JCesar
Deployment Guideliness 400+ suscribers at tech conference
Sun Apr 21, 2013 9:55 am
Hello
I'm organizing a hackathon for mobile developers with 400+ wireless device. Could you please recommend guideliness about equipement,setup?
Area : 6060 ft²
Suscribers: 200 Developers, 400+ devices (smartphone, laptop, tablet,etc)
Ussage Needs: web, social media , e-mail
priority low needs: video streaming sites , music streaming , p2p, downloads
isp: 20 Mbps :(
i was thinking on:
- Mikrotik x86 lv6 hotspot, user manager , profiles
- ubiquiti Unifi equiment (2.4 Ghz)
Regards,
Ibersystems
Re: Deployment Guideliness 400+ suscribers at tech conferenc
Sun Apr 21, 2013 2:05 pm
Avoid ubiquity.
Use 433AH with 2.4GHz(n) and 5GHz(a). Use the minimum power possible. Use PCQ queues.
Martín Ruiz
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in:
MTCNA - MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE - MTCSE
TheWiFiGuy
Sun Apr 21, 2013 11:07 pm
There was some 3rd party testing of APs recently, Ubiquity UniFi broke down with the least number of clients first.
A single Ruckus AP could actually handle that if you believe their specs, but a couple of Ruckus units if you want to do it well, or even 10 or so 751's running low power. Clearly, keep the APs wired, not wireless, run them on seperate channels.
Check out the article here : http://wlanpros.com/WiFiStressTestReport if you are serious about providing high density wifi events.
Mikrotik Consultant.
MTCNA, MTWCE, MTCTCE, MTCRE, MTCINE
JCesar
Tue Apr 30, 2013 2:35 am
Avoid ubiquity.
por que Unifi no debe ser tomado como una opcion?
Después de leer esto http://goo.gl/LHgch pienso que necesitare al menos 13 ap (30 usuarios por AP) , no estaría desperdiciando el 433AH al usarlo solo como ap?
Sabes tu cual es la capacidad en usuarios que pudiera soportar solo un 433Ah?
Gracias por tu respuesta. Saludos
gotsprings
Forum Veteran
Forum Veteran
Tue Apr 30, 2013 5:25 am
6K sq/ft. 400 clients. Absolutely not on unifi.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
Users browsing this forum: Bing [Bot], sindy and 52 guests
