davit2020
SSL connection error in my RB 751G
Thu Apr 11, 2013 5:29 pm
after configuration of my RB 751g Hotspot I had the following on lunching a web browser to browse
Unable to make a secure connection to the server. This may be a problem with the server,
or it may be requiring a client authentication certificate that you don't have.
Error 107 (net::ERR_SSL_PROTOCOL_ERROR): SSL protocol error.
Sigma721
Re: SSL connection error in my RB 751G
Sat Aug 03, 2013 7:29 pm
I have the same issue, only have a solution?
SurferTim
Sun Aug 04, 2013 1:36 pm
Do you have a SSL certificate installed in that router? If not, you should use "select certificate=none" in the hotspot setup.
Sigma721
Sun Aug 04, 2013 3:12 pm
Hi
The hotspot was set up using the selection "SSL - None"(attached a screenshot).
If a user connects to the hotspot and is not redirected to the login page(which normally happens on smart phones and tablets), then the user usually types in Google(which is a SSL site) in their browser they get an SSL error instead of the hotspot login page.
Anyway around this?
Regards
SurferTim
Sun Aug 04, 2013 3:17 pm
I have not found a way around that. The original request prior to login must be unsecured port 80.
chris84
Wed Dec 11, 2013 10:38 am
I ran into the same problem, did you solve it?
regards
Sigma721
Wed Dec 11, 2013 5:48 pm
No unfortunately not, and it looks real bad to clients. I hope Mikrotik can fix this soon!
TheWiFiGuy
Wed Dec 11, 2013 11:46 pm
set a static dns entry to force google to not be ssl - google non-ssl.
Mikrotik Consultant.
MTCNA, MTWCE, MTCTCE, MTCRE, MTCINE
Sigma721
Tue Apr 01, 2014 12:35 am
Thanks for the tip, can you explain how to do this?
Users browsing this forum: safik and 76 guests
