MUM Europe 2020
jbaird
The Dude causes high CPU usage on routers
Fri Apr 05, 2013 3:46 pm
Several routers running 5.21-5.24 (RB450G) here. After adding the device to The Dude via SNMP, the CPU usage on all of these routers goes to 99-100%. The profiler tool on the routers says the usage is attributed to the "Management" process which I am assuming is SNMP.
Has anyone noticed this? Any fix?
Thanks.
lebowski
Re: The Dude causes high CPU usage on routers
Fri Apr 05, 2013 5:42 pm
On devices with large routing tables you need to tell the device to not respond to SNMP queries for routing tables.
I am on Cisco so I can't give you the command and I don't know if one exists. The commands for Cisco are like...
snmp-server view cutdown iso included
snmp-server view cutdown at excluded
snmp-server view cutdown internet.6.3.15 excluded
snmp-server view cutdown internet.6.3.16 excluded
snmp-server view cutdown internet.6.3.18 excluded
snmp-server view cutdown ip.21 excluded
snmp-server view cutdown ip.22 excluded
I have put these on my BGP internet connected routers to lower SNMP walk CPU.
HTH,
Lebowski
jbaird
Fri Apr 05, 2013 5:54 pm
That does make sense, but these routers do not have large routing tables.
Users browsing this forum: No registered users and 11 guests
