uldis
Attention v2.9.16 users!
Fri Mar 10, 2006 10:57 am
If you are using v2.9.16 then please change
 /ip firewall connection tracking>print
enabled: yes
tcp-syn-sent-timeout: 50ms
tcp-syn-received-timeout: 50ms
to
enabled: yes
tcp-syn-sent-timeout: 5s
tcp-syn-received-timeout: 5s
spoiler
Fri Mar 10, 2006 2:01 pm
Nice, 2 hours trying to figure out why nearby servers worked and others not... and why icmp was working with all of them, thought it was a BGP issue...
Just as a note... if you downgrade, setting will keep unchanged!
pekr
Fri Mar 10, 2006 2:18 pm
guys, isn't it better to simply release 2.9.17?! Remember - not all ppl do visit this forum ....
-pekr-
uldis
Fri Mar 10, 2006 5:27 pm
Done
changeip
Re: Attention v2.9.16 users!
Fri Mar 10, 2006 6:23 pm
enabled: yes
to
enabled: yes
5s? Was previous value something like 1-2m? I think 5s is still too short for many users on slow dialup, cellular, etc. I'm just throwing this out there, not saying 5s is wrong though...
Sam
DirectWireless
Fri Mar 10, 2006 6:54 pm
We sell MT routers to corporate customers who manage them themselves (we provide consulting support ) and man I had a stack of phone messages this morning when I came in from frantic customers!
samsoft08
Long time Member
Long time Member
Thu Mar 16, 2006 8:42 pm
[admin@MikroTik] ip firewall connection tracking> print
enabled: yes
tcp-syn-sent-timeout: 1m
tcp-syn-received-timeout: 1m
this is my MT setup .. should i change 1m to 5s ?? and why ??
Hammy
Forum Veteran
Forum Veteran
Mon Mar 20, 2006 4:52 am
enabled: yes
Same here... suggestions?
aviper
Mon Mar 20, 2006 10:52 am
Tip: The topic is: Attention v2.9.16 users! ...
cmit
Mon Mar 20, 2006 10:57 am
This value (roughly said) defines the time-span that it may take to completely open a TCP connection. This is started by a SYN packet, and if the SYN-ACK packet doesn't arrive during the time you can configure here, the "half-open" connection is dropped.
Then main reason to keep this short is that this is one way to run a denial-of-service attack: If your system is waiting 1 minute if some (every) half-open connection will finally become a fully-established connection, it has to keep a rather long table of connections. By just starting to open enough "half-open" TCP connections you can block a system so that it cannot accept legitimate new TCP connections anymore.
So having this value on a unnecesarry high value is kind of dangerous. And 1 minute is too high in my opinion. 5 seconds should be enough to establish a TCP connection - remember: that is not, that everything has to be over in 5 seconds - just that the connection has to be completely established in max. 5 seconds.
Best regards,
Christian Meis
changeip
Mon Mar 20, 2006 6:46 pm
I've seen dialup users take longer than 5 sometimes ... 5-10s would be a good middle ground. 1m is definately too long : )
sten
Forum Veteran
Forum Veteran
Tue Mar 21, 2006 11:01 am
30 seconds in my opinion.
it matters to the functions that limit number of connections.
Move along. Nothing to see here.
Users browsing this forum: b10up, erlinden, Paternot, RalphIsoms, tgkmilo and 73 guests
