normis
v6rc14 released
Tue Apr 30, 2013 8:57 am
What's new in 6.0rc14 (2013-Apr-24 11:52):
*) route - make connected routes inactive when interface has no link;
*) ipsec - changing or removing unused peer or proposal config won't flush active SAs;
*) console - add 'without-paging' to more 'print' commands;
*) route - automatically repair FIB inconsistencies;
*) ipsec mode-cfg - unity split include support;
*) ipsec policy - template matching for policy generation;
*) metarouter: fixed occasional lockups on mipsbe boards;
*) fixed crash when bridge filter rule had action=return for rule in builtin chain;
*) traffic-flow - fixed deadlock and crash on multicore;
*) fixed memory leak on CCR with PPPoE interfaces;
*) improved PPPoE interface encapsulation performance;
*) fixed queues - total amount of traffic passing through queues sometimes was about 1Gbit;
zanetti
Re: v6rc14 released
Tue Apr 30, 2013 10:06 am
Upgraded an RB2011L from rc13 to 14. DHCP Client and DHCP Server would not issue to or bind to addresses. Downgraded to 5.24, all is back to normal.
leoktv
Trainer
Trainer
Re: v6rc14 released
Tue Apr 30, 2013 11:04 am
HI i can confirm this problem.
_________________
Leo De Geer, Mikrotik Certified Consultant/Trainer #TR0003, MTCNA, MTCRE, MTCWE, MTCTCE, MTCINE, MTCUME, MTCIPv6E MTCSE MTCASE MTCSWE & MikroTik Distributor
http://www.mikrotik.se
support[at]mikrotik.se
Office: +46 325 660 650
elgrandiegote
Re: v6rc14 released
Tue Apr 30, 2013 3:46 pm
send backup by mail script, still does not work, in the v6rc11 version works fine...
any news on this?
mrz
Re: v6rc14 released
Tue Apr 30, 2013 3:49 pm
any news on this?
Debug your script which part of it exactly is not working.
DirectX9
Re: v6rc14 released
Tue Apr 30, 2013 4:12 pm
Hi Normis
Very nice to see the updated ROS 6rc14
Very interesting bug with Atheros 9344. What's new in 3.07 firmware
Only one question - and when we can change the DTIM interval for SSID (default is 1 and cannot be changed by software - no option) to 2 or higher?
A lot of client side devices looses the battery power very fast because of Mikrotik DTIM is selected 1.
In 5.25 release I had asked the same before.
Please answer.
DirectX9
BETEPAH
Re: v6rc14 released
Tue Apr 30, 2013 4:53 pm
Bug with SNMP not fixed.
jozwiak
Re: v6rc14 released
Tue Apr 30, 2013 5:11 pm
Problem with IPsec Peer and "Generate policy" Not working.
Downgraded til v6rc13 and it worked again
raz
Re: v6rc14 released
Tue Apr 30, 2013 5:37 pm
Im running rc14 since few Days, MT made here a good Job.
Thanks also for fixing this traffic-flow Deadlock.
btw: Is there a Model planned with Dual CPU? or 72 Core tilegx?
fsfranco
Re: v6rc14 released
Tue Apr 30, 2013 9:23 pm
After for Release 6rcv14 Update, i am lost connection in RB 1100AHx2
Connection via console, reset-configuration and downgrade for version 6rcv13.
Its Work OK!!
[]s
Franco
majkel
Re: v6rc14 released
Wed May 01, 2013 9:57 am
BUG on RC14 Official from 24/Apr ~~11:00 on CCR 1036
There is big CPU usage of Profiling (5-6% of all cores)
This bug doesnt exist in pre-release version of rc14 from Apr/23/2013 16:37:18
check this..
majkel
Re: v6rc14 released
Wed May 01, 2013 10:03 am
why 2CPU ? 72 cores?
THere still NO OPTIMIZATION on 36 cores and you wont 2 CPU or 72 cores?
any ddos on TCP attack about 400mbit killing CCR in two seconds.. and for me I need to buy some another firewall.. becouse ccr are useless
NetworkPro
Re: v6rc14 released
Wed May 01, 2013 10:58 am
Intel PRO/1000 (e1000?) VLAN tagging fail :)
2 device="02:01.0" name="82547EI Gigabit Ethernet Controller (rev: 0)"
vendor="Intel Corporation" category="Ethernet controller"
vendor-id="0x8086" device-id="0x1019"
(OnBoard Intel Server Board S875WP1-E http://downloadmirror.intel.com/19459/e ... 5WP1-E.zip)
Temporary workaround: create new bridge, put the problematic ether interface in that bridge. Add the VLANs with interface=that bridge so that bridge software would now be taking care of vlan tagging etc. instead of the NIC driver. (Note: the VLANs are not bridge ports of the mentioned bridge. They can be bridge ports of another bridge)
@MT I will send you the supout.rif file taken when problem is observed.
