Thalid
low throughput
Sun Mar 31, 2013 11:48 pm
i have an 435c whit two R52Hn cards.
One of these R52Hn is setup as an ap on the 2.4 band the other is disabled atm My goal is to create up to max 24 virtual aps one for eash household whit maybe 3 ore 4 client on a 100mbit fiber link.
But at the testing stat on in now is that i only get a troughput of around 300kb/s this half the speed of what my current internet connectiton ewen just 3 feet away from the ap
I tryd mixing whit nstreme but that dint do anything.
noise is -113 dBm
before 5.24 it was 5.22
firmware 3.02 se some people have 3.04 on other rb modell
so atm i got this config
[admin@MikroTik] > export
# mar/31/2013 16:38:45 by RouterOS 5.24
# software id = 9TZB-W636
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    disabled=no forward-delay=15s l2mtu=1520 max-message-age=20s mtu=1500 \
    name=bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:9D:3D:1A \
    master-port=none mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:9D:3D:1B \
    master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:9D:3D:1C \
    master-port=none mtu=1500 name=ether3 speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1 switch-all-ports=yes
set [ find default=yes ] authentication-types="" eap-methods=passthrough \
    group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
    management-protection=disabled management-protection-key="" mode=none \
    name=default radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled \
    radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
    static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
    none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
    static-sta-private-algo=none static-sta-private-key="" \
    static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
    none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=\
    "" wpa2-pre-shared-key=""
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
    aes-ccm group-key-update=5m interim-update=0s management-protection=\
    allowed management-protection-key="" mode=dynamic-keys name=S6 \
    static-transmit-key=key-0 supplicant-identity="" tls-certificate=none \
    Somekey wpa2-pre-shared-key=Somekey
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" \
    arp=enabled band=2ghz-b/g/n basic-rates-a/g=6Mbps basic-rates-b=1Mbps \
    bridge-mode=enabled channel-width=20mhz compression=no country=\
    no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
    disable-running-check=no disabled=no disconnect-timeout=3s distance=\
    dynamic frame-lifetime=0 frequency=2412 frequency-mode=manual-txpower \
    frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 \
    ht-amsdu-threshold=8192 ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any \
    ht-rxchains=0 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,\
    mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,\
    mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0 \
    hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=\
    00:0C:42:6C:7C:AC max-station-count=2007 mode=ap-bridge mtu=1500 \
    multicast-helper=default name="Wireless 1" noise-floor-threshold=default \
    nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" \
    nv2-qos=default nv2-queue-count=2 nv2-security=disabled \
    on-fail-retry-time=100ms periodic-calibration=default \
    periodic-calibration-interval=60 preamble-mode=both \
    proprietary-extensions=post-2.9.25 radio-name=000C426C7CAC \
    rate-selection=legacy rate-set=default scan-list=default \
    security-profile=S6 ssid=MikroTik station-bridge-clone-mac=\
    00:00:00:00:00:00 supported-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
    1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default \
    update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
    none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
    wireless-protocol=any wmm-support=disabled
add area="" arp=enabled bridge-mode=enabled default-ap-tx-limit=0 \
    default-authentication=yes default-client-tx-limit=0 default-forwarding=\
    yes disable-running-check=no disabled=no hide-ssid=no l2mtu=2290 \
    mac-address=02:0C:42:6C:7C:AC master-interface="Wireless 1" \
    max-station-count=2007 mtu=1500 multicast-helper=default name=Test2 \
    proprietary-extensions=post-2.9.25 security-profile=S6 ssid=Testtttt \
set 2 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" \
    arp=enabled band=5ghz-a basic-rates-a/g=6Mbps basic-rates-b=1Mbps \
    disable-running-check=no disabled=yes disconnect-timeout=3s distance=\
    dynamic frame-lifetime=0 frequency=5180 frequency-mode=manual-txpower \
    D4:CA:6D:10:31:10 max-station-count=2007 mode=ap-bridge mtu=1500 \
    multicast-helper=default name="Wireless 2" noise-floor-threshold=default \
    proprietary-extensions=post-2.9.25 radio-name=D4CA6D103110 \
    rate-selection=advanced rate-set=default scan-list=default \
    security-profile=default ssid=MikroTik station-bridge-clone-mac=\
    wireless-protocol=unspecified wmm-support=disabled
/interface wireless manual-tx-power-table
set "Wireless 1" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbp\
    s:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,\
    HT20-0:17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20\
    -7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:1\
    7,HT40-7:17"
set "Wireless 2" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbp\
    7,HT40-7:17"
/interface wireless nstreme
set "Wireless 1" disable-csma=no enable-nstreme=no enable-polling=yes \
    framer-limit=3200 framer-policy=none
set "Wireless 2" disable-csma=no enable-nstreme=no enable-polling=yes \
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
    hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
    cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 \
    split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default \
    shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
    lifetime=30m name=default pfs-group=modp1024
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \
    stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default \
    remote-ipv6-prefix-pool=none use-compression=default use-encryption=\
    default use-ipv6=yes use-mpls=default use-vj-compression=default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
    remote-ipv6-prefix-pool=none use-compression=default use-encryption=yes \
