Jeanluck
Back leds on sxt lite, don't works, Is normal?
Wed May 08, 2013 4:09 pm
The SXT lite is properly connected and with good signal but LEDs are off.
Is a limitation of this model?
The other SXT model leds, works fine.
normis
Re: Back leds on sxt lite, don't works, Is normal?
Wed May 08, 2013 4:14 pm
is it in station mode, or something else?
nickshore
Wed May 08, 2013 4:19 pm
AFAIK the LEDs only work in the station modes.
It would be nice if the LEDs worked in Bridge mode (only allows 1 client) as well, but I don't think they do ?
Nick.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
Jeanluck
Wed May 08, 2013 4:46 pm
Yes, I try with 3 SXT 5nD r2, and nothing....
Router OS 5.24 and 5.25
Yes, they are in station bridged mode.
I've been installing SXT for months, and I have only this problem with the SXT Lite (configuration is identical to that of the other antennas)
normis
Wed May 08, 2013 4:48 pm
like it was said, LEDS only work in "station" mode, not ap-bridge, bridge or other modes.
Jeanluck
Wed May 08, 2013 4:51 pm
yes, they are in station mode, like others working SXT (not lite). Only fail in SXT Lite
normis
Wed May 08, 2013 4:53 pm
Are you using RouterOS v5.25 and latest RouterBOOT? Also make sure you have not reset the '/system led' configuration. You can also manually configure them there.
Jeanluck
Wed May 08, 2013 4:56 pm
Yes, 5.25 and 3.07.
I honestly do not see /system led, because I had never needed to touch ... I'll take a look
Jeanluck
Wed May 08, 2013 4:59 pm
Indeed, I have "/system led" empty. I do not know why, this with the default settings, I never touch that.
thank you very much
normis
Thu May 09, 2013 8:54 am
thank you very much
Upgrade to newest v6 release and do "/system reset" to fix it.
Users browsing this forum: johnmes, MaxMan and 91 guests