p.s. it may be vlan offload bug or otherwise Intel bug in my opinion !!!! (where MT could choose the driver, tweaks, they have in ROS, maybe NIC firmware or if they can - patch the damn driver (patching of NIC firmware is also a possibility))
P.S. 2: Intel PRO/1000 NIC driver in RouterOS 5.22 did not have this problem
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
honzam
Re: v6rc14 released
Wed May 01, 2013 11:59 am
All V6rc show bad frequency in LOG
LAN, FTTx, Wireless. ISP operator
odie
Re: v6rc14 released
Wed May 01, 2013 4:39 pm
after upgrade from rc13 no more connectivity via Vlan on RB1100AHx2
it is a shame that MT does not really test those releases !!!
i would like to get some money for testing and wasting time with this buggy stuf !
it seems that Mikrotik OS gets worse from release to release
sorry but i have enought !!
hey mikrotik why dont you try to fix all the errors first an then bring new features ????
onnoossendrijver
Re: v6rc14 released
Wed May 01, 2013 8:16 pm
That's the frequency in kilohertz, just like the atheros driver under linux reports it.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
raz
Re: v6rc14 released
Wed May 01, 2013 9:36 pm
Moar pps is what i need, and yes i would pay for that 2-3k $.
AsciiWolf
Re: v6rc14 released
Wed May 01, 2013 10:50 pm
It's not a final release which means it's not ready for production use! ;-)
odie
Re: v6rc14 released
Thu May 02, 2013 2:45 am
it is a release candidate for sure - but major things like Vlans should work....
and also with 5.24 we have even more sudden reboots of the boxes and no answers or fixes
and MT sell routers where you cant use a final ROS ( CCR )
osvaldotcf
Re: v6rc14 released
Thu May 02, 2013 4:07 am
Yes but is not a Beta!
This is a Release Candidate! and ... 14!!!!!
NetworkPro
Re: v6rc14 released
Thu May 02, 2013 4:43 am
So what big deal with the naming? Are you going to explain what the problem is and CONTRIBUTE or are you going to be annoyed and chatty on the forums?
Time to be annoyed has long passed. Nothing you can do about that.
nz_monkey
Re: v6rc14 released
Thu May 02, 2013 9:01 am
We are using vlans, bonding and vlans on bonding with no issues.
Are you sure your config is right?
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
odie
Re: v6rc14 released
Thu May 02, 2013 9:11 am
the config works until rc13....
seems to be not so wrong...
and also works on >100 other MT boxes
normis
Re: v6rc14 released
Thu May 02, 2013 9:12 am
please make a new topic and post "this config" that works only up to rc13. we will see what is so special about it.
odie
Re: v6rc14 released
Thu May 02, 2013 12:59 pm
sent it to support this morning !!
including supout
zyzelis
Re: v6rc14 released
Thu May 02, 2013 1:53 pm
Hello, i am using Vlans with RB1100AHx2 since 6.0rc11. And after upgrade from rc13 to rc14, Vlan's still working. :)
So i can't confirm this bug
normis
Re: v6rc14 released
Thu May 02, 2013 1:54 pm
please clarify what SNMP bug do you mean? did you contact support and report it?
napismizpravu
v6rc14 crash web-proxy
Thu May 02, 2013 8:07 pm
RB433UAH uptime 19h crash web-proxy (NAT forwarding off internet work)
Arnold2222
Re: v6rc14 released
Thu May 02, 2013 10:08 pm
For me also works fine. No any issues with vlans for now.
nz_monkey
Re: v6rc14 released
Thu May 02, 2013 11:35 pm
Hi Mikrotik staff,
I understand you are all very busy working on RouterOS. But can someone please look at Ticket#2013050266000072
It is regarding an issue with BGP pre-pends on RouterOS 6.
I also have Ticket#2013043066000404 open which may be related.
Thanks.
RafGan
Re: v6rc14 released
Thu May 02, 2013 11:41 pm
I confirm this issue on this same RouterBoard, plus forwarding on non-vilan ports losts many of packets (input is OK). Downgrade to 6RC13 and everything works great.
Best Regards,
GaR
Best Regards,
Raf G
samsung172
Re: v6rc14 released
Fri May 03, 2013 12:46 am
Seems like some of the problems around vrf are partly introduced in rc14. I cannot use it due to unstable router (hanging, not showing anny error in log etc. It also had a strange, not possible to start terminal from winbox. (wrong user password) teleneted from the link in, and it was ok. Something wired are back.
Also not yet fied the vrf bug route-distinguisher
Here there should be 0.0.0.0:0
ros code
/ip route vrf
add export-route-targets=0.0.0.0:0 import-route-targets=0.0.0.0:0 \
    route-distinguisher="(unknown)" routing-mark=vrf.internet
I have also had some troble mac-telnet from later releases of v6 and 5.xx to clients in nv2 mode. Is this a common problem? switching from nv2 to 802.11 solve the problem.
