zhangxiao
What's the best wifi speed I could get from RB951G-2HnD?
Fri Jun 07, 2013 11:45 pm
I just bought a RB951G-2HnD and set it up. When I transferred a 2GB file from my Macbook air to a Macbook Pro, the peak speed is only 4 Mb/s. Most time it was only 3.2 Mb/s. I think it's too slow, but why?
Here are the 2 laptops:
InoX
Re: What's the best wifi speed I could get from RB951G-2HnD?
Sat Jun 08, 2013 9:58 am
4MB/s from Macbook air + 4MB/s to Macbook Pro = 8MB/s or 64mbps, is more than enough for an 130mbps connection.. You need to connect to more than 144mbps. Maybe 300mbps. Check google for Macbook wireless problems.
onnoossendrijver
Sat Jun 08, 2013 10:42 am
Have you enabled both chains and 40MHz channelwidth of the wifi interface in de Routerboard?
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
zhangxiao
Sat Jun 08, 2013 12:05 pm
Thanks. But I don't really understand what you said... did you mean this is a problem of macbook? When I used the router provided by the ISP the transferring speed is much faster...
zhangxiao
Sat Jun 08, 2013 12:08 pm
Thanks. Here are the settings:
zhangxiao
Sat Jun 08, 2013 12:16 pm
This problem drives me crazy now... I just removed RB951G and used the modem router directly to test. Here is the result:
If I connect RB951G to the modem and use it as router:
RB951G connects to modem through a 100 Mbit/s LAN port. So it won't get higher than 100 Mb/s. But 17.02 Mb/s is way too slow...
honzam
Sat Jun 08, 2013 12:23 pm
Upgrade to 5.25.
Then set - hw retries 15, Distance-indoors, try reduce Tx power
LAN, FTTx, Wireless. ISP operator
zhangxiao
Sat Jun 08, 2013 12:39 pm
Upgrade to 5.25.
I've upgraded to 6.0. Should I downgrade...?
zhangxiao
Sat Jun 08, 2013 12:53 pm
Upgrade to 5.25.
I've tried your config, no help. but thanks :)
Users browsing this forum: No registered users and 42 guests