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
    red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=\
    ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
    metric-other-ospf=auto metric-rip=20 metric-static=20 name=default \
    out-filter=ospf-out redistribute-bgp=no redistribute-connected=no \
    redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
    router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
    backbone type=default
/routing ospf-v3 instance
set [ find default=yes ] disabled=no distribute-default=never metric-bgp=auto \
    metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 \
    metric-static=20 name=default redistribute-bgp=no redistribute-connected=\
    no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
    router-id=0.0.0.0
/routing ospf-v3 area
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password="" \
    authentication-protocol=MD5 encryption-password="" encryption-protocol=\
    DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=:: remote-port=514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password="" \
    paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
    permissions=owner signup-allowed=no time-zone=-00:00
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
    eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
    ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
    winbox,password,web,sniff,sensitive,api" skin=default
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none \
    interface=ether1 path-cost=10 point-to-point=auto priority=0x80
    interface=ether2 path-cost=10 point-to-point=auto priority=0x80
    interface=ether3 path-cost=10 point-to-point=auto priority=0x80
    interface="Wireless 1" path-cost=10 point-to-point=auto priority=0x80
    interface=Test2 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
    no
set 0 vlan-header=leave-as-is vlan-mode=fallback
set 1 vlan-header=leave-as-is vlan-mode=fallback
set 2 vlan-header=leave-as-is vlan-mode=fallback
set 3 vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
    default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=\
    1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
    default enabled=no keepalive-timeout=60 mac-address=FE:B7:66:A9:82:F7 \
    max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
    default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
    disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
    00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
    frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
    multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
    no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.5.1.48/24 comment="default configuration" disabled=no \
    interface=ether1 network=10.5.1.0
add address=10.5.1.49/24 disabled=no interface="Wireless 1" network=10.5.1.0
/ip dhcp-client
add add-default-route=yes default-route-distance=0 disabled=no host-name=\
    Mikrotik interface=ether1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-relay
add delay-threshold=none dhcp-server=10.5.1.1 disabled=no interface=ether1 \
    local-address=0.0.0.0 name=relay1
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=512 servers=8.8.8.8,8.8.4.4
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set "Wireless 1" disabled=yes
set Test2 disabled=yes
set "Wireless 2" disabled=yes
set bridge1 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
    600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
    0.0.0.0
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
    all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
    max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ipv6 nd
set [ find default=yes ] advertise-dns=no advertise-mac-address=yes disabled=\
    no hop-limit=unspecified interface=all managed-address-configuration=no \
    mtu=unspecified other-configuration=no ra-delay=3s ra-interval=3m20s-10m \
    ra-lifetime=30m reachable-time=unspecified retransmit-interval=\
    unspecified
/ipv6 nd prefix default
set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set "Wireless 1" queue=wireless-default
set Test2 queue=wireless-default
set "Wireless 2" queue=wireless-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
    multiplier=5
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing pim
set switch-to-spt=yes switch-to-spt-bytes=0 switch-to-spt-interval=1m40s
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
/routing ripng
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
    trap-target="" trap-version=1
/system clock
set time-zone-name=Europe/Oslo
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
/system gps
set channel=0 enabled=no set-system-time=no
/system health
set fan-mode=auto use-fan=main
/system identity
set name=MikroTik
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set "Wireless 2" disabled=yes display-time=5s
set Test2 disabled=yes display-time=5s
set "Wireless 1" disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=129.6.15.28 secondary-ntp=\
    128.2.136.71
/system ntp server
set broadcast=no broadcast-addresses="" enabled=no manycast=yes multicast=no
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
    boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes \
    enter-setup-on=any-key force-backup-booter=no silent-boot=no
/system script
add name=script1 policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
    source=""
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol=\
    "" filter-mac-address="" filter-mac-protocol="" filter-port="" \
    filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes \
    only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
    use-radius=no
[admin@MikroTik] >
Thalid
Re: low throughput
Mon Apr 01, 2013 12:16 am
Thalid
Re: low throughput
Tue Apr 02, 2013 6:29 pm
Did some bandwitch test from other sources`s then the first
http from my web server same network 12mbit
online bandwitch test from tptest.se 6.01 mbit this value is correct as i only have 5 to 6.5 connection atm.
Kristian
Thalid
Re: low throughput
Sun Apr 07, 2013 9:40 pm
been mixing around whit alot of settings after reading several posts but none seems to help :?
what puzzels the most is that the bandwith test gives me he corect troughtput when testing my internet but still i cant download whit moore then 300kbs :shock:
Users browsing this forum: No registered users and 23 guests