Also im missing good old preamble mode, ack-timeout etc make the setup of bad links easier.
Alessio Garavano
Re: v6rc14 released
Fri May 03, 2013 5:44 am
I found the solution to the VLAN problem on RB1100AHx2!
Upgrading an RB1100AHx2 with VLANs from rc13 to this rc14 the router was inaccesible, only connecting directly to the ether13 i can access by MAC in winbox and solve the problem changing the L2 MTU from 1598 to 1700 of the ether3 where are all the VLANs ;)
Best regards!
Alessio Garavano
http://www.isparg.com.ar
BETEPAH
Re: v6rc14 released
Fri May 03, 2013 10:34 am
No, I not contact support. I speak english very bad. Если говорят в саппорте по русски, то тогда смогу
описать проблему им очень подробно.
I have softrouter on server hardware PC. When I use 6.0rc11 graphics fine. When I upgrade to 6.0rc13:
normis
Re: v6rc14 released
Fri May 03, 2013 10:35 am
I have softrouter on server PC. When I use 6.0rc11 graphics fine. When I upgrade to 6.0rc13:
You can write in Russian. Some of our support enginers will be able to understand it. Please send full description so we can test.
hapi
Re: v6rc14 released
Fri May 03, 2013 10:38 am
CCR in bridge is fail. When it will be fixed?
normis
Re: v6rc14 released
Fri May 03, 2013 10:39 am
"bridge is fail" is not enough to understand your problem and fix it. please describe in more detail and send it to support.
hapi
Re: v6rc14 released
Fri May 03, 2013 11:02 am
insert 2 interface to bridge and let the traffic flow around 200Mbit. CCR is rebooted or totaly shutdown in time. half cores is running on 100%.
it says that a lot of people. You never tried it? CCR is totally unstable.
infused
Re: v6rc14 released
Fri May 03, 2013 2:40 pm
Not unstable... depends what your doing... high throughput yes, it seems.
hapi
Re: v6rc14 released
Fri May 03, 2013 3:04 pm
is unstable in bridge, dot. Throughput is 200Mbit.
normis
Re: v6rc14 released
Fri May 03, 2013 3:11 pm
I think you have a different understanding of word "unstable". You probably mean "slow"
We are looking at this issue
hapi
Re: v6rc14 released
Fri May 03, 2013 3:38 pm
no!! random rebooting or totally stop responding all router.
majkel
Re: v6rc14 released
Fri May 03, 2013 3:48 pm
Still there is no hope for TCP SYN Attacks..
u Can see CPU usage 50% and attack 160mbit?
We try everything.. The same we have with 4-5 rules..
cursixx
Re: v6rc14 released
Sat May 04, 2013 3:51 am
anyone notice a vpn performance drop? running l2tp
with rc13 I was getting around 400+kb
with rc14 100kb or less
zervan
Re: v6rc14 released - VLAN bug
Sat May 04, 2013 12:11 pm
I can confirm VLAN bug in RC14 on RB751G which is used as an AP with VLAN, see http://forum.mikrotik.com/viewtopic.php ... 73#p362473
After upgrade to RC14, I've lost connection to other AP on ether1, which should be tagged as VLAN11, so I've spent few hours to found out what's wrong. Here is what I've found...
  • I'm doing ARP ping on VLAN 11, packet should be received on the router, but they are not - see the screenshot, there is no VLAN 11 tag.
  • When I increase L2 MTU on the incoming VLAN port (from 1600 to any higher value), it starts to work - see the second screenshot.
  • I can change L2 MTU back, it is still working with any L2 MTU value.
  • After reboot it is not working again and it doesn't matter on the value of L2 MTU before the restart, until it is increased again.
Dusan Zervan from Slovakia
MTCNA, MTCRE
samsung172
Re: v6rc14 released
Sat May 04, 2013 9:05 pm
I did not say. I had to downgrade to rc13 and all was ok.
ros code
/ip route vrf
oriondotnet
Re: v6rc14 released
Sun May 05, 2013 9:13 pm
v6rc13 working with !MYSRCADD, and stop working on rc14, mean all drop
0 ;;; Drop to IP Phone
chain=forward action=drop dst-address=10.10.10.1 src-address-list=!MYSRCADD in-interface=sfp1
device on ccr 36 core
SaLMoN
Re: v6rc14 released
Mon May 06, 2013 1:47 pm
After upgrade to rc14 I'have lost DHCP Server config on RB133 and cannot setup it.
