src
How to enable mikrotik broadcast 802.11d country code?
Mon May 20, 2013 8:05 pm
Hi there,
I just bought 2x RB2011UAS-2Hnd-IN for my office needs, and stuck on ability of these to broadcast 802.11d country code, so my Apple devices can connect to 13 channel. I set a country in mikrotik's wireless settings but still no country code broadcast from mikrotik.
sh-3.2# airport -s
                            SSID BSSID             RSSI CHANNEL HT CC SECURITY (auth/unicast/group)
                       MikroTik d4:ca:6d:8a:8d:fb -66  11,+1   Y  -- NONE
CC is a country code which has no value.
Any ideas?
normis
Re: How to enable mikrotik broadcast 802.11d country code?
Tue May 21, 2013 12:44 pm
did you also set wireless frequency-mode to "regulatory-domain"?
src
Fri May 24, 2013 8:56 pm
Sure. Any other settings to enable country code broadcasting?
src
Thu May 30, 2013 1:14 am
No one?
samsung172
Thu May 30, 2013 5:24 am
If there is misc client connecting to your AP (hotspot) and you have no control at client(s). Don't use encryption. it will not function 100% in mikroitik network.
So many clients does not have 100% compatibility to a wpa(2) etc encryption.
normis
Thu May 30, 2013 9:29 am
Seems like CC is not transmitted. We will see if we can make it.
src
Thu May 30, 2013 12:14 pm
Normis, how long will it take? I need to deploy my miktotik routers or just return them and use another hardware for my needs.
src
Mon Jun 03, 2013 10:47 am
Any updates?
src
Fri Jun 14, 2013 3:05 pm
Guys, I'm still waiting for updates.... Are any?
normis
Fri Jun 14, 2013 3:08 pm
feature request is in our list. there are some other things there too, so it will take some time.
src
Fri Sep 06, 2013 10:30 pm
any update on this?
I really need this ASAP. I have 4 Mikrotik APs in our offices, and my Apple clients not able to connect even to 5ghz networks because of no country code from Mikrotik APs.
haik01
Mon Sep 09, 2013 9:07 pm
What if you change to channel 11, does it work then? Or is there a specific reason, that you need to use channel 13?
src
Mon Sep 09, 2013 9:23 pm
Too much noise on channel 11 in my case.
xorax
Wed Oct 09, 2013 4:49 pm
Hi!
This topic is quite important to us, too.
Could you guys please give us a hint about when is this feature going to be implemented?
villi
Mon Oct 28, 2013 1:50 am
Any news ???
100% because of it a problem with ipad 2
RB450G, RB2011UAS-2HnD
src
Tue Dec 10, 2013 11:12 am
so any progress?
normis
Tue Dec 10, 2013 11:20 am
This feature has been implemented, it will be added to a future version.
src
Tue Dec 10, 2013 3:20 pm
6.8 ?
normis
Tue Dec 10, 2013 3:25 pm
It will be added with some other stuff, so it's not clear in which version.
macropin
Thu Sep 25, 2014 1:07 pm
Any update on when we can expect this feature?
macropin
Tue Oct 28, 2014 7:43 am
Any chance we will see this feature this year?
Foxeh
Mon Oct 05, 2015 12:43 pm
Still CC broadcast not working =( Trying to setup Germany as CC
Foxeh
Mon Oct 05, 2015 1:32 pm
Still not working 802.11d .... 6.33rc16 OS
inspirit
Sat Dec 12, 2015 5:48 pm
6.33.3 still not working :(
Any news?
macropin
Thu Feb 11, 2016 11:33 am
Bump bump bump... any chance we'll see this? Ever?
saltspork
Sun Feb 28, 2016 5:22 am
Without 802.11d country code broadcast I cannot use my new hAP ac between 5.5-5.7GHz (channels 100-140) with clients running Mac OS X.
In my scenario, all other nearby APs (running OpenWrt) are broadcasting the AU country code and when connected to these my MacBook shows the AU country code as selected, and lists all channels legal in Australia as supported. When connected to hAP ac, it falls back to "X1" country code and prevents use of all channels between 100-140.
themenace
Wed Mar 02, 2016 6:34 am
Would be great to see 802.11d in Australia
Problem for us is that a Cisco Wireless Sip phone requires 802.11d to operate (world mode phones)
This loyal Mikrotik customer would be very excited to see 802.11d added soon
saltspork
Tue Mar 15, 2016 3:18 am
Is there any chance that this will be added in 6.35 with wireless-rep?
macropin
Tue Aug 02, 2016 7:03 am
@normis Is there an update on when we will see this supported?
normis
Tue Aug 02, 2016 8:52 am
Looks like this feature is now forbidden to use:
http://www.silexamerica.com/unwired/802-11d/
pe1chl
Tue Aug 02, 2016 12:37 pm
In the US. But is this of any significance to other nations in the world?
