos action=add-dst-to-address-list address-list=ddosed address-list-timeout=10h30m
53 chain=detect-ddos action=add-src-to-address-list address-list=ddoser address-list-timeout=10h
54 ;;; Drop from ddoser-list
chain=forward action=drop src-address-list=ddoser dst-address-list=ddosed
55 chain=forward action=drop connection-state=new src-address-list=ddoser dst-address-list=ddosed
Chupaka
Re: Dealing with massive DDoS
Wed Mar 27, 2013 10:51 pm
please read my topic http://forum.mikrotik.com/viewtopic.php?f=2&t=54607 about ddos and 'connection-limit' :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
raz
Mon Apr 01, 2013 3:01 pm
The Connlimit will not help, it seems that is there a Problem with spoofed Source IPs, yes there a lot of DC's they allow this...
The Problem is here SYN, called from the Scriptkiddies "Super Syn"... Here is an Example, what they are using:
    iph->ihl = 5;
    iph->version = 4;
    iph->tos = 0;
    iph->tot_len = sizeof (struct ip) + sizeof (struct tcphdr);
    iph->id = htonl (54321);
    iph->frag_off = 0;
    iph->ttl = 255;
    iph->protocol = IPPROTO_TCP;
    iph->check = 0;
    iph->saddr = inet_addr(ip);
    iph->daddr = sin.sin_addr.s_addr;
    iph->check = csum ((unsigned short *) packet, iph->tot_len >> 1);
    tcph->source = htons (1234);
    tcph->dest = htons (80);
    tcph->seq = 0;
    tcph->ack_seq = 0;
    tcph->doff = 5;
    tcph->fin=0;
    tcph->syn=1;
    tcph->rst=0;
    tcph->psh=0;
    tcph->ack=0;
    tcph->urg=0;
    tcph->window = htons (5840);
    tcph->check = 0;/* We fill this in later */
    tcph->urg_ptr = 0;
This Script kills the strongest CCR in 30 Seconds without filtering.
You see the Flags? Create a Filter and Filter the Scheme of these Attacker Packets. So i can filter up to 500k pps (!) on my CCR. I only run there BGP and my Bandwith is average 100-150 MBit's. My best was around 900 MBit SYN, with 50-60% CPU Usage, but the Attackers used always the same Packet:
0000: d4 ca 6d 77 7f a3 84 18  88 06 10 52 08 00 45 00  ..mw.... ...R..E.
0010: 02 1c 28 c8 00 00 3d 06  5d 65 34 3a fe 27 05 53  ..(...=. ]e4:.'.S
0020: bd fa 99 40 00 50 15 ab  3d bb 1b be 46 2e 50 02  ...@.P.. =...F.P.
0030: 00 40 22 d6 00 00 58 58  58 58 58 58 58 58 58 58  .@"...XX XXXXXXXX
0040: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0050: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0060: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0070: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0080: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0090: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
00a0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
00b0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
00c0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
00d0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
00e0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
00f0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0100: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0110: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0120: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0130: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0140: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0150: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0160: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0170: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0180: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0190: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
01a0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
01b0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
01c0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
01d0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
01e0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
01f0: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0200: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0210: 58 58 58 58 58 58 58 58  58 58 58 58 58 58 58 58  XXXXXXXX XXXXXXXX
0220: 58 58 58 58 58 58 58 58  58 58                    XXXXXXXX XX
The Problem is with Microtik it isnt possible Packets specified by length.
tshark tcp port 80
0.787910 151.46.220.237 -> { MY IP } TCP 37424 > http [SYN] Seq=0 Win=512 Len=0
0.787913 151.46.220.244 -> { MY IP } TCP 36658 > http [SYN] Seq=0 Win=512 Len=0
0.787915 151.46.220.245 -> { MY IP } TCP 19989 > http [SYN] Seq=0 Win=512 Len=0
0.787917 151.46.220.243 -> { MY IP } TCP 25404 > http [SYN] Seq=0 Win=512 Len=0
In this Case of DDoS you have to search for Patterns, and yes its a Game you have always to change something on your /ip firewall, because Attackers changed Parameters.
majkel
Sat Apr 13, 2013 9:47 am
raz Can you contact with me? michal@skyblue.pl ?
raz
Sat Apr 13, 2013 4:35 pm
i sent you a Mail :-)
tgrand
Long time Member
Long time Member
Sat Apr 20, 2013 6:27 pm
Wow we took an attack at 800Mbps UDP port 0.
Only way to combat, is to have the attacked on your local address space blocked further upstream.
Users browsing this forum: Bing [Bot], marcos512 and 42 guests