2fast4youbr
Re: v6rc14 released
Tue May 07, 2013 4:06 am
What happend with the HTML files of hotspot ? after I made the upgrade they vanished.
cheers
NetworkPro
Re: v6rc14 released
Tue May 07, 2013 6:48 am
cheers
You will have to copy them from elsewhere with different version or from a backup. In RC14 they are mysteriously missing.
2fast4youbr
Re: v6rc14 released
Tue May 07, 2013 6:55 am
thanks... just did.
cheers
Masyanich
Re: v6rc14 released
Tue May 07, 2013 10:01 am
any news on this?
lysy1033
Re: v6rc14 released
Tue May 07, 2013 2:11 pm
IPSEC over GRE doesnt work any more for me. I've got fatal INVALID-PAYLOAD-TYPE message in logs ipsec,debug.
When I downgrade packages to 6rc13 everything works just fine.
when needed i can post configs.
2fast4youbr
Re: v6rc14 released
Tue May 07, 2013 6:46 pm
Another problem... Looks like that the vLan routes should be done automatic , but I created 3 and the inter vlan comunnication is not working at all.
From any vlan I can ping any gateway, but not the host.
cheers
oxicid
Re: v6rc14 released
Wed May 08, 2013 2:28 am
Sorry, I posted in the wrong thread before by mistake.
Starting with version 6.0rc14 we found a bug regarding functioning SIP VoIP PBXs.
The problem occurs both with 3CX Phone System and Asterisk releases and with SIP devices.
It seems that the changes introduced at the level of NAT somehow cause the fall of the SIP call after a few minutes.
Note that all systems always operated with static port mapping service and SIP ALG disabled and have always worked properly from version 5.0 routeros.
Do Mikrotik introduced some changes at the level of Outbound NAT or Sip ALG (SIP firewall service) with 6rc14 ?
The problem was not present in the version 6.0rc13 and even in version 5.24.
In this situation it is impossible to properly operate an IP PBX behind routeros.
Please let me now something ?
For the moment we downgrade to 6rc13 and everything works fine.
NetworkPro
Re: v6rc14 released
Wed May 08, 2013 9:19 am
try connection tracking yes rather than auto and some "ip->settings" tweaks possibly as well
tkgit
Re: v6rc14 released
Thu May 09, 2013 2:21 am
running well on RB751u2HnD and RB433 with WDS mesh,OSPF routing
when stable version will be released?
2fast4youbr
Re: v6rc14 released
Thu May 09, 2013 5:28 am
Hi all, sorry for the duplicate post, but maybe could be something related to this new v6rc14.
Here is the original post: viewtopic.php?f=2&t=72494
When I have the vLans working on the switch, my mac and some other devices like wireless ap wrt54g don't get an IP address, the DHCP server sends NAK twice and after that only discover & offer without sucess. But with Win7 & Linux Ubuntu works fine.
When I take out the vLans and do a simple network (without vLans & Trunk), every body get an IP ....
I dont know if this is something with my switch (Linksys srw224g4) or with the RouterOS, looking that Win7 works and no one has talken about this on the forum, I am pretty sure that could be RouterOS 6rc14, hope not, I will try to do more tests.
Does any one know a good test to isolate this problem ? I've attached Wireshark to my switch and mirror'd the ports and filtered all by bootp, should I filter other kind package ? which one ?
Would the /export help here ?
cheers!
mark
Re: v6rc14 released
Thu May 09, 2013 7:19 pm
  • 6to4 interfaces stopped working. A first setup will work and, after modifying it—even reverting the changes or deleting everything altogether—, it will break and no connection will be made.
  • … routes to those interfaces are rejected (address not reachable or the like is the error message).
  • With about 1'000 connections or more bridge-local will disappear all of the sudden.
  • »torch« doesn't catch all packets that the interface graph does
  • no L2TP, PPTP or VPN in general to IPv6 — yet the first IPv6-only deployments are made here, in Germany (and years ago in Asia)
  • packets which should be stopped by the firewall are leaking through it (!) using PPTP
  • It seems I cannot get proper 300 Mbaud (802.11n) speeds with my RB951G-2HnD. 130 Mbaud is as most as I can get.
  • Using the web-interface and/or stand-alone client to ping an address will work, but re-using that window to ping another will sometimes result in a blank results list.
  • A plus (+) sign in local-part of email addresses still results in the »Incorrect Email« error.
If you like what I've posted and want to see more of that, then please say thank you by giving me karma.
Please do not contact me by PM or email.
HaPe
Re: v6rc14 released
Thu May 09, 2013 7:27 pm
MT has started to make rc15.
In anticipation on new The Dude release.
Stillhard
Re: v6rc14 released
Thu May 09, 2013 8:20 pm
Tested 6.0rc15, I can't hardly use it with 100% CPU usages almost every time, back to 6.0rc11 for now :?
majkel
Re: v6rc14 released
Thu May 09, 2013 9:56 pm
its started 29 april ;P
semenko
Re: v6rc14 released
Thu May 09, 2013 10:56 pm
Hey Mark -- I'm very interested in this problem.
