magnavox
Strange Error "not acceptable for security profile...."
Sat Apr 06, 2013 11:15 am
Strange Wireless error
"not acceptable for security profile: does not provide privacy as profile requires "
The key are the same...
kreylor
Re: Strange Error "not acceptable for security profile...."
Mon Jun 24, 2013 11:57 pm
BUMP!!
magnavox
Tue Jun 25, 2013 12:03 am
Hello, any news?
kreylor
Wed Jun 26, 2013 12:22 am
I have fixed this problem on my setup. In the security profile tab I setup a new profile with wpa aes-ccm and put that on the wlan interface. I did this on both sides of the connection. I thought it was supposed to use that profile. Well I was wrong. In the connect list tab is where I needed to select the profile. Once I did this at both ends, they connected.
magnavox
Wed Jun 26, 2013 1:00 am
I tried. This not work in my setup.
AndreyRa
Thu Dec 29, 2022 12:39 pm
Enabling tkip in security profile helped me with the same problem.
mkx
Thu Dec 29, 2022 12:55 pm
For google only ... (thread was burried for ages, seems somebody managed to dig it ... but it needs some sensible information in case somebody else comes by).
One has to know standard combinations: WPA goes with TKIP ... and WPA2 goes with AES-CCM ... No other combination is standard so basically don't try to use them (unless you hate yourself). And unless you have ancient clients in your wireless network, just skip WPA+TKIP combo and go for WPA2+AES-CCM combo only.