In the US this should not be a problem anyway as all equipment sold in the US now must be non-modifyable
to use only US channels and settings.
normis
Tue Aug 02, 2016 12:41 pm
due to some new rules in most parts of the world, this becomes less and less relevant.
themenace
Thu Aug 04, 2016 5:35 am
So all those people who want to connect a Cisco phone to a Mikrotik cannot because the Cisco phone requires that the Country Code be transmitted
normis
Thu Aug 04, 2016 11:34 am
Are you sure? Many people use it and it works fine. Cisco phone couldn't "require" this, since it is an american company and like I said, these codes are now illegal in US
pe1chl
Thu Aug 04, 2016 12:33 pm
I think it is not illegal in the US to send a 802.11d country code, but it is illegal for devices sold in the US to enable extra channels or other features based on
receiving a country code that is not US. That makes sending of a country code useless in the US, although that could be debated because a visitor to
the US may bring a phone that actually disables some features when it receives a US country code, which is what they of course would like to see.
themenace
Mon Aug 08, 2016 10:03 am
I am sure Normis, we've had to remove the Mikrotik Wireless for a number of customers using Cisco Wireless SIP handsets because of this.
It specifically states in the documentation - we are in the APAC region
themenace
Mon Aug 08, 2016 10:09 am
As an example see document below.
"The Cisco Unified IP Phone 9971 requires World mode (802.11d) to determine which channels are
legally allowed for any given country"
Then we thought that we could simply set the phone to "US" and it wouldn't require it, turns out that this is not possible as there is a hard setting in the phone at time of purchase for your specific region so that is not even possible.
http://www.cisco.com/c/en/us/td/docs/vo ... er_011.pdf
R1CH
Forum Veteran
Forum Veteran
Wed Aug 10, 2016 9:45 pm
Did you check the FCC guidelines instead of the marketing blog?
https://apps.fcc.gov/kdb/GetAttachment. ... mber=39498
It does not make any mention of 802.11d being "forbidden". In fact, it states that permitted client devices can still use 802.11d:
(3) Country information derived from multiple adjacent access points (for example using
IEEE Std 802.11d provisions) may be permitted on case-by-case basis
The new guidelines are basically a list of acceptable ways for client devices to associate themselves with a country, eg via GPS or cellular signal country codes. So it just means client devices can't rely on 802.11d, not that it's forbidden. Support for 802.11d in RouterOS therefore is still useful to the millions of non-US client devices that configure allowed frequencies based on 802.11d information, and devices made prior to 2015 are still allowed to use the old rules (and thus 802.11d).
normis
Thu Aug 11, 2016 10:06 am
Thanks for the update.
macropin
Thu Sep 15, 2016 6:26 am
So @normis, when will we see this feature?
normis
Thu Sep 15, 2016 11:58 am
802.11 standard specifies that to send the country code via 802.11d, you also have to send a lot of other things, which are not easy to implement. So far, it looks very difficult.
GogiPenza
Wed Dec 13, 2017 1:03 pm
@normis, Hi !
Sorry for my english...
For a long time this question on the work of 802.11d was not raised.
Are there any changes to fix this problem?
In fact, this problem due to the inability to expose the required Country Code leads to poor performance of Apple devices.
I'm in Russia, and the inability to turn on 802.11d and also set the Country Code I need causes some Apple computers (Mac mini) not to work at 5GHz in the N band with a channel width of 40MHz.
@normis, Please answer - are there any changes in the implementation of 802.11d on your Mikrotik devices?
Big Thx!
GogiPenza
Sat Dec 16, 2017 10:48 am
Hello!
Does anyone know if the developers answer questions here? The question was previously asked ...
Thank you all for your help!
pe1chl
Sat Dec 16, 2017 11:33 am
This is not the place to get official answers from MikroTik, you have to email to support@mikrotik.com or maybe in this case to sales@mikrotik.com for that.
However, Normis is often posting here and as you can see above the latest on this topic is not promising (when you require it).
GogiPenza
Sat Dec 16, 2017 11:36 am
@pe1chl, Thx!!!
Users browsing this forum: No registered users and 22 guests