Using an RB2011L-RM on 6.0rc14, I experience very intermittent (~weekly) loss of the router (completely unresponsive to ping, won't route traffic, etc.).
I'm wondering if this is an issue with our bridge-local interface disappearing -- for you, does the interface only disappear in the gui, or does the bridge itself seem to disappear & stop passing traffic?
HaPe
Re: v6rc14 released
Thu May 09, 2013 11:23 pm
Today morning there weren't any entries :)
mark
Re: v6rc14 released
Fri May 10, 2013 1:10 am
Bridge-local disappears in GUIs and traffic won't be passed after that happens; »unknown interface« (or the like) appears where you normally could read »bridge-local«.
I've lost connection to the next hop and have logged in immediately to learn what went wrong. I can only guess what would've happened if the error went unnoticed for hours. Maybe the device will not even respond to ARP requests and therefore appear completely unresponsive. It could be something other that you stumbled upon, though. I've set up watchdogs on my devices and they're being restarted regularly—which, of course, isn't a fix…
Bergante
Re: v6rc14 released
Sat May 11, 2013 12:39 am
Some things I would fix (rc14):
- Using BGP-VPLS (l2vpn) there's no way (or I haven't found it) to see the BGP advertisements
- The web GUI for BGP-VPLS doesn't work
- For routing->bgp it would be nice to have a l2vpn routes tab
- Logging isn't very consistent. I have noticed that, for instance, some OSPF state transitions are logged, but not all.
- IP->Neighbors->discovery: the web GUI doesn't offer the option to change default discovery settings. It can be set from the command line, though.
napismizpravu
error compilation all_files_6.0rc15.zip
Mon May 13, 2013 3:07 pm
error compilation all_files_6.0rc15.zip? update print log > system,error all broken package ...
samulosan
Re: v6rc14 released
Mon May 13, 2013 3:24 pm
any news on this?
Hi.Delete tls=yes of the script and enable in /tools/email.
Ex:
/tool e-mail send from= xxxxx@mail.com to=xxxx@mail.com subject=title file=backup
hope that helps
napismizpravu
Re: v6rc14 released
Mon May 13, 2013 3:46 pm
send backup by mail script works 6.0rc15 build time May/03/2013 11:50:25
Masyanich
Re: v6rc14 released
Mon May 13, 2013 5:05 pm
How can i download rc15?
HaPe
Re: v6rc14 released
Mon May 13, 2013 5:18 pm
Don't use it on production. It is in alfa stage, and every day is released an update.
If you need, contact to mikrotik support.
kobuki
Re: v6rc14 released
Tue May 14, 2013 12:00 am
RB450G, rc14, WinBox: ethernet interface Overall/Rx/Tx stats are completely empty or partially empty. On my router, ether1 is blank on every stats pages, and ether2 (2-4 ports switched together) is partially blank on the stats pages. ether1 has a changed MAC (ISP MAC restrictions), maybe this has something to do with the problem?
LennonNZ
Re: v6rc14 released
Tue May 14, 2013 11:41 am
I don't know if its a BUG on RC14 but I have a RB2011-UAS and I have a 3G USB Stick Attached to it via MicroUSB -> USB Adapter.
When I go into PPP Client to set up the Dialer for it I don't get an option for the USB Interface.. only the serial interface.
If I go into System/Resources/USB I can see the RB2100 has identified it
I have used the Same 3G device on a RB750 and its worked fine on the USB port.
Stillhard
Re: v6rc14 released
Tue May 14, 2013 2:35 pm
Tested 6.0rc15 (05/13/2013), RX/TX rates working, send email working, 100% cpu usage problem is gone now, but still error in usermanager web-ui (web-ui ignoring timezone setting) - in cli (/tool user-manager session print) its correctly show.
GOOD JOB MT team :-D
Deac
Re: v6rc14 released
Tue May 14, 2013 5:45 pm
Agree with Stillhard.
I can add that bonding still broken.
mrz
Re: v6rc14 released
Tue May 14, 2013 5:56 pm
What exactly with bonding is broken.
Deac
Re: v6rc14 released
Tue May 14, 2013 5:58 pm
ARP link monitoring don't work. Bonding iface immediately going to down.
mrz
Re: v6rc14 released
Tue May 14, 2013 6:00 pm
Did you send supout file to support?
Deac
Re: v6rc14 released
Tue May 14, 2013 6:46 pm
Done.
infused
Re: v6rc14 released
Wed May 15, 2013 1:13 pm
I had that bonding issue on Rc5 or 6 if I remember correctly.
RC13 seems to be the most stable at the moment.
mrz
Re: v6rc14 released
Wed May 15, 2013 4:58 pm
You can't and most likely in current implementation such feature will not be added.
