gabak
how to save queues list into a TXT ??
Sun May 05, 2013 5:55 am
i have a long list with all my user and i want to take to other mt i got.
thxs in advance
adairw
Re: how to save queues list into a TXT ??
Sun May 05, 2013 7:24 am
Export compact to a file and copy the bits you want?
gabak
Mon May 06, 2013 7:24 pm
thank you so much for your quick answer.
please tell me how to do that.
i dont see export menu.
boen_robot
Mon May 06, 2013 7:26 pm
From a terminal.
Click "New Terminal", type
ros code
/queue simple export file="queues.txt"
and hit enter.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
gabak
Mon May 06, 2013 7:42 pm
thank you
it works !!
1-other question how can u save just the name field?
2-or can it be save in xls format? ;-) hehe
From a terminal.
ros code
and hit enter.
boen_robot
Mon May 06, 2013 9:03 pm
Not directly and/or easily.
To export just the names, you could create a custom script at "/system script", but you'd have to learn scripting for that.
For Excel, it's even harder. The easiest way is to create a CSV file using scripting. Alternatively, if you know any programming language (C, PHP, JAVA, C#, etc.), you could connect to the router using the API protocol and use whatever other libraries are available to that language to programmatically create Excel files.
gabak
Mon May 06, 2013 9:09 pm
can u help me with that?
do you have a script that would help me with that?
this is the way i made the queues.
:for e from=3 to=254 do={
/queue simple add name="user $e" target-addresses="10.0.0.$e" max-limit=244000/2804000 queue=default/default total-queue=default
boen_robot
Mon May 06, 2013 9:21 pm
I think the following should work generating a list of names (one per row)
ros code
:local "filename" "queue_names.txt";
#Create a (nearly) empty file to overwrite later
/file print file=$filename where 1=0;
:local contents "";
/queue simple
:foreach "queue" in=[find] do={
    :set "contents" ($contents . [get $queue "name"] . "\n");
/file set $filename contents=$contents;
I think Excel might be able to extrapolate that into a column of values, but I'm not sure. If it doesn't, you'd have to figure out what it does and does not accept from text files before reworking the script accordingly.
gabak
Tue May 07, 2013 6:03 am
i ll be happy just to get a txt with field name only, the excel file will be a bonus ;-)
i did what you told me and i get an error and a txt file with everything instead of just field name.
here it is what is said
[admin@MikroTik] > :local "filename" "queue_names.txt";
[admin@MikroTik] >
[admin@MikroTik] > #Create a (nearly) empty file to overwrite later
[admin@MikroTik] > /file print file=$filename where 1=0;
syntax error (line 1 column 19)
[admin@MikroTik] > :local contents "";
[admin@MikroTik] > /queue simple
[admin@MikroTik] /queue simple> :foreach "queue" in=[find] do={
{... :set "contents" ($contents . [get $queue "name"] . "\n");
expected variable name (line 2 column 10)
[admin@MikroTik] /queue simple> };
[admin@MikroTik] /queue simple> /file set $filename contents=$contents;
syntax error (line 1 column 12)
ros code
:local contents "";
/queue simple
normis
Tue May 07, 2013 11:15 am
you must post that into the script editor on menu "system script", then run it. not just command line anywhere
Users browsing this forum: Google [Bot], ysha and 70 guests
