MUM Europe 2020
richard_s
Help routing problem
Wed May 01, 2013 5:46 pm
I have been trying to setup a RB433 (V5.11) with 192.168.1.17 (Gateway to internet 192.168.1.1) on Wlan1 and 192.168.2.1 on Bridge1. No matter what I have tried I cannot get a connection from 1 networkto the other.
What have I done wrong or what is missing?
ip> address print
# ADDRESS NETWORK INTERFACE
0 192.168.1.17/24 192.168.1.0 wlan1
1 192.168.2.1/24 192.168.2.0 bridge1
/ip> route print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 wlan1 1
1 ADC 192.168.1.0/24 192.168.1.17 wlan1 0
2 ADC 192.168.2.0/24 192.168.2.1 bridge1 0
ip firewall> nat print
0 chain=srcnat action=masquerade out-interface=wlan1
Richard
columf
Re: Help routing problem
Wed May 01, 2013 10:53 pm
bit of a noob myself so this may not work try adding /ip route add gateway=192.168.1.1
nickshore
Wed May 01, 2013 11:42 pm
Your default route has the wlan interface on it, this only works for ppp type connections.
You need to specify the next hop IP address instead.
Nick.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
richard_s
Thu May 02, 2013 11:18 am
Pardon my ignorance but how do I set the next hop?
Richard
SurferTim
Thu May 02, 2013 11:34 am
If you mean you can't access devices on the bridge from devices on wlan1, that is correct. Unless you route that from the wlan1 gateway router, you can't.
If you mean you can't access wlan1 devices from the bridge, then you have a problem. That would probably be solved by columf's suggestion.
richard_s
Thu May 02, 2013 12:02 pm
I have tried columf's suggestion. config is:-
/ip address> print
/ip route> print
0 A S 0.0.0.0/0 192.168.1.1 1
1 S 0.0.0.0/0 wlan1 1
2 ADC 192.168.1.0/24 192.168.1.17 wlan1 0
3 ADC 192.168.2.0/24 192.168.2.1 bridge1 0
ip firewall nat> print
I cannot ping Wlan1 from Bridge 1
Any thoughts?
Richard
SurferTim
Thu May 02, 2013 12:06 pm
Can you ping 192.168.1.1 from the bridge?
Can you ping from a wlan1 device to another wlan1 device?
Users browsing this forum: No registered users and 26 guests