Confirmed, will be fixed.
See the first answer
It is a known problem that down->init, init->2-way etc are not logged, but those state changes are not so important to spam the logs. In the future we could change that.
Click on entry in the "Discovery interface" table, there will be checkbox "enabled" uncheck it and discovery will be disabled.
mark
Re: v6rc14 released
Wed May 15, 2013 9:48 pm
  • sending emails using IPv6 SMTP server doesn't work
  • restricting access to IPv6 subnets in IP → Services doesn't work
  • L7-filters not available for IPv6
  • Accounting (the CGI script) is not available via HTTPS
normis
Re: v6rc14 released
Thu May 16, 2013 9:09 am
Those are not bugs, but feature requests. Many settings still don't accept IPv6. Thanks for the requests.
Bergante
Re: v6rc14 released
Thu May 16, 2013 10:05 am
Understood. However, please do consider adding it as soon as possible after the 6.0 milestone is reached. If the l2vpn feature is widely used, that debugging information will be very important.
I would seriously consider an overhaul of the logging policies. It's much better to "spam" the logs, allowing the user to filter what is needed and what not, rather than limiting logging. Such information can be critical to track bugs, regression changes, _and_ security incidents. You never really know what message is important (or not) until you miss it when you need it.
[/quote]
Yes. That allows you to enable and disable the discovery on each interface.
What I mean is a feature more like the Cisco "no cdp run", that is, "I don't want the discovery running at all".
From the command line you offer a close equivalent.
[admin@rb2011-despa] /ip neighbor discovery settings> print
default: no
default-for-dynamic: no
So that you can be sure that for any newly created interfaces discovery will be indeed disabled. I don't see these default settings available from the web gui. If I relied just on the web gui I would need to disable the interfaces one by one, explicitly.
That said, something like "/ip services set discovery disabled=yes". But this is not a bug in itself, but an enhancement request.
The discrepance between the command line and the web GUI (default discovery settings) is more like a bug to me ;)
Bergante
Re: v6rc14 released
Thu May 16, 2013 10:49 am
I forgot, sorry for the double post:
Regarding logging, I really miss a detailed logging of router advertisement/withdrawals for the routing protocols in debug mode. Not just state transitions.
honzam
Re: v6rc14 released
Thu May 16, 2013 2:07 pm
After upgrade from 5.25 to 6.0 = all packages all enabled.
Frekvency in log is still displayed in kHz
normis
Re: v6rc14 released
Thu May 16, 2013 2:30 pm
this is a feature, because in "advanced channels" you can specify channels with decimal places. khz will give you precise
spire2z
Long time Member
Long time Member
Re: v6rc14 released
Thu May 16, 2013 8:05 pm
I seem to have a problem where the hotspot login page wont open. All I did was upgrade from 5.24 to 6.14 and the hotspot page wont open? No setting changed.
DirectX9
Re: v6rc14 released
Thu May 16, 2013 8:20 pm
Hello to most respected support team. Please tell me, when can i expect final version ROS v6 for stable working CCR and all mikrotik wireless products?
All my (a lot of and expensive) custom is stopped, before the stability version will be released.
Please Answer and may be in separate topic.
DirectX9
rpingar
Long time Member
Long time Member
Re: v6rc14 released
Thu May 16, 2013 8:46 pm
MT,
when Firewall will get the benefit of manycores Platform?
In an old post Normis wrote into Feb. now we are in May.....
regards
Ros
majkel
Re: v6rc14 released
Thu May 16, 2013 11:11 pm
MT,
regards
Ros
The same question.. when? .. We need some protection of our servers..
normis
Re: v6rc14 released
Fri May 17, 2013 8:35 am
firewall has many core support. only some specific matchers don't have multicore support, but most popular matches supprt it. just look at how load is evenly distributed through all cores on the CCR
if you have the CCR and see only one core loaded with firewall and big traffic, send us your rules.
majkel
Re: v6rc14 released
Fri May 17, 2013 9:08 am
We have access to really big booters (min. 1Gbit/s of SSYN TCP) (2mln/packets) now and testing CCR with MANY RULES AND EXACLY ONE RULE for tested attack.. always the same.. he filtering of coures but not big attacks..
CCR give up when he must filtering about 700k/p.. (350mbit/s TCP).. many people ddosing everything and testing testing testing.. They without problem Can get acces to booters with 1mln/packets.. and our CCR is going to 100% on all cores..
Why there is no fastpatch support?
tracepath
Re: v6rc14 released
Fri May 17, 2013 11:36 am
IP routing rules for PBR no longer work.
normis
Re: v6rc14 released
Fri May 17, 2013 11:39 am
100% on all cores means that all cores are supported for firewall and working. What you are asking is for more speed in general. Did you enable SYN cookie in RouterOS? What kind of rule is that exactly?
majkel
Re: v6rc14 released
Fri May 17, 2013 12:46 pm
ah ah ah.. I wrote to You this half year ago.. yes i have SYN cookies enable..
