mahnet
Long time Member
Long time Member
BANDWIDTH TEST VS ACTUAL THROUGHPUT
Tue May 21, 2013 9:23 pm
I do not understand why but I have experienced this a number of times.
1. 2 SXT's point to point - configured bridge and station bridge using nv2 routerOS 5.24
2. bandwidth test shows - 100mbps +
3. real-time internet bandwidth shows increased latency at 6 mbps+
4. Why?
5. Noise floor -117 dbm, tx/rx connectivity - 63/67 dbm
Belyivulk
Re: BANDWIDTH TEST VS ACTUAL THROUGHPUT
Wed May 22, 2013 9:16 am
As always, what is your configuration?
angboontiong
Wed May 22, 2013 9:49 am
4. Why?
i believe you test it via the udp...
you should test it by using tcp then u will get the same result.
and, test both direction instead of one direction.
btw, can you print screen on the status???
Users browsing this forum: No registered users and 70 guests
