zlojadmin
Tagged VLANs
Fri Apr 12, 2013 12:27 pm
Hi!
I need to send tagged traffic via Wireless link from Omitik to two SXT's and untag one of VLANs on SXT's ethernet port. Second VLAN, that is send to SXT is used as management networt for device itself.
switch --VLAN 21,253 tagged---> Omnitik Eth1 (IP in VL253 for management) --> Wireless --> SXT (IP in VL253 for management) --> VL21 untagged on Eth port --> PC
Diagram in attachment
PS: can not use multiple cables for Omnitik. It seats on the top of the roof with no real access to it without crane :)
samsung172
Re: Tagged VLANs
Sat Apr 13, 2013 1:28 am
Put in wds mode, and "what goes in goes out".
zlojadmin
Re: Tagged VLANs
Wed Apr 17, 2013 2:50 pm
i need to "keep" VLAN253 traffic on device for management and untag VLAN21 traffic on SXT to connect 1 PC directly to it's LAN port. Manageable switch is not foreseen on SXT side to untag the traffic....
Jorbu
Re: Tagged VLANs
Thu Apr 18, 2013 10:26 am
Could you post the current sxt config?
Jorbu
Re: Tagged VLANs
Thu Apr 18, 2013 10:28 am
Have you tried bridging vlan21 to the ether1 on the sxt? If you run torch and activate the vlan monitoring option do you see tagged traffic on the ptplink?
Users browsing this forum: Shy and 43 guests