I didnt say that they are no support for all cores for firewall.. but there is no good optimization for firewall..
normis
Re: v6rc14 released
Fri May 17, 2013 12:50 pm
Depends on your rule. Is that a Tarpit rule, or Drop? Based on what criteria?
half year ago we didn't have CCR. today the software is much improved.
majkel
Re: v6rc14 released
Fri May 17, 2013 1:34 pm
all the rules all droping packets.. but i`m testing the attacks with one rule.. like droping packets on port 80 TCP.. and its the same when i Have 50 different rules.. always max packets is 600-700k/s and I get 100% CPU..
I bought my CCR in November 2012 so I dont understand ;) why U dont have it..
I dont blame You that CCR is not good for DDOS now.. But I do not see to be better in future :( nothing changed from many releases.. the same power for firewall.. from v6
One company from Poland install some distrubution of Linux on CCR, and filtering 2mln/packets of TCP with 50% CPU.. So I thing there is a posibillity to do that the same on RouterOS..
przent
Re: v6rc14 released
Fri May 17, 2013 3:17 pm
Post a link/contact please. I`m very curious about this. Thanks. :-)
hngjared
Re: v6rc14 released
Fri May 17, 2013 8:46 pm
The TX rates in the host and active lists for the hotspot are not shown with 6.0rc11 - 14.
Any fixes available or is there a setting that has been added?
Thanks!
djras
Re: v6rc14 released
Sat May 18, 2013 12:43 pm
After upgrade to v6.0rc14 on RB2011LS I have a problem w Graphing:
Tools/Graphing->ResouseGraphs types=unknown for CPU, HDD, Memory
djras
Re: v6rc14 released
Sat May 18, 2013 12:52 pm
Downgrade from v6.0rc14 set default interfaces mac address. But I have specific MAC address. The Backup configuration in .rsc doesn't restore these data as was earlier in ROSv5.20
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1524 mac-address=D4:CA:6D:4D:21:D5 \
master-port=none mtu=1500 name=ether1 speed=100Mbps
bohorquezf
Trainer
Trainer
Re: v6rc14 released
Sun May 19, 2013 1:08 am
May check the availability of Mikrotik page?, We are training sessions and Examination for MTCNA, and you can enter the page Mikrotik.com
djras
Re: v6rc14 released
Sun May 19, 2013 9:04 am
The v6.0rc14 version on CCR1036-12G-4S slowly opens the Queues page (SimpleQueue) in WinBox of 5-10 seconds for 50 or more records and in addition open columns. In prev versions everything opened instantly. In this version delays began after addition of additional columns UpAvgRate DownAvgRate UpAvgPack DownAvgPack.
shrek777
Re: v6rc14 released
Sun May 19, 2013 3:58 pm
Website is having problems. http://www.mikrotik.com
I want to sent supout for ccr.
We have following services.
2 CCRs same configuration on each with same client quantity and same traffic, there are in different part of country, but same problems.
EOIP Tunnel with 100 mbps traffic
PPP server
Radius client (queues are added dynamically).
Problems on both CCRs EOIP tunnels are disconnecting very often, 20-30 times per day.
one of them are restarting 3-4 times a day and second 1 time in two days.
before on this points with same configuration was RB1100 and it was working about 1 year without any reboot, eoip disconnect or something else.
Also on both point we have CCR1036-12G-4S and both of them have only one CPU with 85% load, others are below 10% and cpu TEMP is 55c
mark
Re: v6rc14 released
Sun May 19, 2013 4:50 pm
Even with low load »bridge-local« keeps disappearing, resulting in my RouterBoard becoming unusable.
Furthermore, after that a »link local« doesn't get assigned to »bridge-local« even if I removed all link local addresses and rebooted the router. I believe it is the same bug that has been reported with v6rc12 here: http://forum.mikrotik.com/viewtopic.php ... wn#p362379
Bergante
Re: v6rc14 released
Mon May 20, 2013 11:28 am
There's a regression problem.
On 5.25 I can add a simple queue and bind it to an interface. Example:
[admin@OmniTik-casa] /queue simple> add name=queue-guest max-limit=512K/128K interface=ether2-master-local
This doesn't work on 6.0rc14. I can't add the "interface" clause to a simple queue.
This is a simple rate limit applied to a bridging interface, nothing complex. And 6.0 rc14 doesn't work as the documentation states.
Has the simple queuing been changed on 6.0 or is this a bug?
macgaiver
Re: v6rc14 released
Mon May 20, 2013 1:57 pm
"target" option now can be used - specify interface there.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Bergante
Re: v6rc14 released
Mon May 20, 2013 2:13 pm
Thank you :)
Documentation should be updated, then.
Also, there is something confusing in the documentation.
In case "target" is an interface, which direction is considered "upload" and which one is considered "download"? I would rather use "transmit" and "receive" provided, of course, "transmit" means "transmitted through the interface" and "received" means "received through the interface".
Or maybe "ingress" and "egress". But "upload" and "download" can be applied to the router or the network connected to the router interface.
Chupaka
Re: v6rc14 released
Mon May 20, 2013 2:37 pm
it's actually 'upload' of a 'target', i.e. traffic received on the interface :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
rower
Re: v6rc14 released
Mon May 20, 2013 2:56 pm
does not feel clear nor simple. :(
normis
Re: v6rc14 released
Mon May 20, 2013 3:06 pm
It is "Target upload" not "router upload". Therefore, these options are from perspective of the target. If you want to limit your users's upload capability, set "target upload".
honzam
Re: v6rc14 released
Mon May 20, 2013 5:54 pm
6.0 final to download...
http://www.mikrotik.com/download
GhostWorks
v6rc14 released
Mon May 20, 2013 6:19 pm
6.0 just been released ... Fantastic as I just ordered a CCR1036
Bergante
Re: v6rc14 released
Mon May 20, 2013 7:01 pm
I'm still confused about "target" and "dst".
And it seems that using "target" I end up with a symmetric queue (I was trying something like 1M/128k) while using "dst" (again, with an interface as an argument) now it works.
So, this configuration allows me to limit output bandwith (on the interface) to around 1 Mbps, input to around 128 kbps.
# may/20/2013 17:59:08 by RouterOS 6.0rc14
# software id = PAXV-BRR1
/queue simple
add burst-limit=2M/192k burst-time=3s/3s dst=ether2-master-local limit-at=1M/128k max-limit=1M/128k name=guest-limit target=""
Still, upload and download are poor names. If you put them on an upstream interface, they work. If you apply the queue to a downstream interface it's the opposite, which is counter-intuitive. Or at least in this particular case :/
keraia
Re: v6rc14 released
Mon May 20, 2013 7:32 pm
I just installed version 6.0.
First impressions compared to 5.24: (mipsbe on RB435G)
Memory usage +100%
Disk usage -50%
CPU usage about +30% for the same bandwidth (this measurement is approximate as I cannot replicate exact same bandwidth/number of connections)
I would go back to 5.24 but since we are going to move to 6.x eventually, I will give it a try for some time.
onnoossendrijver
Re: v6rc14 released
Mon May 20, 2013 10:07 pm
Memory usage +100%
Disk usage -50%
Hm.. I have a different experience..
Got 2 RB600A, same configuration, same test..
6.0 vs 5.24:
memory: about the same
Disk: -50% (like you)
CPU: -30% (opposite of you)
I think I like 6.0 :)
gnic
Re: v6rc14 released
Tue May 21, 2013 5:40 am
Have problems when I try to run the torch in a Simple Queue
*RB1100AHx2
gnic
Re: v6rc14 released
Tue May 21, 2013 6:34 am
All Simple Queues are gone, closed the winbox and opened again several times and still not displaying no queue.
normis
Re: v6rc14 released
Tue May 21, 2013 8:23 am
what version did you have before you upgraded?
gnic
Re: v6rc14 released
Tue May 21, 2013 8:41 am
upgrade v5.21 to v6.0 , Had this same problem reported after the queues are gone --> fixed queues - router could become unresponsive when configuring queues;)
I returned to 5.21 everything normal now
normis
Re: v6rc14 released
Tue May 21, 2013 8:44 am
Always make backups, and if possible, upgrade to v5.25 first, then to v6. This is not required, but could avoid some unknown issues.
afindlay
Re: v6rc14 released
Wed May 22, 2013 5:52 pm
I had just got IPv6 router advertisement working properly on 5.17 and I upgraded to 6.0rc14.
No router advertisements any more. In fact it had lost all the config under "/ipv6 nd" when seen from the command-line. The config could be seen from the web interface, but it didn't work. I re-entered the config from the command-line but still nothing.
Downgraded to 5.25 and all is OK again...
Andrew
wa4zlw
LInux on CCR hardware
Sat Jul 20, 2013 9:44 pm
does anyone have any more informaiton on linux on CCR? who got it going, etc> any links etc?
thanks leon
Ivoshiee
Re: LInux on CCR hardware
Sat Jul 20, 2013 10:25 pm
thanks leon
It sounds something for the OpenWRT. Maybe they are developing it.
IAmStaka
Re: v6rc14 released
Thu Aug 08, 2013 1:45 am
meanwhile i can't handle SSYN floods :(
help <3
Users browsing this forum: BlackFate, kical, Majestic-12 [Bot], sstoyanov and 102 guests
